I was lucky enough to have bought the OneWay adjustment tool with the dial indicator back in the dark ages of my woodworking career. It’s got a dial indicator so bad that Harbor Freight would be embarrassed to sell it, but it’s adequate for this job. I used it to initially ascertain the out feed table, the helical cutter head, and the infeed table near the cutter head were all coplaner with the outfeed table. They were and that helped. I emphasize that using a dial indicator makes tool adjusting incredibly easier as you see in rear-time the effect of the adjustment. The best advise I got was leave the outfeed table alone if it’s coplaner with the cutter head. So, a mount for a dial indicator, a 48”or longer truly straight edge, and a good manual and a large pot of patience are all you need to true up a big tool.
I expect to do this chore again so I made a better straight edge hold down and purchased a Mitutoyo dial indicator of thr OneWay Tool. I also too pics each step.
The test cuts are all straight. Big relief.
