Author Topic: Hammer K3 Blade Height Adjustment Issue  (Read 836 times)
Offline patriot
    • Wood Working By Design
« on: July 28, 2019, 02:43 PM »
For some reason raising/lowering the blade on this table saw is difficult.  To lube, I raise the blade to its maximum height and then blow away all the sawdust from both shafts with my air compressor.  Once this is done I lube the height spindle, lower and raise and lube again.  Ditto for the tilting spindle.
The blade goes down easy enough, but raising it is somewhat difficult.  The mechanism also squeaks when the blade is raised.  The operation of the saw is perfect, so there are no problems whatsoever.  I think that the blade should not be this difficult to raise.  It seems as though I am compressing something when the blade is raised.  The saw was put into service in May 2017 so it is not that old.  That said, I do not recall how much muscle was required to raise the blade when it was new.  I think it was probably much easier than it is now.
Both spindles are clean of any debris or buildup of any sort.  So I'm thinking that something else needs to be lubed to elimate the squeaking and reduce the friction when the blade is raised.
Any comments or suggestions are most welcome.
(Off topic:  I am not receiving forum notifications, but check in frequently.   A moderator is trying to resolve this issue for me.)
'If you don't know where you're going, any road will get you there' Lewis Carroll
Offline Indywoodworker
  • My favorite woodworking companion
Re: Hammer K3 Blade Height Adjustment Issue
« Reply #1 on: July 29, 2019, 11:32 AM »
I read your post and also have a K3.  Have you tried contacting Felder's corporate HQ in Delaware?  My Sales Rep is Steven Taylor at 1 866-792-5288 x219.  He can put you in contact with the technical department and maybe they can be of assistance.  I found the technical folks to be very helpful over the phone.  Most of my issues with the K3 were in setup which I was easily able to resolve easily with a little guidance.
Offline patriot
« Reply #2 on: July 29, 2019, 02:27 PM »
@IndyWoodworker
Thanks for your comments.  How difficult is it for you to raise the blade on your K3?
Thanks!
« Reply #3 on: July 29, 2019, 08:16 PM »
I just tested my saw it is a solid cranking motion to raise and lower the blade.  It is firmer then my old Delta Unisaw.  But it did raise and lower okay.
Chuck
Offline SouthRider
« Reply #4 on: July 29, 2019, 10:13 PM »
I've been having the same problem on my 4-5 yr old K3. It used to operate "normally" like most other table saws. Now it takes two hands to get the blade fully raised. Like you I have inspected, cleaned, removed sawdust, and lubed as much as possible. I haven't taken the time to call them as I only think of it when I am away from the saw or on weekends.
Looking forward to an answer here!
"We, the willing, led by the unknowing, are doing the impossible, for the ungrateful. We have done so much, for so long, with so little, that we are now qualified to do almost anything, with nothing at all."
Offline patriot
« Reply #5 on: July 29, 2019, 11:06 PM »
@SouthRider
Thanks for stopping by.
Tomorrow I will call the number IndyWoodworker posted and see if they can provide any help.
Just as you said, it takes two hands to get the blade up and in my case, one hand to get the blade down.  This makes zero sense to me.  My height spindle is squeaky clean, so I don't get it.
Tomorrow I will call and post the results of that conversation.  Hopefully, they will have a solution that I hope can be fixed in our shops.  I do not want to have to have some tech work on my machine if I can help it.
Thanks again.
Offline patriot
« Reply #6 on: July 30, 2019, 12:29 PM »
To all:
I have a phone call in - was forced to leave a message - and also sent an email as well.
Will keep you posted.
Thanks!
Offline patriot
« Reply #7 on: July 30, 2019, 04:13 PM »
Chuck
Sorry I missed your post, but as I mentioned I am not receiving any email forum notices.
It appears from what you wrote that raising and lowering the blade requires the same amount of effort.  Raising my blade takes about five times the effort that it does to lower it.
I have sent off another email in hope of getting some help.  I think I will use the phone number you posted to see if I can get some help from your rep.
Thanks.
P.S.  I just left a message with your rep.
« Last Edit: July 30, 2019, 04:17 PM by patriot »
Offline patriot
« Reply #8 on: July 30, 2019, 05:13 PM »
To all:
I finally heard back from Felder.  I sent my original rep an email, but quickly learned he no longer works for Felder.  His replacement called me nearly immediately after I sent the email.  He has put me on the Service Dept. "list" and they will call as soon as they can.  Apparently there was a dealer show in Vegas and they are finishing up with that.
At any rate, someone has finally responded to me, so we'll see how it goes from here.
Will report back with whatever solution they come up with.
Thanks!
Offline patriot
« Reply #9 on: July 30, 2019, 07:50 PM »
To all:
Okay - here's the solution:  DENATURED ALCOHOL!
Dust off the height spindle with your air compressor and spray the spindle several times while raising/lowering the spindle.  I used quite a bit of denatured alcohol in a spray bottle with adjustable nozzle. (See my weapon of choice below.)
The tech told me that sawdust gets trapped (compressed) in the spindle mechanism which releases pitch/residue and this gums everything up. In addition, the squeaking has also stopped. DA is now my favorite Hammer K3 lube. [thumbs up]
Now we know.  Thanks!
« Last Edit: July 30, 2019, 09:48 PM by patriot »
« Reply #10 on: July 30, 2019, 10:24 PM »
Thank you for posting the solution.  I have seen denatured alcohol used for many applications.
Offline patriot
« Reply #11 on: July 30, 2019, 10:55 PM »
No problem.  I am VERY happy that this problem has been solved.
Take care.
