« Reply #4 on: April 24, 2018, 04:41 PM »
Jessem had some distribution problems a few years ago -
And for a few years virtually “disappeared” from the U.S. market.
Thankfully they came back - ‘Cause their router table stuff is solid/terrific.
I coupled my Jessem Master Lift Excel II with a PC7518 - Mite-R-Slide, Jessem table and stand - The works. Love it.
Sounds like you’ve got an even better set-up going. ALL JESSEM.
I strongly recommend adding Jessem’s Clear-Cut Stock Guides.
I wouldn’t be without ‘em.
« Last Edit: April 24, 2018, 04:46 PM by Joe Felchlin »
FESTOOL: CT26, CT33 E HEPA Dust Extractors, MFT 1080, MFT-3, TS 55 REQ-F-Plus USA, TS75 EQ, Guide Rails: 1080's/1400/3000mm, LR 32-SYS/Holey Rail, Parallel Guides & Extensions, Plunge Routers: OF1400 EQ & OF1010, Sanders: RO125 FEQ Rotex, LS 130 EQ Linear Detail, DX93E Detail, Drills: PDC 18/4 Li QuaDrive Cordless Drill Set, C12 Cordless, CXS Cordless Compact Driver, SYS-Centrotec-Set, Dominos: XL DF 700 EQ Plus Tenon Joiner Set, DF 500 Tenon Joiner, VAC SYS: System Set, SE 2, Accessory Set | WOODPECKERS: DF 500 Offset Base System | BOSCH: 5412L Compound Miter Saw, 4100-09 10-Inch Table Saw | POWERMATIC: 60HH 8" Jointer, PWBS 14" Bandsaw w/Riser Block | MAKITA: 2012NB Bench Top Planer | JESSEM: Mast-R-Lift XL/Fence/Slide, Rout-R-Plate/Table Stand | RIKON: 50-120 6inX48in Belt-Disc Sander | JET: JBOS-5 Benchtop Oscillating Spindle Sander | PORTER CABLE: 7518 and 690LVRS Routers, 557 Pro Plate Joiner, 16/18/23 Gauge Nailers | LEIGH JIG: D4R 24 Pro Dovetail Jig, | LIE-NIELSEN: Almost every hand plane | DOWELMAX: 3/8" and 1/4" | KREG: K3 Master System | FEIN: Multimaster FMM 250 Q Kit | TORMEK: Super-Grind 2000 | DUST DEPUTY: Industrial (ALL) Steel Deluxe Cyclone (2)
