Author Topic: Hammer N4400 on the way!  (Read 4387 times)
Offline mattbyington
« on: February 12, 2020, 01:05 AM »
Decided the A331 was getting lonely!
It’s crated up right now in Sacramento. Very excited.
Matt
Online vkumar
Re: Hammer N4400 on the way!
« Reply #1 on: February 12, 2020, 01:31 AM »
Nice.  Congratulations Matt.
Vijay Kumar
Offline Bert Vanderveen
« Reply #2 on: February 12, 2020, 04:36 AM »
I bought both at the same time… : ) No regrets! Just joy!
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 Mk2 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 EQ · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · Kapex KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set (next June!) … | Mirka 1230L P&C | Hammer A3 31 Silent Power · Hammer N4400 · Hammer HS950 | TaigaTools VacPods Pro Set
« Reply #3 on: February 12, 2020, 01:05 PM »
Thanks Guys! Super excited. It is being delivered tomorrow!
Matt
Offline pierwood
« Reply #4 on: February 12, 2020, 05:57 PM »
Nice!
What accessories did you add?
« Reply #5 on: February 12, 2020, 08:14 PM »
@pierwood I did get the miter gauge and I picked up a nice Lenox Woodmaster blade for resaw (The N4400 does not ship with a blade).
I, of course, got the X-Ceramic (or whatever they call it) bearings - I've heard mixed reviews. They recommended it. We'll see.
I'm not really aware of any other accessories other than table extensions which I won't get (I am very limited on space).
Are there others I'm missing?
Matt
Offline egmiii
« Reply #6 on: February 12, 2020, 10:49 PM »
Did you get the 1” Woodmaster CT carbide blade? I’m not sure if the N4400 can tension that blade properly.
« Reply #7 on: February 13, 2020, 12:44 AM »
@egmiii ahhh no:( thank you so much for the heads up. That is the one I got.
Would you be willing to educate me on the best Resaw / straight cut blade? I know very little about bandsaws.
Shoot. Wish I asked first.
Matt
Offline derekcohen
    • In The Woodshop
« Reply #8 on: February 13, 2020, 05:43 AM »
Mine certainly does. Excellent blade. I am onto my second.
« Reply #9 on: February 13, 2020, 10:02 AM »
Thanks Derek! So maybe it’s okay.
Offline John1102
« Reply #10 on: February 13, 2020, 03:06 PM »
Matt,
Which bandsaw models were you considering and what led you to choosing the Hammer N4400 in the end?
Offline ben_r_
« Reply #11 on: February 13, 2020, 04:41 PM »
Nice! Got the A3-31 and N4400 combo myself and love it! Both from the Sacramento location too! Did yours come with the stainless bar that the fence mounts too or is it black steel?
« Reply #12 on: February 13, 2020, 07:10 PM »
@John1102 I was considering:
PM1500
Laguna 14 or 18"
I was really really leaning towards PM1500 since I've heard terrible things about Laguna's customer service.
However - once I figured out Hammer / Felder sold bandsaws - the really nice thing is that since I already have an A3 31 jointer/planer, I can do maintenance at the same time if I need to have anyone come out, the machines match each other, I'm already familiar with their reps and folks, tools, motors, I'm very happy with the service I've received, etc etc.
I am sure the PM1500 would have been great, too. But why not stick with a brand I know I love and trust based on the A3.
Aaaaaand at that folks, it was just delivered 30 minutes ago!
I had to jet back to work real quick - so, @ben_r_ I shall know the answer to your question in the next 12 hours or so when I get it uncrated :)
We had to take it off the pallet or it wouldn't fit in the garage.... looks to be a beast. Can't wait to get it set up.
Matt
Offline SouthRider
« Reply #13 on: February 13, 2020, 07:37 PM »
Check out Highland Woodworking for great info about re-sawing.
https://www.highlandwoodworking.com/bandsaw-blades-accessories.aspx
I bought a fairly expensive wide blade when I first bought my bandsaw (following traditional advice). Never could get it to work right. Bought the 1/2" blade from Highland, followed their video advice, and re-sawing is now no big deal. Now I'm not making paper thin veneers or violin cases, but for general use I love their system.
"We, the willing, led by the unknowing, are doing the impossible, for the ungrateful. We have done so much, for so long, with so little, that we are now qualified to do almost anything, with nothing at all."
Offline derekcohen
    • In The Woodshop
« Reply #14 on: February 14, 2020, 05:28 AM »
Matt, here are some modifications/accessories to consider for the N4400. I have had mine about 10 years. It is a single phase, 4 h.p. motor running on a 20 amp circuit.
1. This is a CNC-made aluminium insert, replacing the plastic one which warps.
2. Another CNC-made item, a mitre gauge ..
The N4400 has an atypical slot - it is much shallower than all others. I found that I could use a cheap F-clamp blade with a minor amount of side sanding ...
3. I attached a steel ruler to set the fence ...
4. I began developing a re-saw fence by attaching a high subfence made from MDF (waxed) ...
This slides onto the main fence via a groove, and was held in place by a friction fit. It now has a threaded bolt.
Several months ago I modified this fence with a design of mine that I am happy to discuss later. In brief, it avoids problems with kerf expansion by using a shortened fence ...
From the rear ...
This is a Jarrah board re-sawn using a 1" Lenox Woodmaster CT blade ...
5. Dust control is via a pipe underside ...
This should keep you out of mischief for a while  [big grin]
Offline Lbob131
« Reply #15 on: February 14, 2020, 02:45 PM »
I like   the dust  control  method.
I have  the  N4400 also.
Offline Ambrosia
« Reply #16 on: February 14, 2020, 05:58 PM »
I’m very happy with my N4400 but found the table a bit small. I used some scrap flooring to make a larger surface.
BTW, the overhead dust extraction (orange nozzle) doesn’t really work If you were wondering. I enlarged the standard cabinet port slightly so that it’s the size of the plastic hose adaptor, and dust control is not great but adequate for what I do.
Leigh
Offline derekcohen
    • In The Woodshop
« Reply #17 on: February 14, 2020, 07:44 PM »
Leigh, I recognise both your bandsaw and mitre gauge! :)    Note that I replaced the blade in my mitre gauge. The aluminium one that came with it is too short and creates limitations on the width of the board for cutting. Use a blade from a cheap F-clamp.
Dust control with the “pipe” is very good. Bandsaws are difficult to set up for dust extraction, and this method is the best I have found.
A larger table is a personal matter. Hammer (Felder) do offer extensions for the N4400. I have this for the A3-31, and never needed the extra length. So it lives on my K3 slider. Here it is on the A3-31 ..
I have not felt a need for extra table width with the N4400, however have wanted greater length. My solution, in place of the Hammer extensions, which I thought to be too costly when I purchased this bandsaw 10 years ago, was to add on a roller (I think that this one was designed for a drill press) ...
« Last Edit: February 14, 2020, 07:50 PM by derekcohen »
« Reply #18 on: February 16, 2020, 12:28 PM »
@SouthRider thanks! I might get a couple different blades. We'll see.
@derekcohen wow, thank you so very much for such a detailed post! It took me a little while to read and understand it. So many cool things in there. The scale is something definitely missing in my opinion from the bandsaw. I'd like to do inlay work making 1/8 or 1/4 wide strips of exotics to inlay. My plan was just to use the router bit itself between the blade and the rip fence, which I probably still will do. But the scale is great and can't hurt.
I've also heard the dust extraction isn't the best so I might do something similar to what you've got going on here too.
@Ambrosia nice! I don't have space for that but if I did, would be awesome!
Thanks everyone for the great replies!
On Friday evening I finally got the thing off the pallet and onto its (barely strong enough) mobile base. I use a PM 3500 for the A3, but unfortunately, it doesn't go small enough for the N4400 and I didn't want to cut the rails by hand.
So, I got the 2500 which is rated for 650 pounds. It works great so far.
the only issue I've had is the Brake gets in the way of the casters. I don't want to mount the casters on the side of the base since I like the streamlined look and space saving.
Has anyone removed their brake? The big yellow metal bar. I might.
Thanks!
Blade comes Thursday...can't use it until then :( patience is hard!
Matt
Offline derekcohen
    • In The Woodshop
« Reply #19 on: February 16, 2020, 05:58 PM »
Do all the N4400s have an external brake in the USA? In Australia, and I assume Europe as well, the brake is internal/automatic.
Offline Bernmc
« Reply #20 on: February 16, 2020, 06:31 PM »
I noticed the US mechanical brake thing when I was reading through the N4400 manuals before getting mine.
The ROW models brake by injecting DC into the motor - I wonder whether there's some sort of US legislation that prevents this, or the puny 110V you have over there can't handle it?
Online Rob Z
« Reply #21 on: February 16, 2020, 07:02 PM »
Derek, nice work with all the mods made to your N4400.
Bernmc, the N4400 is shipped here to run on 230v.  I haven't made a big study of bandsaws, but what I have seen is some times a particular model is available with the foot brake and also (for an upcharge) an electric brake.  My N4400 had a foot brake but I don't recall if an electric brake was an option.
Offline Ambrosia
« Reply #22 on: February 17, 2020, 03:54 AM »
Derek - I see your point with the mitre gauge extension. Will look into that.
I’m about 50 years practice away from your skill level and projects - I mostly cut shapes out of cheap plywood, hence the need for a larger cutting table area. One day I hope to resaw rare and valuable timbers, but right now I feel it would be a bit of a waste!
Leigh
Offline SouthRider
« Reply #23 on: February 19, 2020, 05:35 PM »
Matt -
My Rikon has a similar brake - I wouldn't live without it. The momentum from large diameter cast wheels can keep that blade spinning for a long time after the saw is off. Someone else mentioned electronic or magnetic brake - sounds great (and expensive). I don't recommend removing the mechanical brake - I use mine every time (I like my fingers, and those of my guests too).
I wasn't recommending Highland for you to buy a blade, but to learn how to re-saw. Their setup and use videos made the whole process simple and easy for a newbie to a bandsaw like I was at the time. Great info on setting up for blade drift too.
Offline Bernmc
« Reply #24 on: February 19, 2020, 07:29 PM »
Electronic brakes are standard on AU/European models, and the mechanical is not an option.
Interestingly, I think the same applies to Fe$tool's QF1400 - ours has an electronic brake, but I don't believe that the US flavour does.
« Reply #25 on: February 20, 2020, 12:08 PM »
@SouthRider got it. I'll keep it then. Thank you.
Blade comes today. Super excited to power it on for the first time tonight.
I ended up getting the 1" Lenox CT
Matt
« Reply #26 on: February 29, 2020, 08:33 PM »
Hey team! Looking for some advice.
I switched to a thinner blade : I’m using a Lenox 3/4” classic bi-metal blade with 3  TPI. I’ve only used the bandsaw 3 times so far as I just got it in. The rip cuts against the fence have left the edge pretty wavy and ripply. It takes 2 solid passes on the jointer to clean it up. I was hoping for smoother edges right off the bandsaw. I’m more than confident it is me doing something wrong here but figured I would ask. I’ve tensioned the blade according to the scale on the bandsaw, for a 3/4” blade. Thanks so much for any help.
« Reply #27 on: February 29, 2020, 10:46 PM »
Forget that scale. Tension by feel and you’ll notice that the scale is no help.
Offline RustE
« Reply #28 on: February 29, 2020, 11:20 PM »
Curiosity question:  Any featherboards to keep the wood in position?
Offline RKA
« Reply #29 on: March 01, 2020, 09:48 AM »
I’m thinking it’s either the tension or the fence isn’t parallel with the blade, but I’m no expert.  Here is a video Marc put together with Alex Snodgrass that should walk you through a quick and easy way to get everything set up.
https://www.thewoodwhisperer.com/videos/best-way-set-bandsaw/
-Raj
