Author Topic: Which New Air Compressor Lines  (Read 8014 times)
Offline wow
  • Inactive Member
« on: May 11, 2014, 04:54 PM »
Since I have the ceiling open in my shop, I am considering moving my air lines up into the ceiling (conditioned space) to run around the shop and just doing 'drops' wherever I want them. I currently use black pipe, but I am open to other options. It might be difficult for me to get lengths of black pipe angled up into the truss space?
I want at least 1/2" - 3/4" ID pipe. My compressor is a 2-stage 80 gallon IR that can produce about 16 CFM at 90 PSI, and a maximum of 175 PSI. BTW, the longest run would be around 60-70 feet.
What would you guys do?
Offline leakyroof
Re: Which New Air Compressor Lines
« Reply #1 on: May 11, 2014, 05:18 PM »
I like iron pipe, I can thread it easily, and it's strong and dependable .
Some people just solder 3/4" copper tube and go with that, even at 150psi line pressure before your regulator takes it down at the end of your run.
Offline Peter Halle
« Reply #2 on: May 11, 2014, 06:06 PM »
There is of course the newer plastic - almost like PEX - systems out there that offer flexibility, fewer joints, and adaptability in the future.  I am sure if you do a google search for plastic air line piping you will find info.
Offline WarnerConstCo.
    • Warner Mill Works
« Reply #3 on: May 11, 2014, 07:15 PM »
Iron, sloped with drops for drains.
Offline RJNeal
« Reply #4 on: May 11, 2014, 07:24 PM »
 [thumbs up]and take your feeds off the top of the pipe. It will cost you two elbows per drop but you will get less water
At your tools.
Rick
Offline rst
« Reply #5 on: May 11, 2014, 07:25 PM »
This stuff works great and is easy to install http://www.rapidairproducts.com/
Offline tjbnwi
« Reply #6 on: May 11, 2014, 09:26 PM »
I've installed the Rapid Air system for others. It is a nice product.
Offline Brenton Olander
« Reply #7 on: May 12, 2014, 04:46 AM »
I installed 1/2" AquaPex for a few drops inside my workshop, and a 1" run to an upstairs bedroom that I often setup as a spray booth.  It sure was easy to build.  I have a Quincy 5hp, 2 stage, 60g compressor with a harbor freight air dryer attached. I do have moister filters near the tools that need that. With the dryer attached I decided not to setup up any kind of water drainage system in the lines. So far, so good, but I haven't really used it that much yet.
Offline wow
  • Inactive Member
« Reply #8 on: May 12, 2014, 03:24 PM »
I already have the tools to do the aquapex, but I've seen mixed statements about whether it could handle the pressures involved. I suppose I should research that some more, since sure like the ease of installation.
My shop does have a couple of windows, so the lex could be exposed to UV to a small degree. Just another consideration, I guess.
Offline Richard A.
« Reply #9 on: May 19, 2014, 03:00 PM »
 I have a large 2-stage stationary compressor in my shop. I just used 1/2" PVC to pipe air all around my shop. You can save a lot of $$ not using black-pipe or copper. PVC holds 175 lb with ease.
 I have also used this PVC set-up on large commercial jobs. We put the compressor on the ground floor (or in the L.L. for security & noise) and run a vertical 1” PVC riser up to each floor. On each floor we ‘T’ off ½” PVC horizontally runs the width of the building. As the building goes higher, we just cut off the end cap and add to the riser. Usually the easiest place to run the riser is through the elevator shaft. With this set-up, all the trades have air at a few central locations on each level. PVC is cheap. At the end of the job, we just remove the quick disconnects and abandon the PVC.
- Rich
SOME PEOPLE ARE LIKE SLINKIES
They're not really good for anything,
but they still bring a smile to your face
when you push them down a flight of stairs.
« Reply #10 on: May 19, 2014, 08:15 PM »
PVC should not be used for compressed gasses including air.  It tends to explode and send sharp shards all over the place.  Manufacturers often print a statement about not using it for compressed air or gasses right on the pipe.
« Last Edit: May 19, 2014, 08:23 PM by Hurricane Whisperer »
Offline wow
  • Inactive Member
« Reply #11 on: May 19, 2014, 08:20 PM »
I agree. PVC is NOT an option I would consider.
Offline Richard A.
« Reply #12 on: May 19, 2014, 08:27 PM »
  I have been using PVC for 37 years now and have never had it explode. I have used it in both winters and summers here in NJ.
 - Rich
Offline festooltim
« Reply #13 on: May 19, 2014, 08:35 PM »
My brother uses PVC in his metal fabrication shop for many years and never had a problem.
Quantity is no substitute for Quality
2-mft3's ,  ct22,  ts55,  rotex125,  c12, kapex,  ras115,  65planer,  of1010,  LR32system, trion psb 300 eq,  parrallel guides,    sortainer,  routerbitsystainer,  guide rail acc. kit,  toolie,  t-shirt,  hat,  pen,  saftey glasses.
« Reply #14 on: May 19, 2014, 08:44 PM »
I have heard a lot of statements like that from people who use it.  I have also personally heard it explode when every one was at lunch and no one was around to damage it any way.
At Garagejournal.com forum, the subject comes up frequently and the compressed air guys usually post pictures of various exploded lines and refer to OSHA regulations against using it.
Offline BobcaygeonJim
« Reply #15 on: June 01, 2014, 05:08 PM »
I used their Maxline 1/2" master kit for my shop. It has aluminum core with a pex type outer jacket. It was very easy to install and I like the outlet blocks with the drain valves.
Offline James Metcalf
« Reply #16 on: June 01, 2014, 07:42 PM »
One con for any plastic is if you have a fire the plastic melts and then the air feeds the fire. Having said that I have not made my mind up and this discussion is of interest to me. I am also building a shop.
Offline jimmylittle
    • JimmyLittle
« Reply #17 on: June 01, 2014, 08:01 PM »
I second the RapidAir system.  Easy, and in the north east US, cheaper than black iron pipe.  It's also not prone to rusting like iron, lighter, and flexible so there are less connectors necessary.  They offer in-wall, surface mount, ceiling mount and even exterior hose connection plates, and all the fittings are friction fit.  If you decide to reconfigure later, the fittings can be reused.
You can get the starter kit for less than $150.
Using a good tool to do a good project for a good client makes me feel good.  Remove any of the three and things aren\'t so fun anymore.
Offline Dovetail65
« Reply #18 on: June 01, 2014, 08:18 PM »
I agree, at rapidair at .91cents  a foot for 1/2 inch and ease of install how much do you really save by using PVC which really isn't designed for it or iron with all its issues?
Starter kits are way less than 150.0 more like 95.00 for 1/2" , 3/4" is about 185.00.
« Last Edit: June 01, 2014, 08:30 PM by Dovetail65 »
Offline Rusty Miller
« Reply #19 on: June 01, 2014, 08:20 PM »
Just looked the Rapidair system up on Amazon.  You can save some money on the kits.
Rusty
Rusty Miller
I'd rather be woodworking!
Offline amt
« Reply #20 on: June 02, 2014, 12:26 AM »
I find the advocating of PVC on the Festool forum kind of odd.  Don't people want quality and safety, even if it costs more?
Personally, I used copper, and it works quite well.
Offline UncleJoe
« Reply #21 on: June 02, 2014, 01:05 PM »
I bought the rapid air and installed about 3-4 years ago and have not had one single issue. I read somewhere that some Nascar shops have gone to rapid air system but in reality there was probably an endorsement deal so you can't just say they use it because it is better but I guess you can say that if it failed or was just bad they would not allow it in their shop.
Just a hint. The tubing comes in a coil and to get a neat job you have to uncoil it and allow it to sit in the sun until you can work with it. The connectors are great and I love the stuff.
I am not young enough to know everything!
