Author Topic: Forstner depth stops?  (Read 1519 times)
Offline JonathanJung
  • www.timberlightdesigns.com
    • Timberlight Designs
« on: February 02, 2021, 12:30 AM »
Anyone have experience with depth stops for forstner bits? I often find myself counterboring for bolt heads, fastcaps, cabinet screws, lags, etc. What should I use in these situations? I grab my forstner bits, occasional a spade bit.
Fastcap has their Flushmount for recessing powerhead screws and covering with a fastcap, but Fastcap's quality is a real problem and I want a depth stop not limited to the 3 size cutters they offer - https://www.fastcap.com/product/flushmount-drill-bit-system
I'd like it to be non-marring, so probably with a bearing. Initially I'm after a 9/16" for flush sticking Fastcaps.
Anyone have a source for the Fisch 973F?
Some out there are these:
https://www.eagleamerica.com/product/301-0109/woodboring_-_forstner_bits
https://woodworker.com/1-6-forstner-slipstop-kit-mssu-915-975.asp?GF=915-975&gclid=Cj0KCQiA6t6ABhDMARIsAONIYyxWHmPOepu5Q6hlw4oMEXZzdckCN1WeSRXT0_Wuiv3MORRACbdJNLkaAglTEALw_wcB
https://www.fisch-tools.com/en/produkte/973f-drill-stopper-for-forstner-bit
https://www.sautershop.com/depth-stop-for-forstner-bits-fa-162110800?c=14759
Offline CeeJay
Re: Forstner depth stops?
« Reply #1 on: February 02, 2021, 04:30 AM »
For Forstner bits I use a thin black permanent marker and mark the depth I want to stop at on the outside. The black line is pretty easy to see and use as a depth stop.
Offline Bob D.
« Reply #2 on: February 02, 2021, 06:17 AM »
Are you drilling free-hand with a hand held drill?
If using a drill press most have some sort of mechanical depth
stop built in or one can be made without much trouble.
Offline Chris Perren
« Reply #3 on: February 02, 2021, 09:39 AM »
Infinity Tools has the FAMAG depth stops for Forstner Bits.
https://www.infinitytools.com/famag-forstner-bit-accessories
Offline cpw
« Reply #4 on: February 02, 2021, 09:53 AM »
I have a fastcap system with the three bits, they work, I haven't had any quality problems with this product.  I know that they have a hit and miss reputation for quality (but will always make it right from a customer service perspective).  Sometimes they'll come out perfect, but other times you can leave a bit of a mark, especially if you are not quite straight and one side of the stop collar contacts before the other.  I actually used it yesterday, 3/4 were perfect but one left a slight mark where the collar rotated against the paint.  Prefinished plywood is tougher and your less likely to leave a mark.
Offline Oldwood
  • Alberta, Canada
« Reply #5 on: February 02, 2021, 10:49 AM »
I use a drill stand if I have enough holes to justify setting it up. This is not the one I own but the same idea. They help keeping the drill perpendicular and have a built in stop.
https://www.amazon.com/Milescraft-1318-DrillMate-Drill-Guide/dp/B014A1Z92I/ref=sr_1_4?dchild=1&keywords=drill+stand&qid=1612280580&sr=8-4
I have also in a pinch drilled a hole through a piece of wood that is thick enough that the bit protrudes  through the amount I need the depth of cut to be then the drill chuck bottoms out on the scrap and acts as a stop.
Confucius
Offline Kevin C.
« Reply #6 on: February 02, 2021, 01:45 PM »
If you have a corded hammer drill, they come with a handle and a rod that can be used for a depth stop. I've used it on a cordless drill as well. I know the Dewalt works from one drill to another, makita as well.
« Reply #7 on: February 03, 2021, 10:09 AM »
Good idea, if that works I may have one less reason to use spade bits.
« Reply #8 on: February 03, 2021, 10:09 AM »
Hand-held drill
« Reply #9 on: February 03, 2021, 10:10 AM »
Sweet, thanks! I emailed them, but do you know if they fit Fisch / Freud bits?
« Reply #10 on: February 03, 2021, 10:11 AM »
That's good feedback. I've been dissatisfied with so many of their product, the majority of what I've purchased, that I didn't want to waste $65 on another. I might give one a try though.
« Reply #11 on: February 03, 2021, 10:12 AM »
I've done the same too, using a wood block with a hole drilled first with the drill press, then I take it with me for on site work. It's ok, but is very clumsy to use.
« Reply #12 on: February 03, 2021, 10:13 AM »
What would be cool is an attachment with 3 rods, so that the drilling finishes square to the surface. I've got a drill with that, but it's easy to drill wonky.
Offline Packard
« Reply #13 on: February 10, 2021, 09:56 AM »
Rockler has a "jig-it" for that purpose.
https://www.amazon.com/Rockler-JIG-IT%C2%AE-Drill-Guide/dp/B001GT8EY8
And, of course, a drill press works fine for that application.
Offline dpow
« Reply #14 on: April 14, 2021, 10:26 PM »
This is late but for anyone else who sees this, that Fastcap bit is $25 less on Amazon
