Author Topic: Felder FAT300  (Read 13529 times)
Offline Grev
Re: Felder FAT300
« Reply #30 on: July 17, 2022, 08:31 AM »
Hi. Im new here. I was considering buying one of those fat tables, but now i think about calculating cost of diy build. Is there any chance that one of you guys provide Steel profile dimension used at this fat table? Cant find anything on felder web. Thanks
I measured the steel tube profile as 40 mm x 60 mm.  The bottom frame dimensions are approx. 1100 mm x 650 mm and the top frame dimensions approx. 1100 mm x 625 mm.
Offline Tobiasz
Re: Felder FAT300
« Reply #31 on: July 17, 2022, 09:51 AM »
Thanks for this. And can you describe or show how felder figure out this part with routed groves at top and bottom section? Are there some rollers that run through this channel profile ?
Offline Dane
Re: Felder FAT300
« Reply #32 on: July 17, 2022, 11:29 AM »
Despite the price, the FAT tables are pretty standard lift tables.  You can buy plans for them on Etsy.  The lifting mechanism is what Felder seems to do pretty nicely.
Offline Mini Me
Re: Felder FAT300
« Reply #33 on: July 17, 2022, 08:39 PM »
