Author Topic: Bandsaw Dust Collection  (Read 2993 times)
Offline dlu
Re: Bandsaw Dust Collection
« Reply #30 on: May 19, 2020, 12:27 AM »
@dlu   isn’t that black tube a dust collection chute? Doesn’t it work better than the little pvc tube running perpendicular to the flow of debris?
[/quote]
Yes, it is. The black tube, the stock dust collection point is just "in the vicinity of" the dust coming off the blade. Attaching a shop vac there gets a fair amount of the dust, but still misses a lot. My "little PVC tube" is just missing the teeth of the blade and seems to do a much better job.
If the stock port wrapped around the blade, like @Cheese's appears to do (and I had enough air volume) I expect it would work better.
« Reply #31 on: May 19, 2020, 09:50 AM »
Isn’t that black tube a dust collection chute? Doesn’t it work better than the little pvc tube running perpendicular to the flow of debris?
I had the same item on my bandsaw. It has an ID of 1 1/8" and is at least 1" away from the blade. So it catches some of the stuff, maybe 25%.
« Reply #32 on: May 20, 2020, 02:11 PM »
rmhinden use Carter micro-adjust
Cheese perhaps Carter 2400 series?
What’s wrong with this picture?
This is what Rockler uses to sell Carter guides.
Thought I might get a set using the Rockler 15% discount (V20610) but they only have the basic model, and this picture of the teeth deep inside the bearing is off putting.
« Reply #33 on: May 20, 2020, 02:42 PM »
Mucho... [eek] [eek] [eek]
That's just a very bad picture Michael...it's tragic that they'd even use that for advertising purposes. Get the blade tracking properly first and then do the adjustments.
1/2" wide DoAll wood blade.
3/4" wide Lenox metal blade.
