I don't understand. DDF40 has all the same features as Domino (fence, pins, cross stops, alignment marks and window), and in addition there is a notched alignment bar. How is it a lot simpler with Domino?
Here's an example: A divider for, say, a compartment or drawer. There're three joints to do as shown in the image (blue lines). To do all of them, I only needed a DF500, the components of the compartment, and a pair of clamps or holdfasts. No measurements of any kind or pencil marks are needed:
1) Clamp the divider in position on one of the compartment boards (front, back or bottom) -- please refer to the manual for the set-up details
2) Mill the two outside mortises using the paddles on the divider and then on the compartment board (the order is not important)
3) If a middle one is needed, mill it on the divider and then stand the machine to mill the mating one on the compartment board using the wide or widest setting -- which means no pencil line is needed.
Repeat the above steps for the other two joints.
Can a DDF40 complete the same joinery task quicker or with no other aids? I don't think so -- based on my understanding (
not experience) of how it works.
Food for thought: Is it simpler or quicker to mark placement lines (assuming they're needed if one doesn't have the cross stop) or to measure (with a tape), position the alignment bar and clamp it down? Not to mention that you must ensure that you use the correct set of notches to mill the holes.
