Author Topic: Looking for saw blade reviews  (Read 1823 times)
Offline 9Fingers
« on: February 02, 2018, 03:48 PM »
I'm a hobbyist woodworker and I recently purchased a used Felder K500 sliding saw from a cabinet shop.  It came with a couple of melamine blades but I'm also looking to get a Rip blade and some kind of combo blade to use with solid wood. I have used the Forrest WW II 40 tooth in the past with good luck but I was wondering if any of you with sliders could share your thoughts and experiences. Has anyone tried the Felder Silent combo blade? I will need a blade with a 30mm 2 pin arbour.
Thanks for your time.
Offline TSO Products
    • TSO Products
Re: Looking for saw blade reviews
« Reply #1 on: February 03, 2018, 11:29 AM »
have you reached out to Dan Clermont at ULTIMATE Tools in Burnaby, BC: www.ultimatetools.ca
phone (604) 291-9663
Dan knows these saws very well, sells and sets them up.If Dan is not available right away, ask for Chris Wong Chris@ultimatetools.ca
enjoy your sliding table saw!
Hans
TSOproducts.com
Offline Bert Vanderveen
« Reply #2 on: February 03, 2018, 05:26 PM »
Felder doesn't make the saw blades (most machinery brands don’t, eg Festools saws — and probably the Felder branded ones — are most likely made by Leitz) — you pay more what they buy in and have branded.
Research experiences from other users and try out what is recommended. (What is good and available also depends on your location. In the US Forrest gets mentioned a lot, in Europe Leitz, CMT, AKE and Freud.)
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
