Author Topic: Finally Used My DF 500 Connectors  (Read 1249 times)
Offline Mike Goetzke
« on: December 06, 2022, 07:44 PM »
In my garage shop I use three MFT slabs, TrackTubes, and Speedhorses to make a 4' x 8' work table. I use six short dogs in the t-track of the TrackTubes to hold the slabs in place but sometimes they want to wander a bit. About a year ago I bought some connectors to hold the slabs together but kept putting it off until today. They work great! I also added a regular domino to the center to keep the table flat. I will only need a couple of dogs now to hold the big table in place. The table seems stronger now being attached together. Only thing I'm worried about is I hope I don't damage the studs or loose the set screws:
Offline Adamsse
Re: Finally Used My DF 500 Connectors
« Reply #1 on: December 06, 2022, 08:41 PM »
Clever idea! First I heard of that innovation.
Offline StanB
« Reply #2 on: December 07, 2022, 01:02 PM »
cool idea. I was thinking about doing this to my vaccum bag plenum plate. cut it in two so it is not ridiculous to manhandle. nice to see it works in practice!
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM S ET | MX 1200 E MIXER | DF700 XL | PDC 18 | TID 18 | ConuoroKA 65  | Kapex KS120 REB | MFK700| RTSC 400 | LS 130 EQ
Offline PaulMarcel
    • VoilĂ , my blog
« Reply #3 on: December 07, 2022, 06:02 PM »
I did that to my plate with plain Dominos years ago before the connectors. Made it so much nicer to have multiple-size plenum plates depending on the configuration. May have to pull them out and add the connector hardware. Excellent idea.
Offline cpw
« Reply #4 on: December 07, 2022, 07:40 PM »
I did the same thing for a Lego FIRST table; so we could break it down into 3 sections instead of just a more difficult to handle 4x8 sheet of plywood.  They work great for this kind of application.
« Reply #5 on: December 07, 2022, 11:07 PM »
I've used these connectors to attach a face frame to a cabinet that may in the future need to be disassembled.
« Reply #6 on: December 08, 2022, 09:33 AM »
Thanks for the replies.
Might mention I bought the box of connectors here on the FOG. The seller only needed a few for his application and sold the rest. He also made a drill guide block for boring the face hole and it worked great - no need to purchase the fancy Festool jig if you only have a few to do.
Another side note. I purchased a Parf 2 system to drill the holes in the slabs but then found a sign shop less than a mile from my house has a CNC to drill them. With the connectors I measured the diagonals of the extreme holes and couldn't believe they are within 1/32" over the 8' length. Two things I would have done differently: 1) carried the 90mm spacing across the 3 slabs. 2) had less clamp openings (great for clamping but I've lost things falling through them 100's of times).
