Author Topic: Lightweight routers dedicated to roundovers  (Read 4586 times)
Offline afish
Re: Lightweight routers dedicated to roundovers
« Reply #30 on: May 04, 2021, 08:20 PM »
That Ryobi might surprise you.  I havent ever used one but light duty tasks such as  Roundovers, chamfers, flush trimming doesnt usually require a $500 MFk.  If you have several and leave them set up for dedicated tasks the ergonomics such as height adjustment, bit change etc. becomes less of an issue. I always make new bases for mine anyways because they always feel on the small side and I like to make them so the center of the bit is 2" from one of the long edges.  This way if Im setting up a straight edge to route against I just need to account for the radius of whatever bit Im using.  The main thing becomes how well it fits your hand and battery life.  For $69 bucks I doubt you will be disappointed for a small trim type router.  I wish the Dewalts were 129 like the Makitas. $199 is a little steep for them in my opinion.
Offline Banana
« Reply #31 on: May 04, 2021, 09:05 PM »
After trying a few colors I landed on the Milwaukee 18v.  10k to 31k rpm, plenty of power,  simple ez very fine adjustment,  great dust extraction, good ergonomics, motor brake, cheap n' cheerful always a sale round the corner etc.  I think most guys use the high output 3.0Ah for weight.
Regardless of the brand though, making different bases for how you work / the task will also go a long way towards how you like using any router.
Offline Stan Tillinghast
« Reply #32 on: May 04, 2021, 09:41 PM »
I have the Makita LXT 18V drill and driver, so added their XTR01Z cordless router. Very handy, nice soft start, lots of power. I think was $118 for bare tool.
Für uns...ist das Beste gerade gut genug!
Offline online421
« Reply #33 on: May 04, 2021, 09:46 PM »
I have a Festo Of1000 which I use it for roundover... guess its from the era when Festool used to be Festo?
Griggio Unica400
Felder AD951
Masterwood OMB1V
Omga T55-300
SCM 5 RCS1100
SCM TI145EP
Comatic DC40
Chicago Pneumatics CPRS10500
Ceccato CDX 12
Holytek DC006
Festool DF700XL, LEX3, OF1010, OF2200, CT36, VAC SYS
Starmix 1635
Danfoss VLT 2880
Sicar TOP6
Offline mrFinpgh
« Reply #34 on: May 05, 2021, 01:31 AM »
These cordless routers do seem like they would be very convenient.  Cord management isn't fun when the router is running.
I have a few of the old porter cable 310 model routers.  One has the offset base with the belt drive, which is kind of neat.  I haven't done much with them, as I usually run a dewalt trim router since it has some dust collection.
as @Banana mentions, having the right baseplate makes a world of difference w/ these edge trimmers.
Offline FestitaMakool
« Reply #35 on: May 05, 2021, 05:34 AM »
For those of you who is considering the Makita router, whether corded or cordless.
There’s this lesser known base available separately (It does not come with the 3 base kit)
It’s base can also de-attached from the offset unit in order to be used as a widening base for the router it selves.
Offline afish
« Reply #36 on: May 05, 2021, 08:11 AM »
Yes, thats the major issue with the Dewalts. They only offer a the fixed base and a plunge base. No tilt, offset, or underscribe but I dont think the Makita has an underscribe either (could be wrong on that but I havent seen one).  Underscribe might not be a big deal to most, its pretty specialized as is the offset but its always nice NOT to be limited.  I will probably still pick up a makita cordless and a battery adaptor just for the tilt base.  Plus I have been wanting the Makita drywall cut out tool. That thing looks sweet for remodel work and dust control.
Offline notenoughcash
  • to many ideas, not enough cash....
« Reply #37 on: May 06, 2021, 03:53 AM »
i have a katsu makita knock off, and it is identical to the makita other than the scribles on the side.  and it cost half the amount
turns out that woodworking is 1% making things you'll use, 4% making bespoke high end firewood, 15% cleaning, and 80% looking for the bl**dy thing you just put down
Offline Knight Woodworks
« Reply #38 on: May 07, 2021, 02:51 PM »
Big fan of dedicated lightweight routers. Currently have four of the Makita cordless for site use. Hope to add a few more.  In the shop I use an old PC, a Bosch GKF125CE, a corded Makita and a Dewalt. Each have their pluses and minuses. I find the Makita to be the most comfortable to hold. Unfortunately it doesn't have a light, a feature I find important. The Bosch isn't quite as comfortable, it is agile and has a light. I don't find the Dewalt to be as comfortable as the others, I do like the light. It will probably end up in a plunge base.
John
Offline Rick Herrick
« Reply #39 on: May 07, 2021, 03:58 PM »
I got the Ryobi cordless in yesterday.  Put a small mortising bit in it as I want to use it to flush cut plugs/dowels.  I don't seem to have the technique with the Japanese pull saw to do this without scratching my work.  This Ryobi set up is very nice.  Cut the poplar dowels very easily.   Will also test with some oak and maple to make sure there is enough power but I think I am going to get a couple more of these.
What type of bits do you guys keep chucked up?  I am thinking this mortise or straight cut bit, a round-over and also a chamfer bit.  Be curious to see what others use on a regular basis that fits this scenario.
Offline afish
« Reply #40 on: May 07, 2021, 04:38 PM »
I typically have a .25 spiral down, a Amana Tool MR0110, Amana Tool - 47147, Amana MR0103, Another round over with a larger radi (the particular size escapes me at the moment Probably a 1/4 with 3/8 bearing but not positive), and a 45° chamfer with 3/8 bearing.
 The two miniature Amana bits probably wont be used by others much but they work good for cutting the onion skin on small parts that come off the cnc that were cut with a .25" bit.  one to flush trim or to just soften the corner depending on the part. If its a part that is going to get glued to another then it gets flushed if its a part that will get handled then the small round over. That pretty much handles most of what I need. I do swap a bit from time to time for odd ball stuff but its pretty rare.
It will depend on what you typically build and use.
Offline afish
« Reply #41 on: May 07, 2021, 04:40 PM »
Oh, I forgot the Festool 499811 also lives permanently in one trim router.
« Reply #42 on: May 07, 2021, 05:17 PM »
Japanese saws have set teeth too. There are special saws with flush teeth for this purpose. Lee Valley has a good one.
Offline CeeJay
« Reply #43 on: May 07, 2021, 07:26 PM »
Yes this one:
http://www.veritastools.com/products/Page.aspx?p=167
I use it all the time - really good, no scratches.
Offline Crazyraceguy
« Reply #44 on: May 07, 2021, 07:45 PM »
I typically keep a "bullet" style flush trim bit and a "no-file" bit in each of my cordless Makitas. The Bosch Colts are all configured for some kind of laminate bit too, but with specialty bases. One has the tilt base, one has the off-set base, one has the underscribe attachment and the last one has a 1/8" roundover.  One Rigid has a 1/4" down spiral and the other has an overhang trim bit. The corded Makita has a 3/8" bushing and a 1/4" down spiral.
I also keep two Milwaukee body-grip routers with Amana insert-style bits, one flush-trim, the other pattern. The OF1400 and OF1010 are the ones who actually get bits changed on them. All of the others do one specific thing and the Festools adapt to whatever comes along.
The MFK700 is generally set-up for trimming 3/4" thick wood edges, with the zero degree base, but not always. Sometimes it gets used for 3mm PVC edgebanding, usually on tops curved shape.
There are days that I don't use any of the laminate cutters and then others, like today, where I might have 5-6 of them out at once.
« Last Edit: May 07, 2021, 07:52 PM by Crazyraceguy »
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1400
MFK700 (2)
CT26E + Workshop cleaning set
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
TS75
Shaper Origin/Workstation
Offline acer66
« Reply #45 on: May 08, 2021, 11:43 AM »
I own a pair of the Bosch 12v routers and the ergonomics can't be beat.
You mean this guy?
I'm surprised people like the ergonomics on it.  I can't stand it personally, I have never figured out a comfortable way to hold it and have come close to putting my finger on the bit a few times because of it.  Really wish it was just the traditional design.
To the op though, I almost always have a 1/4" round over in it and love having it setup like that for quick tasks.  I'm considering getting another to leave setup with an 1/8" bit too.
Fits me like a glove in is my goto round over router.
Was a bit unusual in the beginning but once I got used to it it was like why did it take so long.
Might also help that I have a typical german build. 🤪
Offline afish
« Reply #46 on: May 08, 2021, 12:55 PM »
I like the looks of that Bosch, I like how the on/off looks like my thumb could easily reach it in while it is being held (unlike the Dewalt) and the slimmer easy to hold shape.  Even the Dewalt can make my hand start to cramp up after awhile but Im not as young as I used to be either.  Not so sure how I feel about it only being 12v but Im not going to be investing in another battery platform and even if I did it would be Makita since they offer one of the most comprehensive cordless lineups.  I do lots of different types of work so that might not apply to someone else that is a little more specialized.  It looks good though other than if you had big hands your fingers might get closer to the business end than I would like.  Bottom line is for light duty work that doesnt require a lot of horse power these cordless trim routers are hard to beat no matter the brand they will make thing much easier and the more you have the better.
I keep thinking about trying to add D-handles to my dewalts.  If I could figure out a non destructive way to add a D-handle with either a trigger for on/off or at least a switch that is easily toggled while holding the handle would be SWEEEET! one day Ill get some time and try to tinker with one.
« Reply #47 on: May 08, 2021, 03:15 PM »
Festita Makool:
Thanks for letting us know about that Makita offset base--I can see occasions when that would be very useful. (That's my general excuse for buying cool tools I may never use). I also bought the plunge base. Dust collection is not up to Festool standards, however, in my experience.
« Reply #48 on: May 08, 2021, 05:23 PM »
Festita Makool:
Haha, well it can easily be the case, however, I generally like to have most accessories available to any tool I have; at least when accessories can be a problem solver. As with this, since I bought the kit version with all the other bases, AND I had a particular task for the offset base, recognised that the moment I saw it, and ordered in fear of it going obsolete.
Have not yet done it; but I’ll retrofit seals to old door jambs - given the larger base and offset this accessory should be just the right tool, maybe.
The dust collection is quite all right, and with the same dc accessory as Festool has to theirs it would probably be very good. Edge routing do throw good amount of dust even with Festool’s, without the right accessories. Sooo.. one better accessorize sooner than later  [big grin]
Offline JonathanJung
  • www.timberlightdesigns.com
    • Timberlight Designs
« Reply #49 on: May 09, 2021, 07:34 PM »
Looks like this has hit a popular subject! Glad to read all the responses. Looks like I'll be going the cordless route, Bosch 12v routers and either Makita or Milwaukee 18v.
Offline Bob D.
« Reply #50 on: May 09, 2021, 08:57 PM »
" If I could figure out a non destructive way to add a D-handle with either a trigger for on/off or at least a switch that is easily toggled while holding the handle would be SWEEEET!"
That would be nice. A D handle with trigger switch like the old PC690 had would be a winner.
Offline fshanno
« Reply #51 on: May 10, 2021, 02:56 PM »
Before getting into Festool a year ago, I had a bunch of Ryobi tools and batteries.  I rarely use any of them now but they do have a trim router for $69 US.  And since I have a bunch of batteries, I went ahead and ordered one just to see if it can do what I want.  Like most, I don't want to invest a lot but having a couple routers at the ready, would be nice.
I started buying Ryobi AFTER I already had a bunch of Festool stuff, including this trim router.  I got sucked in because I already had several 18v batteries for lawn stuff.
It's a good little trim router.  No complaints.
