Author Topic: Drill Press: The Cats Meow for Woodworking.  (Read 5969 times)
Offline martin felder
« on: December 29, 2019, 06:16 PM »
I was reading a couple of posts about drill presses, and saw the Nova referred to as the "cats meow" of drill presses.  I have a Powermatic.  It too has some bells and whistles - easy speed adjustment without changing belts, laser.
However, it just does not seem all that rigid and stable.  I got a Woodpeckers accessory table and fence, but to me it seems flimsy. Often I end up making a mark on the wood, lower the bit to the wood, move the wood around, and then cut while holding the wood.  Sometimes I regret not using a clamp, but I have had the clamps fail me.
Anyhow, I came across this 1982 Rockwell radial drill press
https://sawmillcreek.org/showthread.php?146681-Benefits-of-Radial-Arm-Drill-press
Looking further, I found out it was a machine restored by a guy named Shane who had it on a shop tour video he posted
http://www.youtube.com/watch?list=PLURiUR4pBzqdYJwePugb9fJ29fNRQIk9x&time_continue=9&v=Nm0iLunAB7U&feature=emb_logo
Just a matter of opinion, but to me, a drill press like that is the cats meow!  I am not sure what that is worth, but I believe often these guys get them in not so good shape for very little money, but have the skills and devote the time to a restoration process that provides them with a machine better than money can buy new.
If I had that machine, I would make a table with a fence and stops and put is in line with my miter saw so there would be a lot of room.  Since the table does not raise or lower, and since the drill is what moves,  I would think that would allow one to leave not only the table stationary, but also the fence stationary making it very easy to index with stops.
Anyhow, I just thought some of you may find that drill press interesting.
Offline rvieceli
Re: Drill Press: The Cats Meow for Woodworking.
« Reply #1 on: December 29, 2019, 06:42 PM »
Martin if you are interested in radial drill presses here is a smaller Carlton that you won't have to worry about flimsy.  [wink]
Ron
Offline RJNeal
« Reply #2 on: December 29, 2019, 09:21 PM »
[ Attachment Invalid Or Does Not Exist ] I like my Boice Crane drill press. Gear driven three phase.
I enjo6ed the video on the radial drill press.
We had  a 12 or 16” column by 6 foot travel. Big machine. Everyone was scared to use it.  Sold itit to a welding shop in Napa.
« Last Edit: December 29, 2019, 09:27 PM by RJNeal »
Offline magellan
« Reply #3 on: December 29, 2019, 10:51 PM »
Great video.  We also had two of these at work. One was. 4 ft and the other a 6 ft.  I believe one had a 12” Column and the other a 16” column.  I used it for many things. I believe we had bits up to 3.5”.  Our bit racks looked like a torpedo rack with all the bits.  Most guys never took the time to learn how to use it so they stayed away from them.
The real shame was the company did away with our fabrication department and they scraped both of them and almost every other huge machine we had.  They claimed liability reasons. Sure a waste of fine never to be made again machinery.
Thanks for sharing
Offline demographic
« Reply #4 on: December 30, 2019, 03:10 AM »
Thanks for sharing
One of the places I worked at whe  I was a teenager had something I knew of as a Radial Arm Drill, anyway it was made by Cinncinati (might have been Bickford but I think there was a milling machine in the shop by Cinncinati Millacron so can't quite remember for sure) and I can remember drilling out to 65mm with it for lifting eyes.
Think it could go as slow as 28 rpm and it was a beast of a thing that kind of scared me a bit.
Not having much instruction didn't help mind, it was kind of "Use that, that does that and that locks/unlocks that and thats the speed, there you go son theres 50 of those to do for Vickers" and I was pretty much left to it.
Shortly after then the company closed down as I think it got a lot of its money from defence contracts and a lot of the money went out of that when the USSR colapsed.
Offline StanB
« Reply #5 on: December 30, 2019, 08:05 PM »
@martin felder walker turner has a similar radial drill press. I have been looking for a decent one for a while now. I agree that this would be an amazing machine to complement a shop.
OF1010 EQ Router | MFT/3 | DF500Q | Mafell P1CC | ETS EC 150/3 | CT 36 Auto Clean | TSC55 | LR32 | OF1400 EQ Router | ZOBO Metric Set | CXS Li 2.6 - 90 Limited Edition | Universal Cleaning Set | HKC55 | Centrotec CE-SORT | RO150 FEQ | DTS 400 | RO90 DX | CTSYS | C18 Drill | SysLite KALII | Syslite STL 450 | RAS 115 E | OF2200 EB | OSC 18 Vectoro | VAC SYS SYSTEM SET | MX 1200 E MIXER | DF700 XL | PDC 18 | TID 18
Offline EdL
« Reply #6 on: December 31, 2019, 01:25 PM »
The Walker Turner was the predecessor to the Delta, When Delta bought WT, they kept it in the line-up.
Over the years they were had 3 different base styles, enclosed cast, cast leg and finally sheet metal. There were also variations in the number of speeds and stroke length.
Delta was still selling them in the mid 2000's
I've had mine for a few years now, wouldn't know what to do without it.
Ed
« Reply #7 on: December 31, 2019, 08:34 PM »
That Carlton is an impressive machine and an amazing example of the engineering and quality that went into the building of vintage metalworking machinery.
If I had unlimited space and someone gave me that machine in that condition, I would proudly display it, but for woodworking, I would favor something smaller.
When I saw that drill press that I referenced, I thought that would be of all of the drill presses I have seen, one I would most want to have for a woodworking shop where things made are cabinets and furniture.
Some day I would like to have a radial drill press.  However, I have not found many examples of fully restored machines.  For me, I would have to get one fully restored because I lack the machinist skills to deal with a machine that is at high risk for a mechanical problem and there is no customer support from the manufacturer for sure.  Still a risk, but less risk.
« Reply #8 on: December 31, 2019, 09:27 PM »
That little Rockwell 1982 radial drill is indeed pretty sweet. I never knew they made them that small, my only real life experience is with the larger 8"-10" column radial drills...and they were a force to be reckoned with. [eek]   A Bridgeport is chump change (power wise) compared to a large radial drill.
« Reply #9 on: December 31, 2019, 11:54 PM »
So this drill press thing is very interesting to me. I don't know what it is but I've always had a hankering for them as they are fascinating machine tools. So simple in their design (think minimalistic Wabeco stand with a drill attached) yet so versatile.
My current modern favorite is a Nova Voyager or better yet a Nova Vulcan. They have all the bells & whistles and convenient amenities, and are easy to assemble and light enough to transport into the basement down a flight of stairs. Reliable, equipped with digital controls and readouts and so much more of what we're accustomed to in the present century. Just yank the keyed chuck and replace it with a good keyless and you're good to go.
And then...there's the old timers, that were relied upon for years upon years to perform their operations on a daily basis, day after day, year after year.
I have an older Delta manufactured in the 80's that weighs about 300#. It's worked well for the 30 years I've owned it. An Albrecht chuck and a few mods brings it up to modern standards. However I'm torn between old school and new school and the 1982 Rockwell radial drill just exacerbates the situation. That's a pretty sweet drill press despite the minuscule 1/2 HP motor mounted on it. Don't get me wrong, 1/2 HP is fine for wood, but it's not fine for metals. I also love the production table mounted on it.
So, over the years I've been looking to add a "real" drill press to my shop. These are my 3 favorites considering that anything in excess of 600# will be difficult for me to put on my back and carry downstairs.  [big grin]
Powermatic 1200 with VFD...continuously variable speeds from 250-4600 rpm and it's just under the 600# limit.
Clausing 15" or 20" series with VFD...continuously variable speeds from 150-2000 rpm, however it pushes the scales at 630#.
Finally an Ellis 9400 with VFD...continuously variable speeds from 0-1200 rpm. Obviously focused more on the metal market than on the woodworking market. However it also tips the scales at 675#.  Like the Voyager it also has an electronic reversing feature for automated tapping.
« Last Edit: December 31, 2019, 11:58 PM by Cheese »
Offline derekcohen
    • In The Woodshop
« Reply #10 on: January 01, 2020, 05:53 AM »
If I wanted to look at machines, collect them, then I would have Shane’s workshop. The drill he has is spectacular. Oh my ... all the old machines he has restored are spectacular!
But if I want a drill press to use, and one that will take my skills and work up a couple of notches, then I will talk about the Nova Voyager I recently purchased. For 25 years before this purchase I had a Taiwanese floor standing unit. It did the job - it does not take much to drill holes ... heck, I drill holes with a brace by preference for some holes ... but the Nova is a different beast, for a different mind set, and for different tasks. It has a beauty of its own, just a different type of beauty ...
I still love Shane’s ... sigh ...
Visit www.inthewoodshop.com for tutorials on joinery, hand tools, and my trials and tribulations with furniture builds.
« Reply #11 on: January 01, 2020, 01:05 PM »
When comparing the Nova to the Clausing and others, they are similar in that the head is stationary.  I did not get to see how the head moves up and down on Shanes, but is sure seems very easy to move the head from back to front and I would imagine there would be no flex.
I have never used a drill press like Shane's and never even saw one like it in person, but I love the idea of a stable non-moving table that is what a radial drill press is all about (in addition to the ability to drill farther away from the edge of the workpiece.  I think that a fixed height table would really open up options for fences and stops.  I could imagine being able to walk over to the drill press equipped with a large table at a height that will be flush with other things that open up more table support,  setting the stop to the marking like on a miter saw, setting the distance from the edge of the workpiece, and drilling the hole.
« Reply #12 on: January 02, 2020, 12:54 AM »
Offline Mario Turcot
« Reply #13 on: January 02, 2020, 02:04 AM »
That drill press  [jawdrop] no but  [jawdrop] seriously  [eek]
@derekcohen How did you like your table. Do you feel you have enough clamping capability?
I am at drawing mine and any input is welcome  [wink]
« Last Edit: January 02, 2020, 02:26 AM by Mario Turcot »
Mario
Offline Jiggy Joiner
« Reply #14 on: January 02, 2020, 09:19 AM »
I love the old pillar drills and presses. We’ve had a few including Meddings and a couple of Fobco Stars, and I really think they were built to last a lifetime but’ I absolutely love the Nova Voyager, there really is nothing else like it, and it’s easy to use and efficient.
Since I’ve had mine, I do actually use the various speeds now, where as with the belt driven machines, I tended to use what I considered to be a general setting, and plodded on. As Cheese mentioned the stock chuck and arbor are probably it’s only weakness but, easily replaced.
I’d recommend the Voyager to anybody, and the smaller Viking looks superb too.
@Mario Turcot I suppose the best size table, would be as small as you could get away with. In my case, the tables on our other drills proved to be too small a lot of the time. So I made a new one for the Voyager at a more suitable size. I didn’t want a cut out for the height crank handle, so I replace the crank handle with a wheel.
My overall table dimensions are:
750mm Wide x 450mm Deep x 35mm Thick.
« Last Edit: January 11, 2020, 05:39 PM by Jiggy Joiner »
« Reply #15 on: January 02, 2020, 11:55 AM »
My actual design is 760mm x 560mm x 36mm with a half moon in the back. I want to be able to puish back the fence as far as possible. No crank notch here too  [big grin]
I ordered an alum wheel crank and shaft + bearings to go with the coppler I found a few months ago  [wink]
I was wondering about Derek table, because in my desigh I have the same T-track design Woodpecker have. Two parallel track of ~300mm and another track across the front table. I was hesitant to use T-track at the beginning, because of the chips and dust getting clogged in the tracks.
edit: Wait, I just realized Woodpecker table do NOT have a front track  [eek] wondering where I saw that  [embarassed]
Mario
« Reply #16 on: January 02, 2020, 01:37 PM »
After I’d finished my table, I wondered if I’d got carried away with the channels but, they’ve proved to be really useful for all kinds of clamping.
They don’t clog, as I have an extraction port, and if that misses anything I just vacuum them when I’m finished:
« Reply #17 on: January 02, 2020, 01:49 PM »
That is for sure a nice table  [thumbs up]
I'm using the Lee Valley quad track. They will hold in place using 1/4-20 bolts. I'm always affraid of clamping too tight that the track would lift from the wood  [eek]
Mario
Offline rvieceli
« Reply #18 on: January 02, 2020, 03:06 PM »
Mario I think you would like another t track centered in front of the middle of your table. Doesn’t have to be full length, just a shirt piece parallel to the others but in front of your insert. It allows you to employ a stop against the workpiece.
Ron
« Reply #19 on: January 02, 2020, 03:08 PM »
I see what you mean Ron, good idea. I'm about to cut the first layer of two 18mm BB. After that I will have to take a decision about the final placement of the T-tracks.
Thanks!
Mario
Offline derekcohen
    • In The Woodshop
« Reply #20 on: January 02, 2020, 06:14 PM »
Hi Mario
I have not used the drill press much since building the table ... I am travelling in Europe presently. What use has been positive.
I'll post again once it has been in use for a while.
Regards from Berlin
« Reply #21 on: January 03, 2020, 05:58 AM »
Hi Mario, I was always concerned about lifting the channels with the clamping pressure but, it never happened. I think because the pressure doesn’t need to be too much to hold the workpiece. I always tighten the clamps steadily until the workpiece cannot move, and with a couple of clamps, there isn’t a great deal of pressure.
As a belt and braces approach with the new table, I used epoxy resin and the longest coarse thread screws I could get away with, to fix the T channels.
Offline Gone
« Reply #22 on: January 03, 2020, 08:57 AM »
If you use your Drillpress for a lot of varying woodworking operations you will find the high fences you're showing will interfere with the chuck. The fence Derek showed with the center opening is ideal and the lower profile fence found on the Woodpecker drill press addon table is most ideal. Being easy to remove is also a big bonus.
« Reply #23 on: January 03, 2020, 10:17 AM »
No, no problems with the fence and chuck, the workpiece can be moved away from the fence with spacers if the need arises. The table can be completely removed in seconds.
« Last Edit: January 03, 2020, 10:19 AM by Jiggy Joiner »
« Reply #24 on: January 03, 2020, 11:11 AM »
I originally purchased a Rockler drill press table and I did raise the U-channels from using too much clamp force. The channels were held in using #6 wood screws.  [mad]  I removed the channels, added some PL400 and replaced the wood screws with #6 flat head screws threaded into T-nuts.
The main reason I switched over to the Woodpeckers table is because their U-channels are stronger and fastened to the table using 1/4" bolts and T-nuts.
Offline rvieceli
« Reply #25 on: January 03, 2020, 11:21 AM »
All this drill press talk reminded me to do some maintenance on mine. 😃
1963ish 16 inch ElectroMechano 601J benchtop model. Proudly made in Milwaukee Wisconsin
Continuously variable from 150 to 4000 lower range is gear driven. It got a new belt, lubed and gear box oil checked.
Ron
« Last Edit: January 03, 2020, 11:27 AM by rvieceli »
« Reply #26 on: January 03, 2020, 11:42 AM »
(Attachment Link)
That’s much more substantial  [thumbs up]
« Reply #27 on: January 03, 2020, 11:45 AM »
“ fastened to the table using 1/4" bolts and T-nuts. ”
If the head is inside the channel and the t-nut is buried in the bottom of the table, how is it tightened?
Offline jeffinsgf
« Reply #28 on: January 03, 2020, 02:29 PM »
Bad photo...or at least inaccurate. What looks like a bolt head is actually a hex nut...which would work, but that's not what we package. Flat head machine screw (1/4-20) comes up from the bottom of the table and threads into sliding T-nut in the track.
Offline jeffinsgf
« Reply #29 on: January 03, 2020, 02:30 PM »
(Attachment Link)
Ron
If that ever needs a new home...let's talk.
« Reply #30 on: January 03, 2020, 02:41 PM »
Mine also uses t-nuts however this photo is from the Woodpecker site. The package 1, package 2 & package 3 all use the same photo.
https://www.woodpeck.com/drilling/drill-press-tables/complete-woodpeckers-drill-press-table-package-1-includes-36-fence-2-molded-flip-stops-2-hold-down-clamps-1-filler.html
Offline jeffinsgf
« Reply #31 on: January 03, 2020, 02:44 PM »
Yeah...I see that. It's on my list now. I'll get it fixed sometime soon.
Offline derekcohen
    • In The Woodshop
« Reply #32 on: January 03, 2020, 03:24 PM »
There are two features about the WP table I dislike that decided me on building my own (I posted more details of this in an earlier thread) ...
The first was the veneered edges. I have seen a number made this way, and they all chip or peel away.
The second feature was the square insert. This does not make sense as the drill is centred on it, which means that (if you use it that way), the insert is a one-shot user, and will need to be replaced frequently.
I made mine off set, and round. Making it round was harder but, together with the offset, it may be rotated many times before it needs to be replaced.
With the Wixey laser ...
Instead of a lamination, this table is solid UHMW. I don't think that the laminated MDF is as big an issue, but I could not turn up the opportunity when I came across UHMW sections at a scrapyard. It is very hard wearing and this one has good non-slip.
Regards from Berlin
Offline jeffinsgf
« Reply #33 on: January 03, 2020, 03:46 PM »
Finding that piece of solid UHMW would have been enough to send me to the shop to make my own, too. But just to be sure things are clear, the edge banding is not veneer or laminate. It is a vinyl edging that is bonded on in a huge press and trimmed afterward to the point I can't catch my fingernail on it anywhere (I just tried after seeing your comment). I have never seen one returned because of chipped edge trim...or heard about the issue from Customer Service.
I like your round insert, but not everyone is equipped to make round inserts...everyone can cut 1/2" material relatively square.
Offset positioning is just a matter of moving the table a little forward or backward when mounting...it won't ever be as efficient as your circles, but it certainly can be better than "one and done".
Offline 08G8V8
« Reply #34 on: January 03, 2020, 05:04 PM »
I just recently installed my Woodpecker table. Yeah, I liked the idea of a round insert, but decided to do as suggested and offset the table forward by about an inch and adjusted the tracks for this position. I not get any way near as many positions to use prior to replacing, but can at least get 4 rotations, flip and get 4 more.  It has also been suggested to chamfer the corners for an octagon with 8 rotations and 8 more after flipping. I will give this a try too. At least it gives more flexibility than just keeping it centered.
« Reply #35 on: January 03, 2020, 05:26 PM »
I learned from previous tables that circular inserts are a better option than square or rectangle, and the bigger the diameter (up to a certain point) the better.
Offline Bob D.
« Reply #36 on: January 04, 2020, 11:51 AM »
Make a round insert that fits in the square recess in the WP table and offset front/back or left/right and you're good to go. You can spin it as often or as many times as you wish.
A circle template of the required diameter with a guide bushing like the set used for making butterfly inserts would let anyone quickly route the recess for the insert as well as make new inserts whenever they are needed.
Offline derekcohen
    • In The Woodshop
« Reply #37 on: January 04, 2020, 12:38 PM »
... I like your round insert, but not everyone is equipped to make round inserts...everyone can cut 1/2" material relatively square...
As mentioned, the circular sacrificial disks are 1/2" thick MDF. I found it quicker to saw them fractionally oversize on the bandsaw, and then turn them on the lathe. This literally took moments. I made several. They will last a while since they are also reversible.
Others have suggested a using a bandsaw or router table circle jig, or hole saw cutters.
Regards from Berlin
« Reply #38 on: January 04, 2020, 03:19 PM »
@kcufstoidi
This is why I choose that type of fence, it can be used on the flat side as well.
@Michael Kellough
My bad, I didn't explain much. I'm not using t-nut sprung but standard nuts. a hole is drilled through the bottom layer and the nuts and washer are tighten from under the table. The tracks can be relocated or remove quickly.
@Jiggy Joiner what is the size of your insert? Looks like 120mm. I have forstner bits up to 2 1/2" so the insert need to be at least 120mm to be somehow efficient  [big grin]
I plan to make a 12mm pocket on the top layer with the CNC, prior to glue up.
« Last Edit: January 04, 2020, 03:23 PM by Mario Turcot »
Mario
« Reply #39 on: January 04, 2020, 03:33 PM »
@Mario Turcot Hi Mario, mine are 170mm diameter x 18mm
« Reply #40 on: January 04, 2020, 03:34 PM »
Wow, I was off a tid bit  [embarassed] yeah that big of an insert should cover all my bits  [wink]
« Last Edit: January 19, 2020, 11:10 AM by Mario Turcot »
Mario
« Reply #41 on: January 04, 2020, 03:43 PM »
Yes, I use various large Forstners and hole saws, so wanted the inserts fairly large.
The size works well for me, and if I need to use larger diameter bits, that won’t go within the inserts diameter, I just use a piece of sacrificial ply or MDF.
Most of the time, the 170mm is fine.
It also allows holes to be drilled into the inserts, to take various sanding drum attachments if needed  ;)
« Last Edit: January 19, 2020, 10:36 AM by Jiggy Joiner »
« Reply #42 on: January 19, 2020, 02:45 AM »
Some day....vintage restored radial drill press.... I hope.
With my current drill press or a future upgrade, there is still the issue of the table-fence.  I currently have the Woodpecker as shown by others in this thread.  I do not like their clamps that fit in the T track with 1/4 inch bolts.  I tend to just try to hold the wood, and at times regret that decision.
 I was at Woodcraft this past week and playing with the Automaxx clamps and though this would be nice.  I bought one.  The problem is that what secures it to a T track is a 5/16 and that does not fit on the Woodpecker T track which is only wide enough for 1/4 hex.
So.... I think I am going to dado a channel in the table to allow a wider T track.
It seems like the Kreg clamps are superior to the Woodpeckers..... but I have not had the opportunity to use my clamp yet to know for sure.
Offline jeffinsgf
Offline hdv
« Reply #44 on: January 19, 2020, 09:15 AM »
Hi Martin,
I had the same problem with a Kregg Bench Clamp (which I do like a lot by the way). I solved it by buying their Bench Clamp Base. I removed the bolt and knob and replaced them with two washers and a wing nut. One washer and hex end of the bolt go into the T-track. The other washer prevents the wing nut from dropping into the clearing for the head of the original bolt in the base. The wing nut is used to fix the clamp in place from above. Any other type of nut that can be fastened by hand would work just as well. I am not near my shop at the moment. If you want I can make a photo when I am back home.
« Reply #45 on: January 19, 2020, 11:34 AM »
Here are some Besseys that are similar in function. I adapted these to be used with 80/20 extrusions. The Besseys have a 20 mm post on the bottom which can simply be unscrewed. This leaves a 1/2" x 20 tapped hole in the bottom. A new mounting stud can be machined from a 1/2" x 20 hex head bolt. This stud fits 5/16" tracks however, it could be machined to a smaller profile that would work with 1/4" Woodpecker track.
Better yet, machine 3-4 for 5/16" use and 3-4 for 1/4" use and then just swap out the studs when appropriate.
On another note, I regularly use the Woodpecker flat aluminum clamps on my table and have not had any issues.
https://cdn.woodpeck.com/media/catalog/product/cache/1/image/1800x/040ec09b1e35df139433887a97daa66f/d/r/drill-press-table_1_07.jpg
Offline rvieceli
« Reply #46 on: January 19, 2020, 12:43 PM »
Lee Valley makes the plates Cheese references, but they also make a t track mounting plate for those clamps as well that uses 1/4 inch bolts.
https://www.leevalley.com/en-us/shop/tools/hand-tools/clamps/71461-t-track-toggle-clamp-plate-and-bessey-auto-adjust-clamps
They also sell the whole deal.
https://www.leevalley.com/en-us/shop/tools/hand-tools/clamps/103107-t-track-toggle-clamp-plate-and-bessey-auto-adjust-clamps
But frankly the plates are not hard to fabricate and they provide a good exercise in drilling and tapping etc.
Ron
Offline rvieceli
« Reply #47 on: January 19, 2020, 12:57 PM »
Here’s mine. They are designed to fit into some 1/4-20 holes in my table. They could easily be adapted to a t track. The bases on the Besseys are about 2.5 inches square. So length of 2.5 inch 6061 aluminum  3/8 or 1/2 inch thick could make a few.
Ron
« Reply #48 on: January 19, 2020, 05:08 PM »
Very clever ideas.  When I look at the Kreg Automaxx demo,
Towards the end of the demo, they show the clamp being used with the Kreg track (wider opening than the Woodpecker).  What is nice is that unlike the DeStaco and other clamps, you do not have to screw adjust based on wood thickness.  Also, what is nice about the round part that fits into the T-slot, you do not have to turn it to line up like a hex.  Also nice is that you do not need to have a base attached to the clamp and no need to tighten it to the table - just slide and clamp the Automaxx.
If I was able to machine a 5/6 bolt to screw into the Automaxx on one end, and become a bit more narrow right as it protrudes before the rounded head to fit into the Woodpeckers T track like what is shown, then that would be great.  I could just substitute bolts that come with the Kreg to ones that allow me to have it fit the Woodpecker slot.
However, I do not have anything to machine things and I do not believe these are commercially available for purchase.  So.... I think I will be making dados in my table at some point and adding 2 Kreg tracks.
« Reply #49 on: January 19, 2020, 06:44 PM »
The Bessey unlike the DeStaco and its clones, offers an automatic internal spring adjustment feature that varies from 3/4" to 1 3/8" depending upon the clamp you select.
So, if you typically use 5/8" thick drawer material it will also automatically adjust to clamp up to 1 3/8" thick material.
https://www.bessey.de/en-US/BESSEY-Tools-North-America/Products/Clamping-Tools/Auto-adjust-toggle-clamps/Horizontal-toggle-clamp,-flanged-base
« Reply #50 on: January 20, 2020, 12:51 PM »
Good to know.  Thanks.  I never really paid any attention to these Bessey clamps and did not know they had that ability to adjust.  They would have been better than DeStaco for my dovetail jig as then I could go from 5/8 to 3/4 thickness without adjustment.
Still, they need a base which then goes into the slot.  Also, the Automaxx with the 3 and 6 inch sizes would seem to be easier to use.
Unless someone knows where I can get a bolt like what was shown that will allow the Automaxx to be used with the Woodpecker table, I will just dado additional tracks for the Kreg, front to back, outside and parallel to the current red tracks.  That keeps options open and should not be that hard to do.
« Reply #51 on: April 25, 2021, 09:43 AM »
I am now selling what I think is the "cats meow" for drill presses.
https://www.festoolownersgroup.com/classifieds/fs-the-ultimate-drill-press-for-woodworking-the-rockwell-ram-radial-arm/msg640913/?topicseen#msg640913
https://www.ebay.com/itm/254955172730?hash=item3b5c83337a:g:sJIAAOSwhnVghOPF
Actually, for it to really be the cat's meow, that would be to take this drill press, add a power lift and modify it so you can change the RPMs using a speed adjustment knob.
