Author Topic: De-tension bandsaw blades when not in use?  (Read 4090 times)
Offline mattbyington
« on: February 21, 2020, 04:50 PM »
Hey team,
I started a thread about an N4400 I bought recently. The blade came yesterday. I'm so, so excited to use it this weekend.
A very basic question and apologies in advance. I have never owned a bandsaw before.
Should I be de-tensioning the blade after working, or leave it tensioned 100% of the time?
Thanks so much in advance.
Matt
Offline Bob D.
Re: De-tension bandsaw blades when not in use?
« Reply #1 on: February 21, 2020, 04:59 PM »
I always do with mine. And to remind myself I have a caution sign on the BS next to the power switch to check blade tension before use.
I printed this out on some bright yellow paper and glued it to one of those fridge magnets you get in junk mail sometimes.
Offline rmhinden
« Reply #2 on: February 21, 2020, 05:15 PM »
I have a Delta 14" bandsaw with extension.  I do not de-tension the blades, except with I am changing the blades.
Doesn't seem to have harmed it in the 25 years I have owned it :-)
Bob
Offline ben_r_
« Reply #3 on: February 21, 2020, 05:18 PM »
N4400 owner here and I ALWAYS de-tension any blade I have on my bandsaw even if its only going to be sitting over night. Its just not that hard to re-tension it the next day and why risk blade deformation?
Offline Mike Goetzke
« Reply #4 on: February 21, 2020, 05:26 PM »
I de-tension mine - I thought it was more to prevent the tires from deforming than anything else.
Mike
( Edited - when I de-tension I usually don't loosen it all the way because some blades come close to falling off the wheels if you do. )
Found this on Suffolk Machinery web page (lots of other info there too- https://www.suffolkmachinery.com/six-rules-of-sawing.html ):
ALWAYS DETENSION YOUR BANDS
When you are done cutting for the day, take the tension off your blade. Band saw blades, when warmed up from cutting, always stretch; and upon cooling shrink by tens of thousandths of an inch each cooling period. Therefore, blades, when left on the saw over tension themselves and leave the memory of the two wheels in the steel of the band, which will cause cracking in the gullet. When you leave the band on your saw under tension, not only do you distort the crown and flatten out the tires (which makes them very hard), but you also place undue stress on your bearings and shafts. Believe it or not; you can, and will damage your wheel geometry sooner or later and considerably shorten bearing life. You are also crushing your tires or V-belts.
« Last Edit: February 21, 2020, 05:34 PM by Mike Goetzke »
Offline Jiggy Joiner
« Reply #5 on: February 21, 2020, 05:26 PM »
It’s good practice to slacken the blade after use. It’s usually just the turn of a lever, and sometimes lock.
I made warning stickers for our bandsaws, they are stuck near the on off switches.
Not slackening the blade will cause stretching, and depending on how temps change, can be quite drastic and cause tyre issues. Stretching causes premature wear too.
Definitely slacken it of when not in use, at least at the end of each day.
Offline WarnerConstCo.
    • Warner Mill Works
« Reply #6 on: February 21, 2020, 05:54 PM »
Never.
Sent from my SM-N960U using Tapatalk
Offline kevinculle
« Reply #7 on: February 21, 2020, 07:26 PM »
14" Delta with riser block...I leave my saw blade tensioned with no apparent ill effects.
Offline derekcohen
    • In The Woodshop
« Reply #8 on: February 21, 2020, 08:48 PM »
Matt, many will say that they do not de-tension, but I always do so. My concern is not so much the blade stretching and fatiguing, but the compression of the tyre. The 1" carbide CT requires the highest down force from the N4400.
Visit www.inthewoodshop.com for tutorials on joinery, hand tools, and my trials and tribulations with furniture builds.
Offline vkumar
« Reply #9 on: February 21, 2020, 10:23 PM »
The only thing is that you absolutely have to remember to tension it before you turn it on.  If you dont  you might end up trashing your blade, tires etc.
Vijay Kumar
« Reply #10 on: February 21, 2020, 10:53 PM »
Ya, this is one of those Chevy vs Ford debates.
I purchased a new 8-speed 14" Delta band saw for cutting metal and wood in 1994. The tension with a 1/2" wide blade has never been released since I purchased it.
The original tires are still good, the bearings are fine and it cuts straight.
I've revisited the idea of retrofitting a de-tension arm on the saw many times. Not because I've had issues with the cutting but rather because it makes changing the blade a lot easier.
Don't know Matt...this is a toss-up.
« Last Edit: February 22, 2020, 09:06 AM by Cheese »
Offline tjbnwi
  • Cedar Tucky Indiana
« Reply #11 on: February 22, 2020, 12:30 AM »
Don’t install the blade—problem solved [big grin]
I don’t detension the blade on my Rikon.
Offline ChuckM
« Reply #12 on: February 22, 2020, 12:43 AM »
The newer ones are easy to detension (and tension) and it just takes a second or two. Mine has a threaded rod to unwind...and still, I detension mine everytime after each use.
Offline chewy
« Reply #13 on: February 22, 2020, 01:41 AM »
I've never detensioned mine. Sounds like an accident waiting to happen!
Sent from my SM-G960F using Tapatalk
Offline Bob D.
« Reply #14 on: February 22, 2020, 07:47 AM »
Oh, believe me, YOU WILL trash them.
Don't ask.. :-(
Offline Gone
« Reply #15 on: February 22, 2020, 08:39 AM »
A total and complete waste of time that can be extremely dangerous. I've run my Felder FB600 since new in 2011, through 10's of thousands of lineal feet of cutting with a Woodmaster CT and never released the tension and had no ill effects that these types of discussions generate. The CT takes an extreme amount of tension that the N4400 can't really achieve to the max potential out of the blade. You have to run it with the spring completely compressed to get any where whats needed and its a complete PIA to tension and detension. This type of info is continually repeated and based low end bandsaw with junk construction and soft rubber wheels not something you find in higher end machines like the Hammer N4400. But as always believe and do as you want it will not make any difference to me.
Offline ChuckM
« Reply #16 on: February 22, 2020, 08:57 AM »
Haha. This sounds like the plugged version of "Tails first or pins first" debate.
I think the older, smaller bandsaws and the width of the blade (e.g.,1/8") should be treated differently. Newer bandsaws I have looked into do come with user-friendly detensioners.
It is true that forgetting to tension the blade before turning on the machine could lead to blade damage if the situation is not corrected soon enough. But detensioning is not necessarily the same as loosening. My solution is to leave a block of wood in front of the blade marked in color: "Tension." So far, it has worked...for over 20 years. Others have put their reminders on the power switch like this: https://www.pinterest.ca/pin/683702787154890818/
If in doubt, I would check with the manufacturer whether or not the new saw needs detensioning.
« Last Edit: February 22, 2020, 12:53 PM by ChuckM »
Offline grbmds
« Reply #17 on: February 22, 2020, 09:18 AM »
I don't detention and haven't seen any problems develop over time on my bandsaw. I now own a Rikon 10-325 and, over the 5+ years I've owned it I have not had any problems that I can associate with not detensioning.
Some articles I've read say that, if the saw is used everyday, detensioning is probably not a significant issue. If it's not used everyday, the articles say, possible flat spots can develop and extra stress is placed the blade. I think the danger from forgetting to tension the blade again when using the saw is a bigger issue. I have never noticed the saw running rougher because of flat spots and I've never had a blade fail.
Randy
Offline Gone
« Reply #18 on: February 22, 2020, 09:19 AM »
Every bandsaw and setup has to be treated differently but few understand this simple concept. The discussion here is the OP has a quality bandsaw and is trying to use a 1" blade his saw can't really handle, that pushes it to limit. An 1/4" blade on this saw is no different because of the rubber hardness and the fact it really doesn't deflect like an old 14" Delta would. You will get more damage from the teeth cutting the rubber, tensioning has nothing to due with this. Every bandsaw manufacture that supplies to a potential hobbyist buyer will put the disclaimer in to detension to cover their butt. Even with heavy cutting the blades don't get very hot and the minimal heat they develop has very little effect on the rubber.
Offline ChuckM
« Reply #19 on: February 22, 2020, 09:29 AM »
Could they tell if something goes wrong with the machine under warranty whether the problem is due to not detensioning?
« Reply #20 on: February 22, 2020, 09:51 AM »
We have two commercial bandsaws and a heavy duty pro model. All three are from different manufacturers, and all the user manuals recommend slackening the blade off at the end of each working day.
Ours just have levers, and fine adjustment, so tensioning and de tensioning is a slight turn of a lever.
As I mentioned, we have warning stickers at the on/off switches, so nobody forgets.
I slacken the blades off out of habit, as it was how I was taught years ago.
Each to their own I guess.
Offline Gone
« Reply #21 on: February 22, 2020, 10:01 AM »
Well you are either the sheep, the dog or sheep herder. Your choice. Some old info we were taught is just that, and it just keeps getting passed forward like gospel.
Offline ScotF
« Reply #22 on: February 22, 2020, 12:20 PM »
I do - to prevent issues with the tires. It is simple on mine to unscrew the tension wheel to the right tension. If you are using daily then this would be less of an issue.
Offline Df1k1
« Reply #23 on: February 22, 2020, 12:23 PM »
Laguna bandsaw owner. I always de-tension then leave the door open as a reminder to re-tension the blade. Not sure if it makes a difference but I would rather err on the side of caution. There certainly is nothing wrong with reducing the tension but there may (or may not) be an issue with tension 24/7.
Same reason I always unlock the tension on my fence on my saw stop.  Heck, probably doesn’t make a difference but I feel better
Offline ChuckM
« Reply #24 on: February 22, 2020, 12:35 PM »
Snip
Now, that's clever.
Snip
I know of no table saw users who intentionally leave their saw fences in tension. Some probably forgot to release the lever after making the last cut.
A Rikon 14" bandsaw product description I came across includes this: "...a release lever lets you instantly loosen blade tension to prevent premature blade fatigue and wear to the saw's bearings, tires and spring." Myth or truth (or sales pitch)? Your call.
« Last Edit: February 22, 2020, 12:54 PM by ChuckM »
Offline Bob D.
« Reply #25 on: February 22, 2020, 01:09 PM »
I release tension as I said on my bandsaws, but thinking back I worked in a pipe fab shop for many years and we never de-tensioned the blades on those bandsaws. We had a couple Marvel tilt head vertical bandsaws, I don't remember the particular model but it doesn't matter, we cut 16" WF beams, pipe, and all sorts of steel with them but never released the tension at the end of the day. Didn't seem to bother them one bit.
I do it on my wood bandsaws because that's what the manual advises. It takes only a second but YES it does open you up to the possibility of starting the saw with the blade de-tensioned. Like every other tool in your shop you have to engage your brain first, then proceed to operate the tool which includes ensuring the blade is clear of any obstruction and ready for action.
And yes, I did once screw up and start my 12" bandsaw without checking the tension. Ate the tire on the upper wheel and destroyed the blade. Lesson learned and 15 years later no repeats. :-)
« Reply #26 on: February 22, 2020, 01:48 PM »
...but thinking back I worked in a pipe fab shop for many years and we never de-tensioned the blades on those bandsaws. We had a couple Marvel tilt head vertical bandsaws, I don't remember the particular model but it doesn't matter, we cut 16" WF beams, pipe, and all sorts of steel with them but never released the tension at the end of the day. Didn't seem to bother them one bit.
Good point Bob, thinking back over the years in the machine shops and the engineering model shops, metal cutting band saws were never, ever de-tensioned. The only time the blade tension was released is when the saw blade broke.  [tongue]
    • Warner Mill Works
« Reply #27 on: February 22, 2020, 02:24 PM »
Big difference between a real industrial cast iron saw, with large bearings and large spindles.
These welded steel saws with small arbors and small bearings wont last as long and the manufacturer knows that tension will decrease that time even more before components fail.
It's how they cya.
Offline ChuckM
« Reply #28 on: February 22, 2020, 03:05 PM »
If detensioning were indeed meaningless, shouldn't at least one bandsaw manufacturer seize the opportunity and release a bandsaw model that promoted "detension or retension totally not required" as its a selling point?
Offline Svar
« Reply #29 on: February 22, 2020, 03:12 PM »
Manufacturers that recommend de-tensioning should be adding auto switch. You can't start the saw unless it is tensioned. One could probably DIY it too.
    • Warner Mill Works
« Reply #30 on: February 22, 2020, 03:17 PM »
Last time I checked, Northfield never mentioned it in their bandsaw literature, but I also don't think anyone here is paying 30k for a new 36" saw.
Offline ChuckM
« Reply #31 on: February 22, 2020, 03:59 PM »
I have a Craftsman router. Before I can turn on the router, I need to push the lock button out.
« Last Edit: February 22, 2020, 04:12 PM by ChuckM »
« Reply #32 on: February 22, 2020, 04:57 PM »
I figure that the people who built the machines, know a bit more about them than I do.
So when I’m handing over big sums of money, for machinery, I want it to last. So following warnings and advice that they put in the manuals, makes good sense to me.
All of my petrol power tools, mower, chain saws, brush cutters etc, state not to leave gasoline in the tanks for lengthy periods. So I empty them if they’re not used for a while.
Just another example of taking heed of the manual.
Offline Kevin D.
« Reply #33 on: February 22, 2020, 06:48 PM »
Bob
Ditto here except mine is only 18 years old.  It can even sit unused for many months at a time.  Never had a problem.
Kapex, CT-SYS, SYS-Cart, Pro 5 Sander, CT36AC, TS75, MFT 1080, MF-SYS/2, PS300 EQ-Plus, Parallel Guides Set, LR32 SYS, RO 150FEQ-Plus, OF1400 EQ Plus, DOMINO 500 Q-Plus,  Domino XL, MFK 700 EQ-Set, FS-SYS/2, CT22 w/hose storage, D36HW-RS-Plus, FS 1900/2, FS 3000/2, FS 1080/2-LR32, FS 1400/2-LR32, Gecko, Festool Floor Mat, Festool Stein, Multi-Tool, tape measure, large and small Festool floor mats (foam rubber).
Online cpw
« Reply #34 on: February 23, 2020, 09:41 AM »
I usually detension, unless I forget.  I have an MM16; so a similar class of bandsaw and always keep my 1" blade on it.  Whenever I detension (it is the wheel, not the lever); I open up the top door's lock.  This disengages the micro switch, so the saw can not be started until I close the door; which reminds me to tension the blade.
Offline Bob D.
« Reply #35 on: February 23, 2020, 10:00 PM »
I've thought about doing that. Doesn't seem too complicated to implement.
    • Warner Mill Works
« Reply #36 on: February 23, 2020, 10:15 PM »
Just a limit switch. My 36" fay and egan 950 has one on the top tension assembly. It's more the shut machine off if a blade breaks though.
Offline DeformedTree
« Reply #37 on: February 24, 2020, 02:30 AM »
This makes little sense.
When the blade is tight, it has a load in it.  Just sitting there nothing will change. The blade is not going to stretch just sitting there, if it could, the blade would just fail in use very quickly. The blade has to have the tensile strength the handle the load when tension. Just sitting there won't change anything, the load isn't changing or going over the limit of the blade. No different than a torqued bolt, it has to be strong enough for the pre-load, it won't suddenly snap/stretch just sitting there.   When cutting, the blade will warm, thus get bigger thus get less tight, when it cools back to ambient temp, it will be back to it's normal tension.
Now if the concern is your shop changing temperature when sitting there, maybe, but since blade and saw are all steel, they will largely expand and contract as one.
I've never heard of people doing this, it comes across as just plain dangerous as others have mentioned. If there was a real concern the bandsaws would have an auto-tensioner type device just like belt drives and such. It could always limit the tension in the blade. Plus interlocks like Svar mentions.
Far as shafts and bearings.  They too have to handle the static load of the tension, once they are designed for that, just sitting there loaded won't change a thing. If it did change sitting there, the bearings and shafts would again fail right away.
The saw has to be able to handle the loads the blade sees in use, this is going to be higher than just sitting there.
Maybe there is a concern about deforming a tire in one spot, but again, that sounds unlikely. Maybe there is a concern about parts rusting together just sitting there for long periods of time.
Look around us, everything is under load.  We don't unload the stuff around us. It all either handles the load indefinitely, or it fails right away.  Cycle life can come into play and that is what wears out a machine, but obviously that is when it's running, not just sitting there.
This might be a way to use fear to cause folks to regularly check their blade tension.
« Reply #38 on: February 24, 2020, 08:26 AM »
I don’t know if it matters or not, I slacken the blades usually at the end of the day. It takes seconds, to slacken or tension, so certainly not a problem.
If it doesn’t matter, why do all the manufacturers instruct owners to carry out the procedure in the user manuals?
I’m pretty sure a slackened blade is going to cause zero issues in that state, I can’t imagine the same can be said for a tensioned blade, no matter how minimal?
I even know of a cabinet maker that slackens coping, and fret saw blades when not in use.
    • Warner Mill Works
« Reply #39 on: February 24, 2020, 08:34 AM »
The manufacturers that state this practice, like I said previously, are the ones that build light weight welded steel saws.
They are probably well aware the components will wear out faster.
No where, in any literature did Yates American say to detension this saw.
Offline ChuckM
« Reply #40 on: February 24, 2020, 08:49 AM »
Snip
I'm one of them, with my Knew fret saw (for a good reason: it uses screw friction to hold the tensioned blade in place, and you don't want those screws worn out prematurely)! ;)
As I said, small or hobbyist bandsaws and narrow blades should deserve different considerations, and I'm not surprised that industrial type or huge bandsaws (metal or woodworking) may have different maintenance needs, just like a mining truck may be serviced and maintained differently from a SUV.
As I dug a little more on this topic online, I found many better known and seasoned woodworkers splitting on this issue as well, although I have yet to find any published materials (books or magazines or manuals) that suggest detensioning is unnecessary for any non-industrial bandsaws intended for hobbyists. Perhaps someone should do so, offering their reasoning and research data to support it.
I found someone quoting online a sawblade maker (Timber Wolf blades) saying this:
   Suffolk Machinery----
"You are somewhat correct. We do recommend de-tensioning to reduce stress on the saw but more so to reduce stress on the blade. De-tensioning is more critical to narrower blades than wider blades although tension/strain is relative to the size of the blade and sawing application. We run as much as 37,500 psi on wider blades such as our 2" x .052 thick blade vs. 9,000 psi on a 1/4" blade. Therefore, we recommend it on all blades. "
Since everyone on either side is happy with what they've been doing, they should keep their practice.
Edit: Mark Duginske (who also patented the cool blocks, among other things) has this to say in his book (2007, 2014): "Releasing the tension is good for extending blade and tire life, though, contrary to popular misconception, it has no effect on the spring...."
« Last Edit: February 24, 2020, 09:25 AM by ChuckM »
Offline grbmds
« Reply #41 on: February 24, 2020, 09:47 AM »
Yesterday I asked Alex Snodgrass (Carter Products) whether taking the tension off the blade is recommended or not. I consider his recommendations valid. He responded that he does take tension off at the end of each day, but it was to avoid flat spots on the bandsaw tires and not related to the blade. Since there are potential flat spots, especially at the top and bottom, more vibration is likely when the saw is turned on the next time. However, after the tires warm up, the flat spots disappear and the vibration disappears. No permanent damage to either the blade, the wheels, or the tires, results. I'm sure everyone will continue to do whatever they have been doing, but keeping tension on doesn't appear to be a practice which causes any permanent problems. That has been my experience also.
Randy
Offline ChuckM
« Reply #42 on: February 24, 2020, 09:58 AM »
Interesting that you mentioned Alex who does the Bandsaw Clinic in the Woodworking Shows (for over 15 years?). He is on record to have said (check out one of the youtube videos) to the effect that no one knows a bandsaw better than its manufacturer. At the request of Chuck Bender, he recently installed, among other items, a quick-release tensioner in Chuck's Delta bandsaw. Chuck's video shows his step-by-step process.
« Last Edit: February 24, 2020, 10:03 AM by ChuckM »
« Reply #43 on: February 24, 2020, 10:06 AM »
My machines are commercial, and a heavy duty pro model, they are by no means lightweight. All built in the UK.
From other posts here, it’s clear to me, that slackening a blade, is doing less harm than tensioning one does. It doesn’t matter how big or small the difference, the warnings are there in the manuals, from lightweight to big heavy cast machines. Often the warnings are accompanied by an explanation, stating why this practice is recommended.
Everybody is free to make their own decisions, over many years, I’ve found that reading the actual manual is a wise decision, and taking heed of it is also good advice.
I’ll carry on de tensioning, as the benefits outweigh the negatives (in my opinion)
    • Warner Mill Works
« Reply #44 on: February 24, 2020, 10:08 AM »
But they are probably welded steel construction with small arbors and bearings?
Not in any manual or literature on any American made bandsaw since about 1880, earliest machinery catalog I own.
« Last Edit: February 24, 2020, 10:32 AM by WarnerConstCo. »
« Reply #45 on: February 24, 2020, 10:11 AM »
Exactly, as I mentioned earlier, the manufacturers know the machines they build, better than us.
Why would we have reason to believe their advice is nonsense, or doesn’t really matter?
« Reply #46 on: February 24, 2020, 11:49 AM »
Wow, thank you everyone for such an interesting discussion. I've read everyone's comments, some real great tips in there. I really appreciate everyone's point of view.
Matt
Offline Oldwood
  • Alberta, Canada
« Reply #47 on: February 24, 2020, 12:59 PM »
Another factor is the diameter of the wheels. The 20 to 36" wheels don't stress the band like the 12 to 16" saws do. This stress causes fractures in the gullets of the teeth.
The bandsaws I have owned are a 36" and 24" both big heavy saws and I never detensioned the blade.
I don' think the saws like Darcey owns are going to have a problem and the large wheels cause very little stress on the bands.
Confucius
Offline Gone
« Reply #48 on: February 24, 2020, 01:20 PM »
Curious as what what Bandsaws are still made in the UK or are we talking about vintage stuff like Wadkins.
« Reply #49 on: February 24, 2020, 01:45 PM »
I don’t know which UK companies still make band saws nowadays, as most are gone.
Ours are old but not vintage, well not 1880 anyway.
We’ve got two from Wadkins, and the other is either Start Rite, or Meddings.
Offline Bob D.
« Reply #50 on: February 25, 2020, 06:42 AM »
The attached are from old Rockwell/Delta Bandsaw manuals, one for a 1946 14" model and the other for a 1964 20" Metal/Wood bandsaw.
Both recommend detensioning the blade when not in use.
Offline Joe Jensen
« Reply #51 on: November 24, 2020, 05:16 PM »
Engineer here adding to an old thread.  Metal flexes and returns to it original shape unless flexed far enough to reach "Plastic Deformation".  This is where it bends and stays bent.  If the saw doesn't flex far enough to reach plastic deformation it will return to its original shape.  As far as metal fatigue, regular tension/detention will likely be harder on the blade and the saw than leaving it tensioned all the time.  The tires could develop a flatter spot with tension all the time.  So if you detention to protect, it's likely you are protecting the tires and not the saw or the blade.  I have a 1967 Tannewitz 30" and the manual says nothing about detentioning.
Offline WillB
« Reply #52 on: December 07, 2020, 07:51 PM »
Great input....
After reading this thread, its obvious to me, one size does not fit all regarding this issue.
A few points I never thought about introduced here... the large diameter wheels, 20-36" bend the blade  a LOT less vs. smaller diam wheels...so comparing a 16" saw vs. 36" saw regarding this issue is like night n day.
Seems the blade gullets are also effected, as well as wear on the rubber.
I de tension because I don't use the saw often, and feel the added tension can add wear to blade, rubber and bearings.  While bearings on smaller saws might not fail keeping it tensioned, my guess is the bearings do wear, making them a bit less precisioned when running.  Whether that is a problem, depends on what you use the saw for.  My guess is, for re sawing, de tensioning might reduce rubber and bearing wear, possibly allowing higher precision thin veneer cuts.  For rough cross cuts, or cutting thin wood, cant see any benefit in de tensioning...
I also agree, the manufacturers tend to know more than the users, even if they are erring on the safe side.
