Author Topic: Digitally Controlled Router lift with Bluetooth MLCS PowerLift Pro  (Read 319 times)
Offline martin felder
https://www.mlcswoodworking.com/shopsite_sc/store/html/smarthtml/pages/powerlift_pro_2.html
I did a search and could not find this discussed.  For years I have had a router table with the hand crank router lift.  As many of you know there are a number of very similar options available - JessEm, Kreg, Rockler, etc.
I always thought it would be nice to have a router lift that raised and lowered the bit electronically, and so I was searching to see if anything new has come along.
I came across the MLCS option.  I could not find out too much about it.  Has anyone used one?  If all router lifts were the same price, is there any reason one would not want this and instead prefer the hand crank option?
Offline Don T
  • Phoenix, Az
There is also the ready2rout lift and fence that work together. So you might want to take a look at that also.
