Author Topic: Infinity Cutting tools: SawStop Zero Clearance Throat Plate  (Read 1102 times)
Offline miclee15
I received my PCS last week and realized I need a few zero clearance plates.
Does anyone have opinions on the infinity throat plate?  Seems like a good idea as the Sawstop plates are $49 each.
Offline rmhinden
Re: Infinity Cutting tools: SawStop Zero Clearance Throat Plate
« Reply #1 on: August 08, 2019, 05:12 PM »
There is a discussion of this in the Facebook Sawstop group.  Also on Dan Thomas's blog:
https://thenewbiewoodworker.com/2019/07/05/infinity-throat-decision-status.html
My take is that the Infinity isn't a good solution for my Sawstop PCS.
Also, a thread on someone who modified the Sawstop insert.  See:
https://sawmillcreek.org/showthread.php?227675-DIY-SawStop-Replaceable-Zero-Clearance-Insert
Bob
Offline miclee15
« Reply #2 on: August 08, 2019, 08:55 PM »
Thanks for the links
Offline Bugsysiegals
« Reply #3 on: August 13, 2019, 05:48 PM »
Bob
What exactly was it you didn't like over the stock plate?  I'm curious because I recently installed the Infinity and don't have any complaints at this point.
Offline rmhinden
« Reply #4 on: August 13, 2019, 08:58 PM »
I am avoiding it because of the problem that Dan Thomas reported, and some other reports I read about the removable inserts not being consistent.
Glad to hear it is working for you.
Bob
Offline miclee15
« Reply #5 on: August 13, 2019, 09:39 PM »
So I had to call Sawstop on other questions and asked about the insert.   The problem. Have is that the back is recessed so when cutting thin stock it gets caught.  The service rep said he recommends using the dado blade and cut the back for the knife.   I just bit the bullet and ordered a Sawstop one.  I found 2 layers of painters tape work great in the recessed area.
