The current sensing device I mentioned in my post earlier will do exactly what you want.
When you power up your saw it will sense the current draw and close a switch which you use to power a relay the relay sends the power to your dust collector and turns it on automatically. When you turn the saw off it will take power off the relay turning off the dust collector
Those are cool but Pricey. If you don't have a blast gate to automatically open & close all you need is a current switch and a relay, much less expensive here's an example of a current sensing switch:
here They are not hard to find.
It's a relatively easy DIY project.
Scott
Hi scott
So as I'm cleaning the desk minutes ago and getting receipts for taxes(accountants screaming) lo and behold I find the page I ripped out of the book I knew I had. surprising enough it was from rockler. I called immediately and placed an order for Pt# 29537 dust collector auto start module 220v $62.99 Yehah!!! life's good. Then the guy tells me it was phased out and no longer available. DA####M. So close!!!! Go figure.
Then your reply came back and you have answers. The page you listed doesn't come up for me. If you know a part # for one of these relay/sensors that would be helpfull. grainger is nearby would they have it?
Bill
I like the EASY part.
[/quote]
