Author Topic: Need advice from someone with Hammer N4400 who likes it  (Read 8706 times)
Offline billberner
« on: September 28, 2017, 11:07 AM »
I had seen in other threads notes from people saying they had a Hammer N4400 and liked it. I'm hoping I can get some help from one of you.  I bought one and have been very disappointed with it.
I mainly bought it to resaw lumber, and the first problem I had was that with a 3/4" blade and the tracking set the way the manual instructs (with the blade teeth hanging over the left side of the crown), the blade wandered horribly and I mostly just wasted wood.  I had read advice of someone who had the problem and fixed by resetting tracking so the blade was centered in the crown. That worked much better, but when I called Felder customer support, they were pretty adamant I should reset the tracking as instructed in the manual. If anyone's either had the machine work with the tracking set as described in the manual or set the tracking to the center of the crown and not had issues, I'd like to hear it.
The second issue I notice is that the fence is not perpendicular to the table, so all the cuts are wider on the top than on the bottom, and I can't see any easy way to adjust that.
Lastly, I have the standard guides, not the ceramic guides.  Felder suggested maybe I buy the ceramic guides if I have problems with the blade wandering. I don't really feel like throwing more money at the problem before I've tried everything else.
Thanks in advance for any advice.
Offline egmiii
Re: Need advice from someone with Hammer N4400 who likes it
« Reply #1 on: September 28, 2017, 04:03 PM »
I recently bought an FB510. Still setting up the shop so I haven't fired it up. But, while visiting Felder for some training, I was told to hang the teeth off the edge of the wheel. European bandsaws typically have flat wheels, so the Snodgrass method doesn't work. I'd double check if the N4400 has flat or crowned tires and select the correct placement on the wheel.
Offline WarnerConstCo.
    • Warner Mill Works
« Reply #2 on: September 28, 2017, 09:32 PM »
Crowned tires are so much easier to keep a blade tracking correctly, I don't understand the flat wheel way.
Offline Bert Vanderveen
« Reply #3 on: September 29, 2017, 03:41 PM »
Flat wheels are easier on the blade. Less wear, less tear. More support. Less chance of compromising the teeth.
Cheers, Bert Vanderveen
TS55 · TS55R · OF1010 · DF500 · MFT/3 + TSB1-MW 1000 + VL + CMS TS55 + CMS PS300 + LA-CS 70/CMS · CTL Midi · RTS400 · 2 x CXS Li 1,5 · T15+3 Li 4,2 · TI15 Impact Li 4,2 · Centrotec Sets 2008 + 2015 · PSB300 · LR32-SYS · RO150 · KS120 · 2 x MFK700 · RO90 · OFK700 · BS75 · OFK500 · OF2200 · CMS-GE · Vecturo 18 Li · TID 18 · TKS 80 EBS-Set · DTS 400 · ETS EC 125 w 150 pad · Surfix Set · CTL SYS · CT-VA-20 · … | Mirka 1230L P&C | Hammer: A3 31 Silent Power · N4400 · HS950 | TaigaTools: VacPods Pro Set
On order: … [ ! ]
    • Warner Mill Works
« Reply #4 on: September 29, 2017, 05:17 PM »
How?
More support?
Compromise teeth?
It's a rubber tired wheel.
Resaws run on steel wheels, have for over a century.
Offline Andywoj
« Reply #5 on: September 29, 2017, 11:29 PM »
I have a N440 and I like it very much.
I set my fence to be parallel with the miter slot.
Then I adjust the tracking until the blade cuts parallel and does not wander.
I do not care where it tracks on the wheel as long as it cuts parallel to the fence.
I use this tracking adjustment with 3/4" blades and 1//4" blades.
Works for me.
Andy
Offline Gone
« Reply #6 on: September 30, 2017, 08:23 AM »
Darcy are the steels wheels for resawing that you are referring to crowned or flat? What are the width of the saw blades being used in these resaw machines?
Offline petar73
« Reply #7 on: September 30, 2017, 12:02 PM »
Hello everyone, perhaps it is strange but I have been using bandsaws for over 25 years and I have never seen a bandsaw with crowned wheels, but then I have never used smaller than 600mm wheels bandsaw for resawing.
Offline HAXIT
« Reply #8 on: September 30, 2017, 12:24 PM »
I have been resawing with n4400 a lot and did not have any problem. I do have the ceramic guides and they worth the money for sure.
Offline J0hn
« Reply #9 on: September 30, 2017, 12:33 PM »
I don't have a Hammer bandsaw, but it your having problems with your blade tracking - have you seen this video by Alex Snodgrass?
Offline billberner
« Reply #10 on: September 30, 2017, 10:59 PM »
I have watched the Snodgrass video and that's probably at least partially why I was wondering about the tracking method documented in the manual as the Snodgrass method is more or less completely opposite.  Per other responses to the thread, maybe that's because it has flat wheels.  I'll check that tomorrow.
Offline alkaline
« Reply #11 on: October 01, 2017, 02:42 AM »
my first experience with a hammer? here...🙈🙈🙈
Two things are required for proper machine operation. 1. Bimetal strip of first quality 2. ceramic guide. I'm sorry, otherwise it's a bother.
Have a nice sunday.
I have several boxes Festool, one MTF, four guide rails and big taste to play. )))
Offline Lbob131
« Reply #12 on: October 01, 2017, 08:19 AM »
When the sparks are flying  the blade is  blunt  and I've seen it on my  N4400. I use  the tuff  saw  blades.
5/8" maximum   and can  slice    the full capacity  of the  N4400 without issue  on hardwoods.
I'd like the ceramic guide  set up but   for now I'll  make do and  keep using high   quality sharp blades.
I also  apply some lubricant to the  roller shaft  to ensure it turns freely.
« Last Edit: October 01, 2017, 09:46 AM by Lbob131 »
Offline billberner
« Reply #13 on: October 02, 2017, 08:42 AM »
I have not seen the sparks yet, but the saw is new, the blades are new.  I'm starting to think the ceramic guides are top of my list for Christmas.  Or Thanksgiving.  Or maybe Halloween.
Offline ben_r_
« Reply #14 on: October 02, 2017, 05:50 PM »
Had mine a couple years now and its been nothing but awesome for me. Though I havent done any resawing on it.
Offline derekcohen
    • In The Woodshop
« Reply #15 on: October 03, 2017, 11:40 AM »
I have not experienced any issues with resawing in the 6 years I have had the N4400. Below is an example using a 1/2" Woodslicer blade. Incidentally, I do not like these blades as they wear quickly - I much prefer a 1" bi-metal Woodmaster 1 1/2 tpi for resawing. Note the widely set teeth - too many teeth and the gullets will clog  ..
The other aid is a resaw fence, which I made ..
I do not have - and never have had - the ceramic guides. The standard ones work just fine. The sparks in your photo appear to be coming from guides that are rubbing on the blade. They may be too far forward and touching the teeth.
The basic fence I received was a degree off. I filed down the runners until it was perfectly square.
The blades are placed on the wheels/tyres in such a way that they spin smoothly. I tighten them progressively. I make no issue of where they sit on the wheel. Tension must be correct for your size blade.
Check to see if the rubber drive band is tensioned tightly. If it is loose you will lose power. Too little power and the blade will wander.
Incidentally, I added a rule to my bandsaw. It is made from stainless steel. The screw holes are slotted to enable fine adjustments ..
Visit www.inthewoodshop.com for tutorials on joinery, hand tools, and my trials and tribulations with furniture builds.
Offline billberner
« Reply #16 on: October 04, 2017, 04:23 PM »
Thanks Derek.  I was just logging on to check if people doing resawing were using an auxiliary fence and you already answered that question.  In the pictures shown, it seems your fence is affixed to the standard fence just by a slot in the rear-most wooden support, is that right?
Offline derekcohen
    • In The Woodshop
« Reply #17 on: October 25, 2017, 06:26 AM »
Hi Bill
My apology for not replying sooner.
Yes, the auxiliary fence simply slides on and is a friction fit.
Offline billberner
« Reply #18 on: November 15, 2017, 01:47 PM »
Based on the various feedback I received (thank you!) I both purchased the ceramic guides and I made a tall auxiliary resaw fence.  Now I seem to get cuts that are much smoother and straighter. That said, I do not seem to be able to adjust the ceramic guides so I do not get sparks.  The install manual indicates that you should back the guides off the blade if it is sparking, but I do that and it seems to spark worse.  and eventually I had them backed off more than I did for the standard guides, which doesn't make any sense.
Anyone else seen this?  Or know what I might try to eliminate the sparks?
« Reply #19 on: November 15, 2017, 02:07 PM »
The ceramic guides on the sides need to slightly touch the blade. The one behind the blade should have a millimeter clearance (for the guys in the USA, Liberia and Myanmar that is about 1/24th of an inch). Tensioning correctly is important. The scale in the N4400 is not always correct. Try doing a twist or two more & see what happens.
On order: … [ ! ]
Offline dhoover1027
« Reply #20 on: November 15, 2017, 03:46 PM »
For what it's worth, I've had a Hammer N4400 for about 7 years now and it's one of those tools that are better than I am. I've had many a car on the racetrack that were a ton better than I and in the same way will punish you until you up your skills. This just me not anyone else.
I got the plans for the Hammer chair and it is 90% made on the N4400. I learned a lot about bandsaws and my lack of skills trying to make this chair. The chair turned out pretty well. It looks like a piece of art, but the most uncomfortable thing in the world.
I ended up taking the entire red blade guard off and put it in a drawer. This has made it easier to use. A bit more dangerous, so I really need my wits at a high level when I use it. More coffee.
I also bought a set of Carter Products bearing guides. A lot easier to set up and adjust especially when you change blades to a different size. David Best (Felder Owners Group) , another fog - a message here ? published a guide to ordering and installing these guides along with part numbers and some modifications you need to do to the Carter adapter bar for the lower guides. If anyone wants a copy, I can make a PDF and email it to you. Just PM me and include your email address.
You will need:
GP-stud347.   347 offset stud 20mmx7/16       2 each
GA-2300LH.    2300LH upper guide assy.          1 each
GA-2300RH.    2300RH lower guide assy.          1 each.
This made a big difference in how the saw performs for me and they are easier to adjust that the OEM guides. I have never used ceramic guides, so no comparison here.
Yes, Felder advice will not deviate from dogma. We don't want to have you hurt yourself. My blades ride towards the center.
And I'll never make another chair !
Doug
Offline dhoover1027
Offline billberner
« Reply #22 on: November 16, 2017, 10:10 PM »
...and it's one of those tools that are better than I am. I've had many a car on the racetrack that were a ton better than I and in the same way will punish you until you up your skills.
That is definitely the perspective I have as well.  I sometimes feel like I'm learning to play an instrument.  But I'll get there and I appreciate the tips I've received.
Offline Gone
« Reply #23 on: November 17, 2017, 07:35 AM »
Don't worry about sparks unless they are continuous, typically it means the guides are set tight enough and will go away. The Felder ceramic guides are a pain to setup properly and take a light touch, I much prefer the Laguna guides I put on my FB600, much easier to setup. Proper blade tension is much more important in a bandsaw that's properly setup.
John
Offline billberner
« Reply #24 on: April 27, 2018, 03:31 PM »
I thought I would reply once more to this thread as I finally figured out how to get rid of the sparks on my Hammer N4400, but I'm not sure what I'm doing makes sense.   The only help I got from Felder was to "look at their setup guide" and "make sure the blade is parallel to the ceramic guide."  My sparks were coming from the bottom of the ceramic disk, so I assumed the disk was tilted backward with respect to the blade, but I was not able to tilt it forward far enough to make it coplanar and still tighten down.  so what I ended up doing was sticking two small wood wedges above the guide holder as shown in the attached photo.  These rotate it so that it is parallel to the blade and now I have no sparks.  But for a $1800 saw, $350 or whatever ceramic guides, it does not seem wood shims should be necessary, but I could not get rid of the sparks any other way.    Anyone see any problems with this solution?
Offline Prizen
« Reply #25 on: December 01, 2020, 05:21 PM »
I’m aware this is an old thread but I’m having similar issues with my newly delivered N4400.
Standard guides here, no ceramic. I have tried to cut a 4” laminate of oak (1”) and birch ply (3”) but it really struggles. It’s with the as delivered blade installed, but can this blade be actually that bad? It is sharp to the touch and I have only cut 5ft linear of 1/2” ply as the very first cuts prior to this 4” block. The saw really struggles, sparks occasionally and it is nigh on impossible to make a turn
Any thoughts? The blade? If it’s poor quality then I expect it to blunt quickly but at least work satisfactorily for the first number of feet!
Offline derekcohen
    • In The Woodshop
« Reply #26 on: December 02, 2020, 06:48 PM »
Hi Prizen
My advice on the UK forum remains the same, and I repeat it here for others who are interested, and those who may wish to comment:
My assumption would be that you need MUCH more tension on the blade. The lack of tension translates into the blade not gripping the wheel and the power is not being transferred. Plus the blade wanders, and the cut is poor. Sparks are probably coming off the guides as the blades touches it.
Note that the blade tension meter is just a guide to tension. Add more until you see minimal deflection.
Offline ben_r_
« Reply #27 on: December 02, 2020, 07:00 PM »
Yours came with a blade?! What are the specs on the blade?
