I recently bought a Rikon 10-326 (14") bandsaw, mostly for re-sawing wood.
I having been cutting Sapele veneer for a project. A heck of a lot of veneer actually, and almost finished, and its been giving pretty good results. But suddenly I can't cut straight.
The blade is pulling towards the fence. I was using two featherboards, one high, one low, to keep the board against the fence, but for test cut shown below, I just held the piece of scrap against the fence for a test cut. You can see how within a few inches, the blade pulls towards the fence. I now have marks on the fence from where the blade has contacted the fence. Cut is pretty straight, top to bottom.
Many boards I could cut with the guide rollers just above the fence, but the last board was a bit taller and I raised the upper guides another inch. After that adjustment is when the problems started. (sorry, should have stood back another foot so I would get the guide rollers in the photo)
I increased the blade tension a bit. I checked the fence angle, and did have to adjust it a bit to get it parallel to where the bandsaw wants to cut. Tried lowering the upper rollers an inch again. Tightened up the clearance on the upper guide rollers. Did not help much.
I don't know what to check or adjust next. Any thoughts ?
Edit: I did notice that recently the cut had a higher propensity to smoke, so that tells me somethings are fighting. So maybe the answer is the angle of the fence ?
