Author Topic: Incra LS positioner mounting.  (Read 1364 times)
Offline Sparky
« on: July 24, 2015, 02:26 PM »
Ok so I have decided it time for a router table. I can either build a bigger extension wing in my sawstop pcs with 36" fence or I can build a separate table. Because of the clearances needed for the incra ls positioner I am not sure if it makes sense to put in wing. If I build a table was thinking about also being able to use as a outfeed table also but wondering in anyone has came up with a quick way to pull off the positioner fence like maybe using bench dog hole??? Any ideas would be great as I am just starting to plan this out as I am confined to the house and not very mobile yet from surgery.
Ct 36, Ets 150/3, OF1400, Lr32 Set, domino 700 set, hl850, ts 75,Dts 400, kapex
Offline irishman
Re: Incra LS positioner mounting.
« Reply #1 on: July 24, 2015, 03:03 PM »
I have but a custom extension for mine on the side of my tablesaw.  I mounted my LS positioner to a 3/4" plate and that plate mounts to the router table with T-tracks.  Keeps it easily removeable and out of the way.  most times for what I need I just use the tablesaw fence, but for repeatable precision, I breakout this setup.
Offline Sparky
« Reply #2 on: July 24, 2015, 03:16 PM »
Any chance you could post some pictures when you get the chance? Would love to see pictures from several people :-)
Offline SRSemenza
« Reply #3 on: July 24, 2015, 05:57 PM »
   If you've got room for the separate table, then go that way. Keeps everything in full ready mode all the time and no fiddling if you want both set up at the same time.
