Author Topic: 24" planer and 24" jointer rebuild  (Read 1196 times)
Offline WarnerConstCo.
    • Warner Mill Works
« on: April 04, 2021, 09:02 AM »
Figured I could try to post some pictures of my progress rebuilding a couple machines for a customer. I picked these up at his shop right by the Antietam battle grounds. Both these machines came out of a missile silos crating department, so did that 88dy saw.
Both these will get completely disassembled, striped, cleaned, filler, primer, paint.
Everything will basically be brand new, 1950.
Both machines will be getting custom Hermance Helix Heads.
Had some help Friday from my crew. It was a great day.
Sent from my SM-N960U using Tapatalk
Online rvieceli
Re: 24" planer and 24" jointer rebuild
« Reply #1 on: April 04, 2021, 09:08 AM »
Looks good Darcy.
Ron
Offline Holzhacker
    • www.aic-chicago.com
« Reply #2 on: April 04, 2021, 11:27 AM »
Question out of curiosity
Are you going to blast clean all the old paint off and then repaint as part of the refurb? In I think its the 7th pic there's what looks like the base for another machine that looks like it was cleaned down to metal and then repainted.
What kind of primer and paint are you using on that old steel?
thanks, markus
Offline JonathanJung
  • www.timberlightdesigns.com
    • Timberlight Designs
« Reply #3 on: April 04, 2021, 11:28 AM »
I don't know which is more cool, the matched pair of tools, or having the family involved.
Curious, how big is your shop and how much did you get the machines for? I assume you have 3ph or will use a converter?
Offline Oldwood
  • Alberta, Canada
« Reply #4 on: April 04, 2021, 12:03 PM »
Hey Darcy,
I would be interested to see the segmented head disassembled. I had a Wadkin 24" I rebuilt and the segmented head had springs and ball bearings to allow the segments to shift.
It was a job finding the springs as Wadkin could not supply them. I had to have a local shop produce them.
I am curious how  your head looks inside. I mean the one on the planer ;)
Love to see those old work horses put back into production.
Gerry
Confucius
    • Warner Mill Works
« Reply #5 on: April 04, 2021, 12:44 PM »
thanks, markus
I will needle scale them, grind any high spots/seams (although this casting is really nice) epoxy prime, filler, sand, high build primer, block sand, prime, block sand, putty, prime, scuff, paint.  Lot of work.
Yes, that's one I am working on for someone else, its casting was kinda ugly, turned out nice.
Epoxy primer for bare castings
Filler is from napa
Primer is a 2k high build urethane
Paint is do-it best industrial Acrylic enamel (made by SW) sprayed with 2.0 tip hvlp
« Last Edit: April 04, 2021, 12:46 PM by WarnerConstCo. »
    • Warner Mill Works
« Reply #6 on: April 04, 2021, 12:48 PM »
My shop is 23k sqft.
1200 amp 3phase 240v delta service.
I am rebuilding these for a customer, no idea what he paid for them.
My kids have been following me and helping since they could walk. From jobsites to my different shops.
My oldest just pulled a counterweight, radiator and waterpump on a Nissan forklift a week ago for me.
« Last Edit: April 04, 2021, 12:52 PM by WarnerConstCo. »
    • Warner Mill Works
« Reply #7 on: April 04, 2021, 12:50 PM »
Hey Darcy,
Gerry
Oliver just used Springs inside the sections that push against splines on the shaft.
I usually just measure the springs and call one of my suppliers. Usually nothing special.
Offline Yardbird
« Reply #8 on: April 04, 2021, 01:08 PM »
[/quote]
[/quote]
As much as I love to see the old machinery come back alive (who does not love watching an old hit-miss engine?) the best part is seeing the kids helping.  Most kids cannot even read a tape measure any more and are glued to their phone.  I applaud you for getting the kids involved.
Offline Oldwood
  • Alberta, Canada
« Reply #9 on: April 04, 2021, 02:52 PM »
Hey Darcy,
Gerry
The Oliver sounds like a better system. It is always a learning experience tearing down machinery. The way the designers solved problems is pure genius in some machines. But in others not so much ;)
Confucius
Offline Tinker
« Reply #10 on: April 05, 2021, 10:56 AM »
Darcey, I aprove of kids learning trade.
Here is my son at 5 yrs old. He now has fleet of his own. I never told him he had to learn about machinery. I could not keep him off. I can see your kids taking over the biz and succeeding.
/Users/wayne/Documents/STORIES-MY TRUE/WORK/Butch/Operator copy.jpeg
Tinker
« Last Edit: April 05, 2021, 10:59 AM by Tinker »
Wayne H. Tinker
    • Warner Mill Works
« Reply #11 on: April 05, 2021, 10:59 AM »
Tinker
Its my job as a Father, to show them how to do stuff. Even if they want nothing to do with what I am doing, at least they will learn how to fix stuff and hopefully be able to take care of themselves (especially important with my girls as I don't want them to think they need a guy for that)
    • Warner Mill Works
« Reply #12 on: April 06, 2021, 11:23 PM »
Needle scaled, inside first coat of gloss black, castings epoxy primed and ready for filler work. Paint crew showed up.
    • Warner Mill Works
« Reply #13 on: April 25, 2021, 05:52 PM »
Filler work done.
Forgot I had a lift table.
My son is a getting pretty good at body work.
All this pretty work, won't make a machine preform any better, but with a new helixhead, it sure will look good doing it.
