« Reply #24 on: March 19, 2019, 11:59 AM »
@RKA raj the Bessey clamp you want is this one:
https://www.besseytools.com/en/product_details.php?ASIMOID=000000030002de6700040023&ASIMOID_SC=000000030002e90f00070023&ASIMOID_MC=000000000001f3f000030023
Basically the same as the Festool. Bessey makes them for Festool as I recall. About the same list price, but you can sometimes find them discounted or at a place that will take a coupon.
Ron
Does anybody make a quick clamp that has a thicker capacity than the Bessey of Festool ones of just over 6 inches in clamp capacity?
I've been looking for years and have never found one.
If you buy the long Festool screw clamps (489571), you can easily file off the nub that keep the two pieces together and then use the head from the quick clamp (491594) after doing the same filing. If you want to keep the two pieces together, just drill a hole near the nub and put in a small screw/nut.
Never thought of that potential solution. Thanks for mentioning that. I may just do that at some point.
I also didn't know that it was Bessey that made the Festool clamps til I read it earlier in this thread also. That opens this possibility of what I can do to get a longer quick clamp quite possible now.
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus, Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
