Author Topic: Hammer A3 31 dust collection, is 1250 CFM dust collector good enough?  (Read 1896 times)
Offline lshj
I recently just ordered a Hammer A3 31 jointer planer combo due to good discount, will get it in December.  I have just bought a Dust Right wall mount 1250 CFM dust collector with canister filter from Rockler, and connected to a Oneida dust Deputy 4" Deluxe. I bought the dust collector for the Laguna 14BX bandsaw that I ordered but it's on back order and I have no idea when I could get it.  I have tried the 1250 CFM dust collector and it seems to have good suction and less noisy than my Ridgid shop vac although I have no machine to connect yet.
Just read a review saying that the 1250 CFM dust collector is not powerful enough for his 12" jointer.  The A3 31 is a 12" jointer planer combo, I am wondering any A3 31 owners have tried to use it with similar strength dust collector around 1250 CFM? Is this good enough? I have never owned a jointer or planer before so this is my first jointer.  I choose the jointer/planer combo because of limited space in my small garage. I choose Dust right wall mount dust collector because it takes less space.   I have no idea what kind of dust collector is good enough for this machine, but I definitely prefer smaller equipment than large one due to space issue.
« Last Edit: October 06, 2021, 01:05 AM by lshj »
Offline GarryMartin
The A3-31 requires 500CFM (814m3/h),  at a vacuum of 3"WC (740 Pa). It has a 120mm inlet.
I have a Felder AF-12 (1350m3/h) on my Hammer A3-26 and it's more than enough.
Offline Mini Me
There is a truism in dust collection and that is every single DE out there exaggerates the flow figures by a LOT, the only exception I know of is Clearvue who do not specify any at all. Trying to measure air flow is like trying to round up cats and requires special measuring equipment.
Offline Bert Vanderveen
The answer to your question also depends on whether you bought the base model or the Silent Power version (spiral cutter). The latter produces smaller chips but a larger volume (air!).
I own the A3 31 SP and use a Felder AF14, which works fine. As per Felder the AF14 has an airflow of 1383 cpm.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
Offline lshj
Thank you for the information. So I would assume the dust right 1250 cfm would be just fine.
Offline lshj
Yes, it comes with the spiral cutter. When I ordered it, the sales rep told me that almost every machine they sell today comes with spiral cutter, it becomes the standard package now.
Offline lshj
Probably 1250 CFM is the maximum which only happens during ideal situation. With all the duct hose and different connections, I am sure the actual flow at the machine will drop a lot. I have a Rigid 5 gallon small shop which has 97 cfm, and then bought a festool CI MIDI dust extractor which has 130 cfm. When I connect to similar hose, I personally can't feel any significant difference in term of strength of suction power between these two machine.
Offline Joelm
I have the rockler dust collector you mention. I removed the 4" wye connection which left a 6" port in the extractor itself. I now use a 6" hose going to my oneida dust deputy. I connected the 6" hose using a 6" to 5" reducer after I realized the 4" port on my dust deputy was a 5" to 4" reducer. I get a lot more suction now that I did before. I'm not sure what the numbers would be but the the dust collector with lift the dust deputy off the ground a little when it's empty.
Offline kevinculle
I have a Jet 1100 CFM (nominal) dust collector that does just fine with my DeWalt DW-735 13" planer equipped with a Byrd Shelix insert head.  I am using 4" PVC plumbing and the collector has a 30 gallon separator with a Thein baffle.
Offline lshj
My Oneida dust deputy has 4" connection. I bought this before I decided to buy the hammer A3 31. I thought these machine might all use 4" dust connection, but didn't realize that Hammer A3 31' has a 120mm dust port, or close to 5". If I knew earlier, I would definitely buy the 5"' dust deputy instead of 4".
Offline lshj
Re: Hammer A3 31 dust collection, is 1250 CFM dust collector good enough?
« Reply #10 on: October 06, 2021, 03:57 PM »
It's good to know that 1100cfm with 4" duct works good for the 13" planer. I may just wait and see if 4" dust hose works or not. If not, maybe upgrade to 5" duct, definitely better than upgrade the 1250 cfm dust collector. I am kind of like this 1250 cfm dust collector,  really low noise, similar or maybe even quiter than my festool CT MIDI.
Offline rvieceli
« Reply #11 on: October 06, 2021, 04:25 PM »
@lshj The Dewalt 735 is not a good thing to compare against. It has an internal fan to move the dust through the unit. To be honest I never used the dust collector on mine i just laid the hose out the garage door and let it blow away.
As has been mentioned earlier, the generally accepted fact is that pretty much everyone fudges their CFM numbers on dust collectors. Using at best testing lab perfect conditions and not the real world. I think you will probably have to just wait and see what happens when you actually get the machine. If it works that'll be great. If you think the unit might be capable of a better job then try going up a size in your hose and see if you can also reduce the run of the hose as that will help as well.
Ron
Offline RobS888
« Reply #12 on: October 06, 2021, 07:16 PM »
We have that dust collector with the cartridge filter and a Jet 12 inch jointer planer with a helical head. We have a Grizzly cyclone called a Growler right before the Rockler DC, so I imagine some of the suction is being used up by the Growler. (my wife has a big lathe and the fist time a piece of bark went bong inside the Rockler DC we got the Growler...
Anyway, even with a 4 inch hose from the Growler to the Jet 12HH, all of the chips and dust are collected... occasionally some chips are on the planer bed after sending in a wide board through or a few narrow boards side by side.
I have no complaints about the set up.
P.S as mentioned the type of head would be more important. I used to have a 3 knife Rigid planer and it made long strings that seemed to hook on anything going through the hose.
Offline lshj
« Reply #13 on: October 06, 2021, 08:30 PM »
That's great to hear.  If it works for your Jet 12HH, it very likely will work for the Hammer A3 31.
Offline lshj
« Reply #14 on: October 06, 2021, 08:43 PM »
Ron
Thank you.  I realized that there are so many things that could affect the air flow.  I have tried to connect 1250 CFM dust collector   to the 1 7/8 hose that came with the Ridgid shop vac  using the reducer, try to use it as a shop vac for regular floor cleaning.  The result is so disappointing, the air flow at the end is so much weaker than the Ridgid shop vac with the 1 7/8 hose.  I have a 4" to 2 1/2 hose reducer that could connect to 2 1/2 hose, I have not tried it yet because I don't have 2 1/2 hose, but I doubt the result is significantly  better.  Dust right has the 4' floor sweep, but it's very bulky.
« Last Edit: October 06, 2021, 08:45 PM by lshj »
Offline Mini Me
« Reply #15 on: October 07, 2021, 05:53 AM »
It will be fine to pick up the debris that can be swept up but is unlikely to do much for the dangerous micro fine dust.
Offline RobS888
« Reply #16 on: October 07, 2021, 10:41 AM »
Ron
As I understand it, a shop vac is a small volume/high speed device, whereas a DC is a high volume/slow speed device. When you went to a small hose you had small volume/slow speed. I tried the same thing years ago with a biscuit joiner. The DC was very weak, the shop vac was great and could suck the base of the biscuit cutter to the wood. I use the DC for the table saw, lathe, Joiner/planer and bottom of router table. I use the shop vac for router table fence, domino, track saw, jig saw, and routers.
Offline Tom Gensmer
« Reply #17 on: October 07, 2021, 11:57 AM »
Answering the original question, I have a Hammer A3-41 (the 16" version) with Silent Power cutter head, currently paired with a Oneida Mini Gorilla via 15' of 5" flex hose.
The Mini Gorilla tops out at ~600 cfm @ 2" SP, and easily keeps up with the chips and dust produced by the A3-41, both in planing as well as jointing. There is the occasional chip that gets away, but it's a rarity.
That being said, it's hard to know what cfm your Dust Rite is actually delivering once you put a filter on it, run flex hose to a cyclone, and then more flex hose to your machine. It might not be sufficient.
If you can afford a Hammer, I suggest you put a "real" dust collector on your long-term "To Buy!" list. Your 4" cyclone is going to separate out the chips, but the finest (and most dangerous!) dust particles are still going to get to the Dust Rite, and get spewed back out into your shop. The Mini Gorilla has served my shop well the last six years or so, using a single 15' run of 5" flex and shifting from machine to machine. It has a HEPA filter, which is itself quite easy to clean.
Hope this helps!
Edit: If you need a wall-mount solution, you might be well-served by a Super Cell: https://www.oneida-air.com/dust-collectors/personal-shops/supercell
« Last Edit: October 07, 2021, 01:17 PM by Tom Gensmer »
CT-MIDI, C-18, RO-150, RO-90, OF-1010, OF-1400, MFK-700, MFK-700EQ/B, EHL-65, DTS-400, LS-130, MFT/3 (x4), MFT/Kapex (x3), KA 65 Conturo, endless Systainers
Offline lshj
« Reply #18 on: October 07, 2021, 04:14 PM »
As long as it can pick up majority of the dust, I think I would be happy enough.  I read some articles about woodworking dust problem and realized that there is no way you can get rid of all the micro fine dust.  No matter how good the dust collector is, it can only pick up the dust that is adjacent to the hose.  There is always significant amount of leaked fine dust that the dust collector can do nothing about it.
I recently purchased a TSC 55 track saw with the CT MIDI dust extractor because I heard that festool dust collection is so good. But once I used the track saw, I was so disappointed, the dust is everywhere and so much dust leaked in front of the track saw blade, every time I used the track saw, I have to clean up significant amount of dust. Then I tested the dust bag that came with the saw, and realized that about 80-90% of dust has been collected in the bag. Connecting to the dust extractor is slightly better than the bag, but not a lot.  Now I know that I am expecting  too much. I am just accepting the  fact that there is always leaked dust.
I also have a jet air filtration that looks like a big box.  I bought it a long time and have not used it too much.  I am planning to hang it to my garage ceiling.  Hopefully it could help a little to make the garage air clean.  If that doesn't work very well, I might get a rabbit air purifier, I heard some good review about it.  I don't think I will use the jointer/planer more than once a week, probably even less. Mostly I just use it to build some furniture for my home and some other fun projects.
Offline lshj
« Reply #19 on: October 07, 2021, 04:20 PM »
Hope this helps!
Thank you.  I probably just wait to see how this 1250 CFM dust collector works for the machine.  Hopefully it works.  I think the 1 micron canister filter is good enough for me, I really like this machine, not noisy, and it's quite clean although I have not use it much yet.  The 1250 CFM is 1.5 hp, less than the 2hp Oneida mini but labeled as more CFM?  Really don't  know how it can get more CFM than the 2hp machine.
Offline Tom Gensmer
« Reply #20 on: October 07, 2021, 05:47 PM »
Hope this helps!
I agree that ultimately, you won’t know until your machine arrives and you get a chance to run it with your existing collector.
In terms of specs, different manufacturers use different methods for generating their specs, thus the wide variation. Many collectors are rated at the inlet, with no bag or filter fitted, thus generating really impressive numbers, but setting unrealistic levels that you’ll never actually see in practice. Oneida gets their numbers with a HEPA filter, often at the end of some length of flex hose, yielding less impressive numbers that are nonetheless more representative of real-world performance. I have a Felder RL160 on order, and the testing criteria on is is to fit it with the filter, expose the collector to a proscribed amount of a specific size of dust media for one hour, then collect data…..
I would disagree with your assessment that “there is no way to collect all the ultra fine dust”. This ultra fine dust gets suspended in the air if not collected at the source, in which case you need to filter the shop air. A collector with sufficient performance will have no problem collecting the ultra-fine dust (easier to collect than chips), at which point you need to make sure you have a filter with a sufficient filter efficiency to actually capture the dust, otherwise your “dust collector” is acting as a dust pump, continuing to circulate the fine dust in your shop. I’m not an expert, but I’d be wary of a 1-micron filter, as it won’t filter out the finest dust. Granted, this shouldn’t be a big issue with a jointer/planer, but would be a major concern if you connected to a sander.
Congrats on your upcoming A3-31, it’s a great machine that should give you a lot of great service.
Offline Mini Me
« Reply #21 on: October 07, 2021, 09:08 PM »
As I have said before I am in the duct extraction/collection business but do not deal with what can be called commercial operators only those who could be called hobbyist up to wood working clubs of which we have thousands in Australia.
We advised on and installed a system into a club (called Men's Sheds in Oz) and the obvious result was very apparent immediately it was turned on. They had members who were Asthma sufferers and those guys would be forced to leave the shed due to dust build up in the air despite several dust extractors always being used. Immediately we turned on the new system that problem went away and has never returned.
Another truism in dust collection is if the DE uses a felt or cloth bag then it always leaks dust back into the working area and there is no way around it unless the DE is isolated from the work area and the dust can't return. The absolute best dust control information is available on the Australian WW forum, there is simply no better source world wide and it has built on and surpassed Bill Pentz's site by a long way.
A simple recipe I give to achieve effective dust collection is a 15" impeller using 6" ducting to the machine with 6" ports, it simply works. I have also become a convert to using VFD's controlling three phase motors on DE's for speed and noise control purposes. I was the original Clearvue importer in Oz and I think over 99% of CV's here use 240V/3 phase motors driven by a VFD as It was the only way we could get the impeller speed up to 60hz to match the US. I would never buy a single phase DE after that experience because if noise or other reasons dictate a different speed it is done at the turn of a knob.
Take all that for what it is worth as the end effect of your efforts are what affects you health wise and that can only be a personal decision you have to make.
Offline lshj
« Reply #22 on: October 07, 2021, 10:35 PM »
Hope this helps!
Thank you. I have a 1 micron canister filter that connected to the dust collector. I think that would help to avoid pushing the fine dust to the air. Also the dust deputy might also help a little.  I probably have to wait until the machine comes to tell how good it works. As long as it works for the jointer/planer and the bandsaw, I will be very happy.  I won't use the dust collector for sander. I have a festool CT MIDI if I need to use the sander, or I just use the sander outside. I built a small shed in my back yard with a deck. I put my table saw in it and when I need to use the table saw, I push the saw to the deck to use it outside. The saw is a Sawstop contractor saw that I bought many years ago,  so it not difficult to move around. I feel like using the saw outside is the best solution for me to deal with the dust problem for the table saw.  I recently bought a festool track saw hoping that I could us the track saw do more cutting, but really disappointed with the dust extraction of the track saw.
Offline lshj
« Reply #23 on: October 07, 2021, 10:41 PM »
Thank you for all the information. It looks like that larger duct might help a lot. The Dust right dust collector has actually a 6" port, and connected with a Y shape 4"' adapter. I might need to change it to 6" or 5" duct if it doesn't work very well.
Offline Mini Me
« Reply #24 on: October 08, 2021, 12:40 AM »
4" duct simply can't flow enough air to reach the 1000 cubic feet generally regarded as a minimum requirement as the maximum air flow is around 700 cubic feet a minute. Get rid of the 4" entries and use a 6" duct to maximise the flow. I run my 1800 CV at 70hz and I reckon that is the sweet spot for maximum air flow. At that speed the 6" is most probably too small and 7" would be better but we can't buy 7" anywhere in Oz unless it is custom made and I  am not springing for that because then the blast gates we sell would have to be enlarged as well.
Offline lshj
« Reply #25 on: October 08, 2021, 11:56 AM »
That makes perfect sense.  When I installed my range wood with the external blower for my kitchen, I used 10" rigid duct and also tried to make the duct as short as possible.  The diameter of the duct would significantly affect the efficiency of the ventilation.
