Author Topic: DuoDübler DD40 G MaxiMAX im MAFELL-MAX  (Read 3249 times)
Offline Richard M
« on: October 11, 2014, 06:01 PM »
Anyone use one? Does it work as advertise?  My primary use would be indexing cabinet boxes.
Offline Loren Woirhaye
    • LAwoodworking.com
Re: DuoDübler DD40 G MaxiMAX im MAFELL-MAX
« Reply #1 on: October 11, 2014, 06:04 PM »
It works.
Not the same as a construction boring machine though.   It's about as accurate, just slower.
Offline Richard M
« Reply #2 on: October 11, 2014, 06:23 PM »
Thanks for your reply. I assume you have actually used one. Any idea if one could make this work with a Festool vacuum?
    • LAwoodworking.com
« Reply #3 on: October 11, 2014, 06:27 PM »
It works with a Festool style hose.
The cutters build up a lot of heat in use.  It's possible to "cook" the carbide if you drill too many holes too fast in hard material.
I found more affordable cutters than the Mafell ones from Routerbitworld on Amazon.  CMT I think. 8mm shanks.
Offline Steve Rowe
  • Teach them safety when they are young.
« Reply #4 on: October 11, 2014, 06:41 PM »
I have a DD40P and it does work as advertised.  I use it with the CT vacuum and the hose fits fine.  Unlike the Domino, you plunge this as fast as you can to avoid overheating the bits.  The one quirk that takes getting used to is the bottom hangs down and is not flat like a biscuit joiner or the Domino.  All in all, this is a fine machine.
Offline Steve Rowe
« Reply #5 on: October 11, 2014, 06:57 PM »
I forgot to mention that CMT does make bits specific for the Duo-Doweler that are less expensive than the Mafell bits.  Tom Bellemare had some of these drop shipped to my door directly from Italy just because he is that kind of guy [wink].
Offline Richard M
« Reply #6 on: October 11, 2014, 07:13 PM »
Yes, I noticed that in the video. Both the fence and the part that hangs down has the tab the line up with the Dowel template.
Offline jimbouk
« Reply #7 on: October 12, 2014, 10:16 AM »
I have one. Its an awesome tool.
BHC 18, TSC 55REB, OF 1400, MIDI, TS55, TRION, Df500, CSX...
