Author Topic: CNC comparison Onefinity vs shark 510  (Read 983 times)
Offline jussi
« on: September 30, 2021, 09:48 PM »
I was kind of all set to pull the trigger on the onefinity when I found a really good deal on a nearly new shark HD510.  I know the seller well and am confident it is in like new condition.  The shark will end up being around $600 more when factoring in shipping for the onefinity.  I will also have to make a base/spoil board for the onefinity.  The shark already has one.  Neither include a router but the shark can use a variety including midsized routers while the onefinity can only be used with the makita trim router.  But in the future I plan on upgrading to a water cooled spindle so I'm not sure it matters.  Any advice from experienced users?
https://www.onefinitycnc.com/product-page/onefinity-woodworker-1
https://www.rockler.com/next-wave-shark-hd510
Offline tallgrass
Re: CNC comparison Onefinity vs shark 510
« Reply #1 on: September 30, 2021, 11:13 PM »
I have seen both. I ordered the onefinity. I have a a great deal of experience with CNC machines. The real question is how do you plan on using the machines. Do you have the metrics equipment to run and check output?  They are much different in size. CNC machines are more expensive to actually run than people think. Making spoil boards is a staple in the CNC router world. So do not let that be a deciding factor.
Offline WillAdams
« Reply #2 on: October 01, 2021, 08:30 AM »
(ob. discl., I work for a competitor)
May I ask why these two machines are being considered?
What sort of work do you wish to do?
Did you consider the warranty for the respective machines? Look over the documentation?
In what way do you wish to approach it, using what software?
If you really want a spindle, there are machines available which have them preinstalled.
FWIW, my recommendation for folks considering a CNC is that they first decide on a project representative of the sort of work which they wish to do and then:
 - draw it up in a CAD tool
 - decide on what material(s) it will be fashioned from
 - import the design into a CAM tool
 - determine what tooling would be used to cut the parts out, and at what feeds and speeds
 - assign Toolpaths
 - simulate the cutting/G-Code in 3D, ideally both in the CAM program and after writing out the file(s) in a 3rd party G-Code previewer
EDIT: if one is successful w/ that, and finds it a workable technique, then one will likely be successful w/ a CNC.
« Last Edit: October 01, 2021, 10:01 AM by WillAdams »
Offline jussi
« Reply #3 on: October 01, 2021, 08:53 AM »
Thanks for the replies. I had a price range of about $3000 and reading up on the different machines in that range it seemed like onefinity was the best in class.  Until the used shark came to my attention.  The previous owner has only had it for a few months and I believe the warranty is transferable.  But I probably should look at the warranty details more closely to see what's covered.
Initially I'll be just using the machine for myself but eventually I'd like to small repeatable projects to sell.  Cutting boards, mailboxes, not really sure yet.  The owner of the shark is a friend and the reason he's selling is because he made enough money from it that he decided to get a bigger machine from avid.  I have limited experience with cnc having owned a craftsman carvewright.  But they use their own design program and it's much simpler and dumbed down.  I'm starting to learn fusion 360 now and hopefully will use that in the future.
Offline WillAdams
« Reply #4 on: October 01, 2021, 09:32 AM »
Fusion 360 works well for folks doing 3D/mechanical CAD (and some folks get decorative work out of it). We have some notes on setting it up at:
https://docs.carbide3d.com/software-faq/fusion360/
We (I work for Carbide 3d) bundle a program which we make freely available: Carbide Create (which is often recommended for use on the Onefinity Forums and by our other competitors) --- it's useful to get started and acquainted w/ the concepts, and there's an optional Pro mode which adds 3D modeling and toolpaths and an engraving mode. Some folks doing woodworking get Vectric software.
You may find:
https://willadams.gitbook.io/design-into-3d/2d-drawing
of interest if you're not familiar w/ vector drawing and CAD concepts, and see:
https://docs.carbide3d.com/tutorials/#shapeoko-tutorials
if you want some starter projects.
« Last Edit: October 01, 2021, 10:00 AM by WillAdams »
Offline jussi
« Reply #5 on: October 02, 2021, 12:16 PM »
Ok I think I’ve settled on the onefinity. Just 2 decisions now and wondering if u guys can help with it
1. Should I go with the journeyman or woodworker model. 48” vs 32” capacity. Right now 32” seems fine but I would hate to regret the decision. Have u guys had occasion where you needed the extra capacity.
2. Should I buy the qcw (1f base) or make my own. Would sourcing the individual parts be much more cost effective or will it be about the same. And even if it is the same price could I build something better myself (ur more rigid structure with more holding options)? If I build myself what is a good supplier to source the material.
Offline Bob D.
« Reply #6 on: October 02, 2021, 01:42 PM »
Not sure but I think the only difference is the length of the X rail. The attached PDF from Onefinity I downloaded a while back and it gives the depth of both machines as 45-3/8.
If that is true you could get the Woodworker model and 'upgrade' to the Journeymen by just getting the longer X rail. Of course you'd need to spread the Y rails and potentially need a larger table if it was a tight fit. I think the Journeyman is ~61 inches wide (see attached).
Offline Bob D.
« Reply #7 on: October 04, 2021, 06:21 AM »
I came across this comparison of the Onefinity with some other CNC of roughly equal price.
https://www.myerswoodshop.com/blog/onefinityvsshapeoko
Offline WillAdams
« Reply #8 on: October 04, 2021, 11:16 AM »
Yeah, you should look up the history of the guy who wrote that, including the memetic video.
Here's a different link:
https://old.reddit.com/r/hobbycnc/comments/puq42c/please_help_me_find_which_cnc_is_for_me/he6e2c5/
which is a bit more reasoned and nuanced.
and see the full discussion at:
Offline Eagle
« Reply #9 on: October 04, 2021, 04:35 PM »
If you are still researching, look into Avid CNC as well. Their benchtop pro models are really good and so are their regular Pro CNC models.
Offline tallgrass
« Reply #10 on: October 05, 2021, 05:11 AM »
Quote from: tallgrass on September 30, 2021, 10:13 PM
If you can swing it get the 48", for the simple reason that you can process a full sheet of plywood without breaking it down. Also these machines can almost never be too big. Within reason. Also remember the dimensions do not necessarily reflect the cutting area. What tends to happen is, when you get more experience , your eyes grow along with your projects. As far as building your own base. If you can afford it buy the base. If this is your first time, remove as many hurdles as you can in the beginning . you have enough to learn.
Offline mattgam
« Reply #11 on: October 05, 2021, 03:35 PM »
I'd also add that in the $3000 price point you should look at cnc4newbies (ignore the name they make beefy machines) and carbide3d.    3k will get you a nice machine from either.  Onefinity does now have an 80mm spindle mount which can be used in lieu of a router and carbide3d and cnc4newbies also have spindle mount options.
I've owned too many hobby level CNCs and my advice is focus on the support and the user communities.  Carbide3d does top notch support and has excellent user forums and facebook group. Carbide3d also has years long track record of quality support. Cnc4newbies recently beefed up their tech support so less history there, and has a solid facebook group, but no in-house forum for community help.  Onefinity is a newer product with rather long lead times.  Their user community on facebook is very active and they have so far been praised on their support but the machines are new so not a ton of history obviously on long term support.  AVID machines are fantastic but when you get done adding all the options a 2'x4' CNC is going to run you 7-8k easily even if they base price is $3999.  AVID is also not a consumer level machine so it isn't what you'd  call an apples to apples comparison
As Will said, size the machine to what you think your normal project is.  You will always want bigger thats for sure, but cost grows a  lot with size due to needing to maintain rigidity.
