Author Topic: Kreg Drawer Slide Jig with 3/4" "Rail"?  (Read 1049 times)
Offline TheTechRunner
« on: January 13, 2020, 10:35 AM »
Does anyone know if the Kreg drawer slide jig can somehow work on a frameless cabinet with a 3/4" "rail"? I built some shop cabinets with a piece of 3/4" x 2"  plywood between each of the drawers. It doesn't seem like the Kreg drawer slide jig will work but the Rockler would. Picture attached. These are my first cabinets so any constructive criticism is welcome as I have some more important cabinets on the honey do list [laughing].
« Last Edit: January 13, 2020, 10:37 AM by TheTechRunner »
Offline Getmaverick
Re: Kreg Drawer Slide Jig with 3/4" "Rail"?
« Reply #1 on: January 13, 2020, 06:36 PM »
I wouldn't bother with the jig. All you need is a torpedo level.
Offline morts10n
« Reply #2 on: January 13, 2020, 08:03 PM »
A framing square is all you need
Offline Sparktrician
« Reply #3 on: January 14, 2020, 11:07 AM »
Just out of curiosity, @TheTechRunner, how did you join the sides to the horizontal components?  Dominoes?  Dowels?  [smile]
- Willy -
« Reply #4 on: January 14, 2020, 11:26 AM »
Dominoes of course! These ones are screwed in also because I didn't want to wait for glue to try with clamps but the ones on my honey do list will not have screws.
Sent from my SM-G950U using Tapatalk
« Reply #5 on: January 14, 2020, 07:37 PM »
I hoped so!  Good stuff!!!  I sometimes use hidden pocket screws along with dominoes to hold things together as the glue sets up.   [smile]
- Willy -
Offline gunnyr
    • Compass Custom Creations
« Reply #6 on: January 14, 2020, 10:11 PM »
Nice looking cabinets!  Here's a link to the Kreg Drawer Slide Jig manual
The description clearly states the jig can be used with both Frame and Frame-less cabinets.  Lots of ways to install drawer slides, this is certainly one of them!  Worth $25 to try IMHO.
Semper Fi,
Jeff
TS 55 REQ|HKC 55|PSB 420|DF 500|ETS EC 125/3 EQ|ETS 150/3|DTSC 400|RO 90|RO 150|OF 1400|MFK 700|LR 32|MFS 400/700|CXS (2)|PDC 18|DWC 18-4500|CT MIDI|CT 26|CT 48|MFT/3 (2)|VAC SYS-SET|DUO-SET|SYSLITE KAL II
« Reply #7 on: January 14, 2020, 10:21 PM »
Thanks for the link! The problem I see me running into is I have that cross member separating cabinet area and the top drawer. I think that stops me from using their standard frameless instructions. Maybe I'll just send my 5 year old into the cabinet and make him hold it lol
Offline Bob D.
« Reply #8 on: January 15, 2020, 06:37 AM »
Set the drawer jig below the rail and cut a spacer of the required height from a couple plywood scraps.
Or make your own jig based on the Kreg design and notch out for the rail so you can set the jig below the rail but reach up behind it to support the drawer slide.
« Reply #9 on: January 15, 2020, 08:25 AM »
Well then. I was definitely overthinking that haha. Thanks for the idea!
Online SRSemenza
« Reply #10 on: January 15, 2020, 12:03 PM »
You could also just cut a square spacer from plywood. Make it the height from the inside cabinet floor to what ever height the bottom edge  of the slide needs to be. And front to back so that it fits inside your frame. Based on the pictures this would be a piece about 20" x 20".
Then just place inside the cabinet against the side. Set the slide on the top edge, drill and screw in place. You can use  a clamp , small screw or brad to keep the spacer from tipping over if need be.
