Author Topic: Grinder for Wood  (Read 1529 times)
Offline Birdhunter
Grinder for Wood
« on: August 26, 2019, 12:11 PM »
I bought a huge chunk of Cypress to turn for a gift. The wood has some bumps and protruding knobs that I’d like to remove before turning the bowl.
Is there a grinder that would let me quickly remove the offending wood?
Birdhunter
Offline RKA
Re: Grinder for Wood
« Reply #1 on: August 26, 2019, 12:19 PM »
It depends on what you have available.  Bandsaw?  Reciprocating saw?  Pruning saw (ala Silky or something similar)?
-Raj
Offline stickman
« Reply #2 on: August 26, 2019, 12:31 PM »
Festool RAS 115 with P24 paper would eat that up.
KS-120 | TS-75EQ | DF-500Q | XLDF-700 | RO-150FEQ | RO-90DX | HKC-55EQ-FSK420 | EBQ-420D | MFT/3 | CT-26 | CT-SYS | T18+3 | OF-1400EQ |  TSC55 REB PLUS | HL 850 | RAS-115 | VECTURO OS 400 | PDC 18/4 | LR32-SYS | SYS-ROLL 100
Offline Lettusbee
« Reply #3 on: August 26, 2019, 12:34 PM »
Holey galahad wheel on a regular 4 inch grinder is a life changing tool
Sent from my SM-N960U using Tapatalk
Offline waho6o9
    • Garage Door Handyman.com
« Reply #4 on: August 26, 2019, 12:37 PM »
https://kutzall.com/collections/sanding-discs
303658-0
As stated above, 24 grit and the RAS 115 is an awesome combo
« Reply #5 on: August 26, 2019, 12:46 PM »
Any cheap grinder and the coarsest abrasive disk will do the job if you don’t mind the mess.
I’d use a portable power plane instead.
Offline mrB
« Reply #6 on: August 26, 2019, 03:55 PM »
In the uk there are plenty of "chain saw" type blades that fit into a 4" grinder. That would be the easiest and quickest way. And much more pleasant than sandpaper on a grinder that will fill your world clouds upon clouds of fine dust..
Just use that thing with your FULL concentration! Dangerous tools!
https://images.app.goo.gl/VB2AR6wodX2bEj8o9
« Last Edit: August 26, 2019, 03:58 PM by mrB »
Offline ear3
« Reply #7 on: August 26, 2019, 06:26 PM »
Fiber disc attachment and abrasive would be the cheapest, but I second the investment in a Kutzall or Galahad disc to pair with the grinder.
RAS is a bit slower, but generates less of a mess with the DC capabilities.
Offline Alanbach
« Reply #8 on: August 26, 2019, 11:13 PM »
I am no bowl turner so I really don’t know the answer to this but why wouldn’t you just chuck up the piece and remove the protrusions with a roughing gouge?
« Reply #9 on: August 27, 2019, 11:01 AM »
If the general diameter of the rough blank is already close to maximum swing of the lather the extraneous protrusions will prevent it from turning. I just knock them off with a power plane on the lathe. Chip size is similar.
« Reply #10 on: August 27, 2019, 11:26 AM »
If the protrusions are rather large, I'd use a Sawzall. Less mess
Smaller protrusions would be good fodder for the RAS + Saphir or a RA grinder + Kutzall/Galahad.
Offline Birdhunter
« Reply #11 on: September 12, 2019, 05:07 PM »
I went the roughing gouge route. A little bumpy at first!
Birdhunter
Offline Alanbach
« Reply #12 on: September 12, 2019, 08:25 PM »
Don’t worry, your teeth will snug back up in a few days!😊
