Author Topic: Hole saws- which one is the best  (Read 11290 times)
Re: Hole saws- which one is the best
« Reply #60 on: September 04, 2020, 12:35 PM »
Offline TinyShop
« Reply #62 on: September 05, 2020, 04:54 AM »
I'm surprised no one has suggested an adjustable circle cutter:
https://www.starminfo.com/en/product/jizai/36t.html
Assuming there's no need to work in a tight space, seems a circle cutter offers all kinds of versatility. Plus, there's the option of HSS, carbide or even diamond.
Star-M even makes a range of tool-free versions:
What do folks think of a single circle cutter in place of an entire set of holesaws?
« Last Edit: September 05, 2020, 05:27 AM by TinyShop »
ETS 150/5 EQ (DE) [po], TS 75 EQ (DE) [po], OF 1400 EQ-F (DE) [n], CXS (DE) [n], CMS-GE [DE] [po], CMS TS 75 (DE) [n], LA-CS 50/CMS (DE) [po], VB-CMS (DE) [n], MFT/3 (CZ) [n], DF 700 EQ w/Seneca Small Mortise Kit (DE) [po], FEIN Multimaster 350 QSL (DE) [n], Bosch 1274DVS w/dust collection, sanding frame,  stand & fence (CH) [n], BOSCH 1590EVS w/dust collection (CH) [n], CS Unitec CS 1445 HEPA extractor <re-branded Starmix ISP 1435 H> (DE) [n], CT SYS (DE) [po], Milwaukee 0302-20 (US) [n], Two (2) Porter Cable 862 (TW) [n], Porter Cable 447 (US) [n], Zyliss Vise (CH) [nos], Hitachi C 8FB (JP) [h], Walko 4 MKII (NL) [nos], Festool MFS 400 w/add-on 700 profiles & router slide (DE) [n]
[po] pre-owned   [n] new   [nos] new old stock   [h] heirloom   (XX) country of origin
Offline SRSemenza
« Reply #63 on: September 06, 2020, 12:32 AM »
 I never used one but they always look like they would be hard to control. Maybe not?
 I think the biggest drawback would be the size. And swing radius. I have already used several of the hole saws I just got near walls and cabinets where that would never have room.
  Can those be used without the center bit (on a drill press)?  If not then they would not work for making round disks without a center hole.
  I also can't imagine the cutter working well on a 90 degree angle head. Might work but seems awkward and maybe even risky to a hand in the wrong place.
 The pro of course is that it is one cutter that can make any size in the range.
        In my case if I had a circle cutter I would still end up with a set of hole saws. But I think it depends on the users intended cutting purpose.
Offline aloysius
« Reply #64 on: September 06, 2020, 04:03 AM »
I honestly don't think there's a "best hole-saw".  Just the best for the job.  Working at a remote location (250 KM from base) I had a series of downlights to install in Hardieflex.  A colleague's holesaw enthusiastically cut exactly 3 holes before it stopped cutting. I then (carefully) managed 7 before mine was too blunt to use.  Both were new & expensive bimetallics:  Sutton & Sandvik from memory.
If we'd been using Carbide gritted saws instead, the saw would've laughed at the task (20 odd lights) & shown virtually no wear at all.  Unfortunately, we weren't aware that we would be drilling fibre cement, & had no access to the "right" material saws.
Yet I've cut 3" holes with the same well-lubed Sandvik bimetallics in structural steel girders!  Slow & steady works well here.
TCT saws seem to work well in synthetic board, yet tend to burn their way through natural hardwood.  A simple auger (<50mm) works best here.  Expanding-wing augers in a simple old-school handbrace can be remarkably effective in hardwood too, but blunt quickly in synthetics.
Diamond gritted saws & cores work best in concrete, masonry & certain softer marble, limestone, sandstone & ceramic tile.  Water is the best lube & cooling medium here.
I've never really found much diff between any of the particular "brands" that I've used over the years, but admittedly they've always been fairly expensive quality brands:  Marcrist, Husqvarna, Lennox, Sandvik/Bahco, Sutton et. al
I've also noted that others seem to try to spin larger holesaws in any material way too fast to cut effectively.  A big, powerful, high-torque power drill or the very best cordless money can buy is needed to turn a large diameter holesaw at the correct (low) speed.  Years ago, that for me was Bobbie Bosch 1500w (2 HP) corded or 36V cordless drills, both fitted with extra-long auxiliary handles for safety.
FOG-wit since '95:  Some say since birth...
Re: Hole saws, Starrett Quick Change
« Reply #65 on: September 07, 2020, 11:04 AM »
Here's an interesting quick change system for swapping out different sized hole saws if that's what you're up against.
A Starrett A-6 quick change chuck that's available in hex or SDS drive.
From Starrett:
Fast, tool-free changes between different sizes and types of Hole Saws and Pilot Drills. Provides a simple method for core ejection and hole enlargement. A6 Kwik Change Chuck for use with Hole Saws up to 6"/152mm diameter.
A quick change adapter that's available in 1/2-20 or 5/8-18 to fit all hole saw diameters from 14 to 152 mm.
Just attach the adapter to the required hole saws and with the push of a button you can swap out the holes saws instantly.
« Last Edit: September 07, 2020, 11:14 AM by Cheese »
