Author Topic: Impact Driver  (Read 5221 times)
Offline Bhend18
    • Hendricks Construction
Impact Driver
« on: January 17, 2014, 11:03 PM »
This question is mainly for people outside of NA. Did Protool make an Impact Driver/Drill? If so, did that model get rebranded by Festool? I'm not sure if I'm sold on the TI 15. I was just wondering if you guys had another option over there.
Domino DF 500, CT 36 E, Boom Arm Set, CT MIDI, OF 1400, LR 32, FS 2424/2-LR 32, FS 1400/2 LR32, TS 55 REQ, TS 75 EQ, HKC 55 EB, FS 800, FS 1080, FS 1900, FS 3000, FSK 250, FSK 420, Parallel Guide Set, MFT/3, Kapex KS 120, Kapex UG, CXS, PDC 18/4, Drilling Dust Nozzle, CMS-GE, Carvex PS 420 EBQ, Pro 5 LTD,RO 90 DX, RO 150 FEQ, RTS 400 REQ, RS 2 E, LS 130 EQ, RAS 115 E, HL 850 E-F Plus, MX 1200 E EF, CT Wings, Vecturo OS 400, SysLite KAL-2, SYSRock
Offline neth27
Re: Impact Driver
« Reply #1 on: January 18, 2014, 01:58 AM »
There is no Protool impact driver.. just drills and impact wrench.
John..
Offline neeleman
Re: Impact Driver
« Reply #2 on: January 18, 2014, 03:23 AM »
Protool did have 2 Impact drivers called IDC15-2 and IWC18-2.
They were discontinued before the PDC/DRC models were converted to Festool models.
Why they stopped selling it I don't know.
The 14,4V range of Protool has been discontinued a 1-2 years back already. That I also don't understand.
While the IWC18-2 model was even upgraded tot the latest models.
Festoolian since 1998.
FESTOOL:
OF1010R | AGC18 | TPC18/4 | TID18 | OSC18 | RTSC400Li | CTL MIDI I | SYSROCK BR10 | SYSLITE KAL II | SV-SYS D14 | DSC-AG125FH | CDD9.6 | SYSLITE DUO | DF700 | HKC55 | TXS2.6 | CTL SYS | CXS2.6 | DWC18 | CTWings | BHC18 | CS50 | CMS-OF | MFT/3 | MFT/3-VL | KS120 | TS55 R | PSC420 | PS420 | BS75 | RAS115 | RO90 | RO150 | RS400 | RTS400 | RS300 | LS130 | DX93 | ETS150/5 | ETS150/3 | OF1400 | OFK500 | MFK700 | T18 | EHL65 | CTL26 | CTL22 | WCR1000 | D27-AS Plug-it | D36 UNI-RS | D36x7 | D50x2.5 | FS800 | FS800/2 | FS1080/2 | FS1400/2 (2x) | FS3000/2 | FSK250 | FSK420 | Gecko Dosh | Toolie | CE-SYS-2010 | RB-SYS CART (2x) | LEV1400 | LEV350 | SYS-MFT
PROTOOL:
CHP26 | VCP260 | DSC-AGP125 | DSC-AGP230 | DSG-AGP125 | DRP16
Offline jmbfestool
Re: Impact Driver
« Reply #3 on: January 18, 2014, 03:30 AM »
Impact wrenches
 Not really impact drivers
*********************************************************************** [thumbs up]UK members click me
Offline neeleman
Re: Impact Driver
« Reply #4 on: January 18, 2014, 05:02 AM »
Yes you are right.
There is a lot confusion about the terminology between Impact Drivers and Impact Wrenches.
I made the same mistake.
Both Protool machine have 1/2" connection for using sockets and that makes it most often a Wrench.
There is also a 1/4" connection for using bits inside the socket connection and you can also use a Centrotec chuck CC-IP which differs from the standard one because it fits over the 1/2" socket.
« Last Edit: January 18, 2014, 05:16 AM by neeleman »
FESTOOL:
PROTOOL:
Offline Caly
Re: Impact Driver
« Reply #5 on: January 18, 2014, 08:26 AM »
Impact drivers totally band on my site.......too much headache and cant see the point.............
Offline neth27
Re: Impact Driver
« Reply #6 on: January 18, 2014, 11:37 AM »
The point is they are a lot better than cordless drills at putting in large screws, concrete screws etc. They also don't have the habit of trying to snap your wrist like a powerful cordless drill would.
John...
Offline TelcoRandy
Re: Impact Driver
« Reply #7 on: January 18, 2014, 01:23 PM »
They both serve a purpose, impact drivers have less strain and more torque.
Drills are quieter and can screw faster than an impact drill. Eventhough impact drills have high RPM, they have to do 1 full rotation to engage the hammer, and when the hammer hits your bit it is quickly absorbed and almost never does a full 360 degree turn. Thankfully they're usually high RPM/BPM but they're still slower than a drill.
Offline Holz-Her
Re: Impact Driver
« Reply #8 on: February 02, 2014, 04:44 PM »
The customers either picked up the 10,8 Volt or 18 Volt version i was told. So they ditched the 14,4 Volt line.
