Author Topic: Clampzilla Woodpeckers OTT  (Read 7216 times)
Offline ear3
« on: July 10, 2019, 05:33 PM »
This looks really tempting, though they are quite expensive:
https://www.woodpeck.com/ott-clampzilla-4-way-panel-clamp-2019.html
Really impressive that they can generate over 6000 lbs of force, which almost equals what you can do with a Bessey I-Beam.
The only downside is that max width is 38".  Wish they had taken that up to 48, as I've had to do a number of panel glue ups in the last year in excess of 40", but that would have meant almost 5 ft. long clamps.
« Last Edit: July 10, 2019, 05:36 PM by ear3 »
Offline Jiggy Joiner
Re: Clampzilla Woodpeckers OTT
« Reply #1 on: July 10, 2019, 05:43 PM »
What a great concept, I wouldn’t mind a set, even though as you say, quite expensive.
Offline Richard/RMW
« Reply #2 on: July 10, 2019, 05:53 PM »
The concept has been around for at least 25-30 years. Leave it to WP to pretty it up and boost the price significantly. I had a set that I sold when we moved to the shore 10 years ago.
A person so-inclined could start with the kit and, using 80/20, make up an adjustable set of any length.
RMW
Offline mike_aa
« Reply #3 on: July 10, 2019, 06:11 PM »
Shopsmith has a version that has been available for a long time.  They have three sizes, including 48 inches.
Mike A.
Offline PaulMarcel
    • Voilà, my blog
« Reply #4 on: July 10, 2019, 07:29 PM »
Basically the same thing Richard posted from WoodRiver. I have these and love them for how quickly I can change out the caul board for different panel sizes. The side pusher thingy isn't as robust as the one WP offers, but you can easily replace the narrow hard rubber piece with an accurately-sized caul board, too.
https://www.woodcraft.com/products/woodriver-clamping-system
IG: @PaulMarcel328
Offline rst
« Reply #5 on: July 10, 2019, 07:37 PM »
Expensive?...hold my beer.  Plano PC-2L 49-Inch Clamp Vertical Glue Press.  Bought mine years ago, I have a six clamp system.
Offline ear3
« Reply #6 on: July 10, 2019, 08:23 PM »
The key is the side pressure of the WP clamps. I got another brand a while back, forget the name, but they were basically worthless to clamp up anything that was edge joined with dominoes because they didn't produce enough force.
Offline egmiii
« Reply #7 on: July 10, 2019, 10:33 PM »
The Plano seems like a nice unit at a reasonable price. Not much more than Woodpeckers for a similar setup. How do you like yours vs using parallel clamps?
Offline kcufstoidi
« Reply #8 on: July 11, 2019, 08:55 AM »
This clamp like most Woodpecker stuff is overpriced and designed for the tool collecting hobby guys. Really only good for a small selection of clamping needs. 6000 PSI pressure is not needed unless you are straightening improperly prepared material.
 I had the 49" Plano system that could do upto 10' long glueups for 6 years and rarely found it helpful. Painful to load and unload. I went back to parallel clamps on a bench. Making sure your pieces are cut at a perfect 90 degrees, using dominos for alignment and on large projects using slower cure epoxy instead of water based PVA glues helps with no bow units.
A good set of quality parallel clamps is a better investment and far more useful for do a wider variety of panel sizes then this specialty item, IMHO. Guys that run a small shop and do this on daily basis to make a living have a tendency to dismiss a lot of this stuff from Woodpecker.
Offline ChuckM
« Reply #9 on: July 11, 2019, 09:12 AM »
The video is irresponsible to new woodworkers in suggesting that the clamping system can get flat glue-ups from ill-prepared boards. That is a misleading way of promoting a product.
 I visited a small shop (owner couple plus 4 employees) producing lots of solid wood panel tops (for tables and doors) last Sunday to buy some lumber. The owner uses pipe clamps, clamping cauls and marine epoxy and nothing else. No biscuits, no dominoes. No jointers, only a Festool track saw to rip and joint edges. He does have a huge circular saw16", 18"?.
This shop practice from someone who makes flat panels, large and small, for a living for over 10 years.
« Last Edit: July 11, 2019, 09:23 AM by ChuckM »
Offline zapdafish
« Reply #10 on: July 11, 2019, 01:07 PM »
I am tempted to get a pair as I think it would work great with cauls (my bowclamps) but  the price and the width issue.
Offline egmiii
« Reply #11 on: July 11, 2019, 01:25 PM »
I have a feeling that most Woodpecker tools go to DIY weekend warriors with sufficient disposable income. Nothing wrong with that. They produce unique tools that solve problems likely encountered by people who don't do woodworking for a living. Either lack of experience or lack of quality tools is the main cause of problems.
Production guys with deep pockets would likely be better served by a Barth RP or something similar. Very versatile, powerful, fast, and it can square up panels.
Offline grbmds
« Reply #12 on: July 11, 2019, 01:27 PM »
They do look great. However, several years ago I bough 4 Damstom 38" panel clamps and they work great; perfect for any glue ups which are 38" or less. They now sell for $65 apiece at either Rockler or Woodcraft. If you wait for a Rockler 15% off sale and free shipping they would be $55 apiece; four for $220.
They don't exert the same top/bottom pressure, but they line the boards up perfectly and, when clamped together give virtually perfect glue joint line up of the boards.
I always love Woodpeckers stuff because it looks so great! However, in this case, I doubt I'd be gaining anything over the Damstom clamps.
Randy
Offline kcufstoidi
« Reply #13 on: July 11, 2019, 02:43 PM »
Hey got no problem with people buying this stuff with their hard earned money but at the end of day its fluff for the most part
Production guys and deep pockets is rare, hobby guys with great severance packages that don't have to make a living is a better statement. With the price of Barth stuff in NA I put it in the same category as Woodpecker stuff. I've looked at Barth stuff since about 2011 and could never figure out how to recover the investment of at least $15,000.00 to $20,000.00 for a manual unit that could actually do something.
Offline box185
« Reply #14 on: July 18, 2019, 12:30 PM »
The product page has been updated to include a 50 inch bar.
Offline JimH2
« Reply #15 on: July 18, 2019, 04:19 PM »
(Attachment Link)
RMW
I had this kit (you supply the wood and they supply the plastic and metal components). All I can say is that it was not all it was cooked up the be. I ended up tossing it and buying some more Bessey clamps. I have not looked at the Woodpecker's one, but I can guess it is a better implementation.
Update: The kit I am referring to was made by Rockler (I think) and I bought it about 10 years ago. It was marginal and best and I am certain the Woodpeckers version blows it away.
« Last Edit: July 19, 2019, 04:44 PM by JimH2 »
« Reply #16 on: July 18, 2019, 04:42 PM »
I know the actual clamping mechanism is nothing new, I was more impressed by the things Chuck mentioned, which apparently was a sales tactic. So not so good after all.
Offline Richard/RMW
« Reply #17 on: July 19, 2019, 09:26 AM »
(Attachment Link)
RMW
Yep, my limited experience with them 10+ years ago was underwhelming, which is why they didn't make the cut when I downsized. IIRC they didn't totally force everything into perfect alignment, still had to fiddle around to get the edge joints adjusted.
I agree with @ChuckM comment below. I wasn't thinking about newbies not realizing it but the video does lead you to believe that the outcome of gluing up twisted material with the clamps will be a flat panel rather than a large propeller.
I don't know if the heavier WP model will do a better job or not. For my very limited need to do panel glue-ups I just use cauls and K clamps.
RMW
Offline zapdafish
« Reply #18 on: July 19, 2019, 01:03 PM »
Looks like the 50" bars are an add on, cant just get the clamp in 50"
Offline threesixright
« Reply #19 on: July 19, 2019, 03:05 PM »
(Attachment Link)
RMW
What was the problem? The plastic? I thought a 80/20, should work pretty good? Wishful thinking?
Sent from my X using Tapatalk
Offline JimH2
« Reply #20 on: July 19, 2019, 04:43 PM »
(Attachment Link)
RMW
I updated my original post to note the one I had was not made by Woodpeckers. This one was sold by Rockler (I think) about 10 years ago. Nothing to compare between the two other than the one I had was junk.
Offline grbmds
« Reply #21 on: July 19, 2019, 08:30 PM »
Rockler (and Woodcraft as well as other sources) now sell the Damson panel clamps. They work well and are much cheaper than the Woodpecker version (which might a little easier to use than the Damstom). I have used the Damstom clamps for several years with great success; only up to 38" though.
Randy
Offline ben_r_
« Reply #22 on: July 23, 2019, 10:15 PM »
Reviews dont seem that great on the Damstoms (LINK) and they dont pinch like the Woodpeckers do, but the Woodpeckers are insanely overpriced.
Offline grbmds
« Reply #23 on: July 23, 2019, 10:17 PM »
Don't know what people find to be a problem with the Damstom clamps, but they work great for me. I wouldn't even consider spending the money on the Woodpecker panel clamps.  They just wouldn't buy me much of anything I don't already have with the Damstom clamps.
Randy
Offline Alanbach
« Reply #24 on: July 23, 2019, 10:47 PM »
I have three of the Damstons and they are good but they do not apply any downward pressure to keep the boards lined up as I apply clamping pressure. When I need help from the clamps to keep the boards lined up I have to add clamps in the front and the back of the piece to squeeze the damston bars They are also limited to 38”. The Clampzilla’s do provide downward pressure across the panel which, for me is the big difference. Additionally now that WP has offered the 50” option that really helps their case for me.  For those reasons I think that I am going to order a couple with the longer bars. At a million dollars a piece I don’t see stocking up but having a couple to salt in with my damston’s and my K Bodies does seem worthwhile to me.
Offline Blues
« Reply #25 on: July 28, 2019, 04:38 PM »
This concept has been around for many years!! While its simple.. works great.
https://advanced-machinery.myshopify.com/products/plano-vertical-glue-press?variant=27784568390
Unless you have significant use, the Domino and lowly bar clamps prevail.
Offline ben_r_
« Reply #26 on: July 29, 2019, 04:30 PM »
Seriously. At these prices it'd be cheaper and WAY more versatile and useful to just buy a Domino rather than these overpriced clamps!
Offline grbmds
« Reply #27 on: July 29, 2019, 04:50 PM »
Also expensive. Despite previous comments the Damstoms work with a bit more setup on the beginning of the glue up than I’m sure the WP or the panel clamp setup requires. A lot less expensive though.
Randy
Offline ben_r_
« Reply #28 on: December 04, 2019, 06:49 PM »
Bumping this thread because Im curious. Did anyone order these and try them? How do they work? Many of the complaints with similar style panel clamps such as these is that the pinching pressure that flattens all the boards together isnt enough or that great. I was wondering if the same issue plagued the Woodpeckers design.
Offline Ster1154
    • WoodEyes Woodworks
« Reply #29 on: December 09, 2019, 12:40 PM »
I ordered a set but haven't received it yet (was supposed to ship the 29th I believe, so it should be coming soon).  Once I get them I'll let you know as I have a few tabletops I need to clamp up.
