Author Topic: Kreg saw guide  (Read 373 times)
Offline Packard
Kreg saw guide
« on: October 08, 2021, 10:44 AM »
IGM (a European vendor of woodworking equipment and supplies) posted this video, offering the Kreg Saw Guide as a viable substitute for a track saw.  I would imagine no one here will agree (or why did we spend all that money when the Kreg guide is just $40.00?).
I do wonder what kind of accuracy it can maintain.  I did consider one of those to cut down plywood to manageable sizes in the parking lot of the lumber yard.   But I got a Chrysler Pacifica which easily swallows up full sheets of plywood so I went with the track saw.
Could someone produce a satisfactory looking base cabinet using that saw guide and a Kreg pocket hole jig?  I think I could.
Offline squall_line
Re: Kreg saw guide
« Reply #1 on: October 08, 2021, 11:04 AM »
My initial thought before even watching the video:
A rip cut with a parallel edge guide is only as straight as the reference face.  Same with squareness.  MDF may have a better record of squareness than other sheet goods, but the beauty of a track saw is that you rip a true straight edge first, before making any more cuts.
FWIW, Festool sells a parallel edge guide for the HK saws as well as one for the TS saws.  It's something I'm curious about but again requires a straight reference edge if you want good results.
After watching the video:
Not only are circular saws messy, but they chose MDF for all of their examples?  I feel like I need to clean my keyboard after watching that!
Also, my "straight reference edge" comment holds true.
« Last Edit: October 08, 2021, 11:59 AM by squall_line »
Offline Packard
Re: Kreg saw guide
« Reply #2 on: October 08, 2021, 11:36 AM »
Her cuts were on MDF.  But it looks to me that his cuts are on plywood.
This brings to mind another issue.  The Festool saw makes cleaner cuts than my table saw even with a zero clearance insert.   Partially it is because I am able to make a scoring cut of about 1/4" and draw the saw towards me, and then make the final cut.
Now my circular saw, even with a new, high-quality saw blade makes rougher cuts than my table saw.  I do wonder if I can apply the FASTCAP's zero clearance tape to the baseplate of my circular saw.  It would have to run the full length of the saw and possibly another strip would have to run on the far side of the base plate to keep it level. (The tape is 0.024" think).  I think it would work, but I am not certain.
In any case it would be an interesting experiment to see if I could "go caveman" and make a base cabinet with just a circular saw.
Offline Blues
Re: Kreg saw guide
« Reply #3 on: Today at 04:15 AM »
Good tools provide consistent professional results in a quick easy way saving you time. And the more you use it is easier to justify the cost (especially if you are a tradesman) and can take the rigor of everyday use.
So you pay more in up front cost. With festool.. you buy into a system... not just the tool. So the initial cost goes a long way as you add additional tools that play with each other.
