Author Topic: Knipex Pliers -- Made in Germany -- High-End Quality Tools  (Read 4958 times)
Offline ChuckM
« on: December 05, 2017, 08:01 PM »
Newer version:
Offline Gregor
Re: Knipex Pliers -- Made in Germany -- High-End Quality Tools
« Reply #1 on: December 05, 2017, 08:37 PM »
Yep, they make nice things at good quality.
Offline SRSemenza
« Reply #2 on: December 06, 2017, 12:14 AM »
Yes, I've recently become somewhat hooked on Knipex pliers.
Offline Alex
« Reply #3 on: December 06, 2017, 02:42 AM »
Very fond of them, I got quite a few. Very good.
Offline Sparktrician
« Reply #4 on: December 06, 2017, 08:51 AM »
Knipex got a good grip on my wallet a long time ago...   [big grin]
- Willy -
Offline ChuckM
« Reply #5 on: December 06, 2017, 09:21 AM »
Someone has just brought this to my attention: NWS Slip-Joint Pliers, also made in Germany.
I Googled and found this:
« Last Edit: December 06, 2017, 10:11 AM by ChuckM »
Offline ben_r_
« Reply #6 on: December 06, 2017, 12:21 PM »
Got a couple of their Cobra pliers. Nice stuff.
Offline ManipulatingWood
« Reply #7 on: December 06, 2017, 02:26 PM »
Knipex also makes a ratcheting pliers wrench that I've grown quite fond of.  Smooth wrench jaws that don't mark up the surface of whatever you're working on.  I've been using a friend's pair, but am hoping that Santa leaves one under my Christmas tree [big grin]
« Last Edit: December 06, 2017, 02:30 PM by ManipulatingWood »
Offline SRSemenza
« Reply #8 on: December 06, 2017, 08:26 PM »
Interesting. Very clone like. It is a toss up on the thickness. Depends on the steel quality as to which is stronger. But Knipex uses good steel so I think I prefer the thinner  for better access.
Also Knipex makes a quick set version in the 250 size. That slides closed like the NWS.
« Reply #9 on: December 06, 2017, 08:27 PM »
These are great! Cut hard wire up to 4mm. Mild steel up to 5.2mm with a very compact tool.
Offline SRSemenza
« Reply #10 on: December 06, 2017, 08:33 PM »
Yeah, the Pliers - Wrench is nice too!  They have recently added a bent/ angled/ offset version to the line.
« Reply #11 on: December 07, 2017, 09:56 AM »
Thanks to this post and @ChuckM , I was at Menards last night and just had to pick up a pair of these. I especially like the thin jaws  [thumbs up] and the self locking feature.  [cool]
The jaws are less than 1/4" thick, .235" actually.
I already have several of their wire cutters so this was an easy decision.
Offline Peter_C
« Reply #12 on: December 07, 2017, 01:49 PM »
I have had a pair of the Knipex slip joint (If you can call them that, since they lock?) pliers since around 1997. They were used almost daily and are still my go to pliers. Barely any wear on the teeth, nor the soft grip handles, which shows how high of quality the steel is. On par with Snap-on, which I rarely will offer as a comparison.
Offline Trevin
« Reply #13 on: December 07, 2017, 02:53 PM »
I agree with you Michael Kellog!  I love these little cutters.  Just used them this morning to cut some little bolts...
Trevin
Festool: MFT3 (x2), OF1010, OF1400, LR32, Domino DF500, Domino XL DF700, Kapex KS120, TS-75, Carvex 420, CXS, C-18, Vecturo OS 400, DTS 400, Pro 5, Rotex 125, VAC-PMP, VAC-SYS-1, VAC-SYS-2, CT-26 (x2), CT-SYS, SYS Light DUO, SYS-ROCK
Other: Minmax FS41, Sawstop PCS (3HP, 52"), Laguna BX14, Jet 17" Drill Press, Rikon 70-220VSR Lathe, Incra LS Router Station, Laguna P/Flux 3 Dust Collector
Offline estley
« Reply #14 on: December 07, 2017, 10:18 PM »
i also have a knipex habit at this point, all excellent, but the wrench pliers are by far my favorite pliers.
Offline demographic
« Reply #15 on: December 08, 2017, 01:27 AM »
NWS do some very nice compound action end cutters, great for snipping nails upto about Paslode framing nail thickness (3.1 mm if I remember right)
Also VBW make some pliers and snips of excellent quality.
Both German companies if that makes any difference.
Offline SRSemenza
« Reply #16 on: December 12, 2017, 12:01 AM »
Got the two big ones today plus a couple Wera items.  [smile]
« Reply #17 on: December 12, 2017, 12:23 AM »
Couldn’t resist the urge, could you... [poke]
Offline SRSemenza
« Reply #18 on: December 12, 2017, 12:31 AM »
    Nope.
    Headed out to work on the water main now  [eek]
Offline Huxleywood
« Reply #19 on: May 31, 2018, 05:11 AM »
I like Knipex for water pump pliers and their pliers wrench but prefer NWS for electricians type pliers, they just feel better in my hands.  Both are high quality and are worth the price if you use them and/or appreciate good tools.
