Author Topic: Knipex Pliers Wrench  (Read 4545 times)
Offline elfick
« on: June 04, 2014, 09:25 AM »
I'm looking to replace my crappy general-use adjustable wrench. Does anyone have any experience and/or recommendations for or against the Knipex Pliers Wrench?
Offline RKA
Re: Knipex Pliers Wrench
« Reply #1 on: June 04, 2014, 09:44 AM »
I have the set but don't use them very often.  I like them when I need to work a nut in or out of place, because it's easy to release by grip and allow the pliers to expand around the nut as I reposition and clamp down again.  Like a poor mans ratcheting wrench.  But it takes a few extra seconds to get the jaw spacing adjusted properly.  Usually I'll make 3 adjustments before I get it exactly where I want it.  With a regular adjustable, you can reach it into a space, flick your thumb a few times and it's snugged down.  But of course, repositioning an adjustable wrench is a pain, if you need to turn a bolt 10 turns.
So, in most cases I'll reach for a channellock wide mouth adjustable to crack the nut loose, then spin it loose by hand or grab a ratcheting wrench if it's too tight to spin loose by hand.  The knipex is a nice design and well made, but that initial adjustment is a little fussy.
-Raj
« Reply #2 on: June 04, 2014, 10:18 AM »
Knipex is very good but you can buy a locking adjustable wrench.
.There are various forms old and new.
I have an old Williams tool so I can't comment on the newer designs.
Offline Alex
« Reply #3 on: June 04, 2014, 12:43 PM »
I also have one of these, and basically it's a nice wrench, very well made. It is not for the nuts that are really tight, but works fine for most. But I find I use the normal adjustable wrench a lot more.
« Last Edit: June 04, 2014, 12:45 PM by Alex »
Offline Len C
« Reply #4 on: June 04, 2014, 02:10 PM »
strangly enough I just the same thing, order it from KC tools but it is a little cheaper at amazon and probably chads toolbox place.
http://www.amazon.com/Knipex-8605250-10-Inch-Pliers-Wrench/dp/B000X4J2EI/ref=sr_1_2?ie=UTF8&qid=1401905228&sr=8-2&keywords=Knipex+86-05-250
Seems very nice and used it today working on the well.
Offline waho6o9
    • Garage Door Handyman.com
« Reply #5 on: June 04, 2014, 02:50 PM »
http://chadstoolbox.com/3x8603knipex3pcplierwrenchset710and12.aspx
Here's some prices for comparison. They look like high quality pliers.
Offline Roseland
« Reply #6 on: June 04, 2014, 03:00 PM »
I bought one last month, and it's one of the best hand tools I've ever bought.
The mechanical advantage is about 12:1, compared to about 3:1 for regular pliers, so it grips fiercely.  As a result, it's less likely to slip than a regular spanner.  And because the jaws stay parallel it causes much less damage on soft materials.  It's the best tool ever for pulling dominos out of trial assemblies.
It fits in a pocket and has 27mm jaws.  What more do you need to know?
Andrew  :-)
TS55, MFT/3, OF1400, OF1010, CT26, RS100, ETS125, CXS, MFS400, DF-500, Zobos.
Offline Laminator
« Reply #7 on: June 05, 2014, 08:19 AM »
RKA and Alex summed it up very well.  The best use I've found for it is as a back up for plumbing fittings and valves found under most kitchen sinks where being able to hold (grip) something is a big advantage, especially something you don't want visegrip teeth marks on.
Offline elfick
« Reply #8 on: June 05, 2014, 08:48 AM »
Which size did you purchase? I believe they are available in 6", 7", 10", and 12".
Offline Laminator
« Reply #9 on: June 05, 2014, 02:19 PM »
I have the 6" only.
Offline Roseland
« Reply #10 on: June 05, 2014, 02:56 PM »
I got the 6" (150mm).  In April they launched a 5" (125mm) but that would be too small for anything but appliance repairs, I think.
Andrew
Offline Colonel Panic
« Reply #11 on: June 05, 2014, 02:58 PM »
Boy, a bunch of those tools look like solutions in search of a problem!  [blink]
What, me worry?
Offline greg mann
« Reply #12 on: June 05, 2014, 08:13 PM »
Andrew is right about pulling Dominos with them. I had a pair for quite awhile and felt i probably had bought a "solution looking for a problem.". Then i discovered how well theynpulled Dominos. That was the problem that needed solving. [doh]
Greg Mann
Oakland, Michigan
