Author Topic: Does Anyone Make a Wide Bearing Router Bit  (Read 2277 times)
Online Bob D.
« on: August 31, 2017, 04:48 AM »
Was looking for a top bearing router bit with a wide (thick) bearing.
All the bits seem to have something with a 1/4" face that rides against
the template. Is there something in the 1/2" range or is there a bit that
will allow two bearings to be stacked together to form a wider surface?
You'll ask why would you need that but I can't go into detail yet.
Offline Roseland
TS55, MFT/3, OF1400, OF1010, CT26, RS100, ETS125, CXS, MFS400, DF-500, Zobos.
Offline tjbnwi
  • Cedar Tucky Indiana
Re: Does Anyone Make a Wide Bearing Router Bit
« Reply #2 on: August 31, 2017, 08:24 AM »
Stack two bearings or look for a bearing with the i.d. and o.d. you want in the height you want.
Either way make sure you have enough collet purchase on the shaft.
Offline rst
« Reply #3 on: August 31, 2017, 09:19 AM »
UltraTrimâ„¢ Solid Carbide Spiral Trim Router Bits w/ Double Ball Bearings  - google this...I buy all my router bits and saw blades thru
toolstoday.com or routerbitworld.com
Online Bob D.
« Reply #4 on: August 31, 2017, 04:54 PM »
Like this?
https://routercutter.co.uk/up-cut-spiral-flush-trim
Andrew
Yes but bearings on the collet end of the bit. I didn't turn up any when I searched. Thanks.
Offline Richard/RMW
« Reply #5 on: September 01, 2017, 07:54 AM »
Ditto what Tom said. ToolsToday is my go-to for bits and they have a nice assortment of cutter's, bearings, etc.
RMW
Online Bob D.
« Reply #6 on: September 01, 2017, 08:13 AM »
Thanks everyone. I went there and found what I think will work.
Offline rst
« Reply #7 on: September 01, 2017, 08:44 AM »
Hope what you found works for you.  I also buy all the blades that I use in my 55, 75, and HKC from Toolstoday...AGE.
