Author Topic: Fein Turbo I or II  (Read 1354 times)
Offline Claimdude
Fein Turbo I or II
« on: October 10, 2015, 12:18 PM »
I have a number of Festool tools including a CT 22 vac with a Oneida cyclone sitting on it. I am about to purchase an ETS 125 EC with the new cloth covered vac hose and also need a second vac. The second vac will be doing double duty mounted in my custom made miter saw station that is mobile (small shop). The place where the vac will need to fit too small to set a CT 26 or a Midi in and still hook up the hose, etc. This is an enclosure with a door on it. The inside dimensions are 25" long x 20" deep x 23" high. The Fein will fit so I plan on picking up one of those with the new Festools. My question is will my other Festool hoses fit in the Fein vac like they do my CT 22 or will I need an adapter to insert in the Fein to accept the friction fit fitting on the end of the new hose/current 27mm hose I use with my boom arm, etc?
 Jack
Re: Fein Turbo I or II
« Reply #1 on: October 10, 2015, 12:35 PM »
This is an older Turbo II with a Festool 36mm hose for the Kapex. No adapter needed, I believe the newer Feins work like this also.
230754-0
Offline Claimdude
« Reply #2 on: October 10, 2015, 07:19 PM »
Thanks Cheese!
Jack
Offline rst
« Reply #3 on: October 10, 2015, 07:21 PM »
I have two of the older model Fein that work Fine with my Festoys.  I also have a Midi and 26 and all are connected to Oneida's... the Feins to the steel model.
