Author Topic: Hammer N4400 - building a bigger table  (Read 8791 times)
Offline Michael_Swe
« on: March 31, 2013, 03:54 PM »
Hi.
I've seen that quite a number of FOG-members have the Hammer N4400 bandsaw. I'm very happy with mine, but the table is quite tiny. I ordered mine with the table extensions, but they didn't fulfill my needs. The extension table now lives permanently at my Hammer J/P.
The fasteners for the Hammer extensions was perfect for attaching my own table. Thought I'd share the project if anyone else is up for it..
I welded a frame
84669-0
Attached with the same brackets that came with the Hammer extension table.
84671-1
From the underside.
84673-2
Finished project.. Actually not *finished*. I'll probably oil the MDF as I have done with my other tops.
84675-3
/Michael
Offline Timtool
    • My website
Re: Hammer N4400 - building a bigger table
« Reply #1 on: April 02, 2013, 07:27 AM »
Nice one,
Indeed the stock table is really small, first thing i did with mine was to build an outfeed table about 1m long held with pegs, i can also place it on the side if i wanted to.
This way i can resaw boards up to 2-3m long without having to put my weight on them to keep em flat on the table!
BR10, MFK 700, OS 400, ETS EC 150/3, KA 65-plus,TS55R, CT22E, CTLmini, CTL MIDI, CTM 36 AC HD, Kapex KS120, ETS125, ETS150/5, RO150, RO90, CXS-set, T-15+3 set, DTS400, OF900, OF1010, OF2200 set, Carvex PS420 EBQ set, EHL 65, SSU 200, Centrotec installer set, LR32-sys, FS-800, FS-LR-1400x2, domino 500+domino sys, domino 700 XL, Surfix-sys, Sys-box 1, Syslite, LEV-350, Sys-box,MFTB/1-2-4... MFTC, MFSC
Offline Alan m
« Reply #2 on: April 02, 2013, 08:36 AM »
very nice
im thinking of doing this myself
but my bandsaw is beside the door and this would be in the walkway
iv been trying to think of a way to make it removable easily. there are no threaded locations like on yours
Offline ScotF
« Reply #3 on: April 04, 2013, 12:09 AM »
Nice one,
Do you have any pics of your set-up?
Scot
Offline ScotF
« Reply #4 on: April 04, 2013, 12:10 AM »
Michael,
Great idea...I wish I knew how to weld.  Really like the extra space and it seems like it does not interfere with the blade changes, etc...
Scot
Offline Jason Kehl
« Reply #5 on: April 04, 2013, 08:18 AM »
I know this question does not fit the thread directly, but to those of you who have the Hammer N4400; can it handle tensioning a 1' blade with no problems? I may get this saw but would use it mostly for re-sawing and my research indicates that a 1' blade is the go-to size.
Offline Michael_Swe
« Reply #6 on: April 04, 2013, 08:25 AM »
Here is some good info about this.
http://www.swedishwoodworking.com/articles/upgrading-the-blade-tension-spring-on-the-hammer-n4400-bandsaw/
I had a gas spring on order for a completely other project. After reading Mattias' article I added a new spring for my Hammer as well. The new spring was about 15 USD.
//Michael
Offline Jason Kehl
« Reply #7 on: April 04, 2013, 01:16 PM »
Thanks Mike, interesting article.
Offline ben_r_
« Reply #8 on: October 13, 2015, 01:50 PM »
Just took delivery of a brand new N4400 myself. Glad I found this thread I have been looking to do something like this myself. Links to images appear to be dead though. Any chance the OP could do a refresh on those or perhaps repost them?
Offline Michael_Swe
« Reply #9 on: October 13, 2015, 02:02 PM »
I don't know what could have happened to the images. I found one of them. I'll try to locate the other images and repost them as well.
Offline ben_r_
« Reply #10 on: October 13, 2015, 02:03 PM »
Thank you!
Offline Michael_Swe
« Reply #11 on: October 13, 2015, 02:15 PM »
Sorry, can't find them. I tend to not be very careful with those snap-n-post photos. If you'd like I can take some new photos. Is there any particular detail you are interested in?
Offline ben_r_
« Reply #12 on: October 13, 2015, 02:27 PM »
Shucks. Well that would be very nice of you if you could. I was most interested in your frame and how it attached to the bottom of the table as well as how you attached the wooden extension to the frame. Im wondering how I could create a similar style frame but with the wooden extensions somewhat easily removable so I could also build a longer narrow extension for circle cutting. Sort of to mimic the Hammer option:
Offline Lbob131
« Reply #13 on: October 18, 2015, 08:42 AM »
I use  two way sliding tables  on dado slots  made from mdf   to do large  dovetails  on my N4400.. Works really well and  fast..
The tuffsaw  saw blades have  a  nice thin kerf  which  helps the accuracy.
This is   the  pins set up..
This is the tails..
And the  finished product... Well not quite, some sculpting to do now  to make it look pretty..
« Last Edit: October 18, 2015, 08:59 AM by Lbob131 »
Offline ben_r_
« Reply #14 on: November 04, 2015, 05:08 PM »
OP: Never had a chance to retake those first pics?
Offline Michael_Swe
« Reply #15 on: July 03, 2018, 01:38 PM »
Hi there.
A few years later.. and I accidentally found some images on an old hard drive. Thought I'd upload them here if anyone is still interested.
Offline ben_r_
« Reply #16 on: July 03, 2018, 01:40 PM »
Hi there.
HA! Michael you Sir are awesome! I still havent built a table extension for my N4400, so these images will still help. Thank you!
Ah! And I see now you used the "L brackets" from the Hammer extension mounts. I dont have those so I was planning on going a different route. Something more like this that used the bolt holes under the table.
« Last Edit: July 03, 2018, 01:45 PM by ben_r_ »
Offline Ambrosia
« Reply #17 on: July 14, 2018, 08:58 PM »
Just to give an alternative approach...
I made four steel brackets that screwed into the four tapped holes on the table underside edge. Ripped some scrap to fit on top and shimmed the table top to level with some veneer. The table top is made of chipboard flooring.
Leigh
Offline ben_r_
« Reply #18 on: July 14, 2018, 09:01 PM »
I like it! That worked out very well!
Offline mattbyington
« Reply #19 on: March 02, 2020, 12:41 AM »
@Ambrosia do you recall the size of the bolts you used on the underside of the table? M10 maybe?
Matt
Offline Ambrosia
« Reply #20 on: March 02, 2020, 02:11 AM »
@mattbyington
Yep - M10.
Leigh
« Last Edit: March 02, 2020, 02:14 AM by Ambrosia »
« Reply #21 on: March 02, 2020, 12:36 PM »
@Ambrosia thank you.
Matt
