Author Topic: Delta planer chatter?  (Read 2039 times)
Offline fesfrank
« on: June 25, 2010, 05:18 PM »
I have an older Delta Table planer(model tp300) and I recently changed the blades.  Its now a smoother cut but it is very wavy.  Why is this doing this,  does anyone know or has come across this problem before with a table planer.  I'm thinking that its because the blades are at different heights but I used the provided depth tool to guage them.  I'm not sure but I need it fixed asap.  Thanks
Offline jvsteenb
Re: Delta planer chatter?
« Reply #1 on: June 26, 2010, 04:03 AM »
Sounds like a balancing problem to me. Have you tried exchangig the blades - say blade A in the B position and vice-versa ?
When using any depth gauge, you should make VERY sure, that the cutter positions are identical when gauging. This is easily overlooked but very important.
Did you have the blades sharpened or sharpened them yourself ? Sometimes one of the blades is ground deeper to get rid of a nick. The other blade ( even if not nicked ) should be ground down the same amount to preserve balance.
Simple measures which I'm sure you already knew, but perhaps this can be of assistance.
Regards,
Job
Edit: This can also be caused by replacing a blade mounting screw. Sometimes when you chance blades you loose a screw - it happens. Rather then getting the screw back from the intestines of the machine, a similar fitting screw is used. This may upset balance for it's unlikely that the replacement screw is the exact same mass. This may seem like splitting hairs, but especially in a table planer where the mass of the head isn't as big as in a large stationary planer AND the bearings are less robust, it may well pose a problem.
« Last Edit: June 26, 2010, 05:01 AM by jvsteenb »
TS55, OF1010, RO150, RTS400, PS300, T15+3, CTL22E, CMS-TS55+Basis5A (OF1010), MFT/3, MFS400/700, FS800-1080-1400-1900, Centrotec-SYS 09, DF 500 full set, some accessories :)
