Two words. Not always.
There are setups that just don’t work with a drill press. Often, I will use a drilled dowel to limit depth. Works, but a really solid collar type stop is sweet.
The screw doesn’t touch the drill bit. It tightens the collar around the bit. Probably expensive to make.
