PRESS RELEASE
Safer sawing without a riving knife
MAFELL MT 55 cc plunge-cut saw with kick-back protection
In its new MT 55 cc plunge-cut saw, MAFELL has combined the benefits of enhanced active safety, improved handling and enhanced cut quality – without a riving knife. According to the manufacturer, active kick-back protection averts the danger of recoil when the blade enters the work more effectively than a riving knife. In addition, design measures introduced alongside standard EN 60745-2-5, which entered force in 2007, have increased the passive safety of saws that dispense with a riving knife.
Especially when entering the workpiece, the blade of conventional plunge-cut saws can easily jam and thus cause a kick-back. The MAFELL MT 55 cc plunge-cut saw significantly reduces the likelihood of this effect occurring. Thanks to the CUprex Compact motor driving the sawblade at a maximum of 6,200 rpm, the cutting speed is 20 per cent higher than usual. The teeth of the carbide-tipped sawblade thus remove less stock per revolution, which appreciably reduces the risk of jamming.
The probability of a kick-back arising from sawblade jamming is much lower while sawing is in progress as well. The high speed enables the blade to cut itself free more effectively. Additional safety is afforded by the automatic isolation of the power supply to the motor if the blade jams.
"The active kick-back protection provided by the high speed and automatic power supply interruption offers greater safety than a riving knife, which does not protect against the kick-back effect when the blade enters the work and can be a nuisance for the tradesman," comments Ralf Kohler, head of sales and marketing at MAFELL. Josef Riederer, a tradesman of Unterneuhausen, vindicates the manager's claim, "I feel safe when working with the MT 55 cc."
The passive safety of the MAFELL MT 55 cc plunge-cut saw is also enhanced by the strict provisions of EN 60745-2-5 for saws without a riving knife. In the event of a kick-back, the standard requires that the sawblade fully retracts inside its housing within just 0.3 seconds. In compliance with the standard's provisions, MAFELL tested this safety feature more than 50,000 times.
Dispensing with a riving knife makes the saw much easier to use. When changing the sawblade, for example, it is no longer necessary to change the riving knife according to the blade thickness and adjust it to suit the blade diameter. This not only accelerates the blade changing operation, but also reduces the workload when working with a variety of materials. Tradesmen are also delighted that the absence of a riving knife protects sensitive surfaces against the risk of scratch marks.
