Sorry to hear about your bad experience with the Woodpecker lift. Which table did you get (the MDF or the new Phenolic)?
As far as the router goes, it is fairly easy to remove the adjustment screw, but you would only want to do that if the router is dedicated to the table.
All you need to do is remove the red outer cap, remove the brushes, seperate the case from the rotor (this lifts the black plastic plate from the rest of the router) and remove the screw, then reassemble. Sounds harder than it really is.
You should contact Woodpeckers about your experience. From what I've heard they will work with you to get it to your satisfaction. Let us know how it turns out.
-Harry
