One of the other benefits of the TERSA cutter system is that there's a variety of blade alloys available, so you can match your blade composition to the wood/product you are processing. Off the top of my head, my memory is that the TERSA blades are available in HSS, M2, Chrome Steel, Carbide, and NaDia diamond coating, and I'm sure I'm forgetting some. Some blades are better suited for hardwoods, others for softwoods, others are well suited to processing dirty/gritty lumber which might damage/knick the knives.
As MikeGE points out, blade change takes about a minute or so.
I've also heard of users getting rather creative with their blade selection, using two or three blade styles on the same head to get the best qualities of different blade alloys.
I've also heard of users using shorter sections of TERSA blades and setting up their cutter block in sections, for instance the far side of the cutter block is set up with blades better suited for softwoods or dirty/rough lumber, while the near side of the head is loaded with blades better suited for long runs of hardwood.
Again, I'm currently enjoying my Felder Silent Power cutter block in my Hammer A3-41, it's a great cutter, but for more commercial/industrial applications the TERSA systems seems to have some advantages.
