Author Topic: Felder K700 or K500 tablesaw question  (Read 2339 times)
Offline 9Fingers
« on: May 04, 2018, 10:56 AM »
Hi, I have a Felder K500 saw and am looking for some help to adjust the travel of the sliding table. It is about 7-10 thousandths off and the work pieces are contacting the rear of the blade as they are pushed by. I bought this saw used and suspect the table was moved slightly in transit. I have the user manual from Felder but it doesen't cover that adjustment
Any help is appreciated, thanks.
Offline Sparktrician
Re: Felder K700 or K500 tablesaw question
« Reply #1 on: May 04, 2018, 11:59 AM »
You can always contact Felder Tech Support.   [smile]
- Willy -
Offline egmiii
« Reply #2 on: May 04, 2018, 01:18 PM »
Sign up for the Yahoo Felder Owner Group and repost. It's an archaic format, but you will get a solid answer likely within the hour. I'd add a few more details about the machine and the specifics about how you are making the cut.
Offline lwoirhaye
« Reply #3 on: May 04, 2018, 04:23 PM »
You might want to check to see if the blade is heeling first.  That would be an easier adjustment.
I have a Felder and the blade is heeling a little.  It didn't when I got it but I've moved it around a lot on a pallet jack and I think it may have drifted a little.  It's heeling on the rip side though so it's a less pressing concern to me, which is why I haven't got around to adjusting it.
