Author Topic: Baltic Birch Drawer - Flat Top vs Roundover?  (Read 2480 times)
Offline Bugsysiegals
« on: November 21, 2020, 09:50 AM »
I’ve 5/8” BB sides for my drawer boxes and wondering whether I should leave the tops flat or use a roundover bit ... how do you prefer yours?
If with roundover, I’ve no roundover/chamfer bits and see WhiteSide has 20% off ... would you recommend any specific rounderover or chamfer bits?  What about for dado cuts ... I seen Sedge make dado’s with the router and while the table saw is easier for batches of stock, I liked the router for non through cut stopped dado’s so you don’t see the dado on butt joints. Are there bits for this you’d recommend which create “perfect” width for the varying thickness of plywoods?
« Last Edit: November 21, 2020, 12:33 PM by Bugsysiegals »
Offline Sparktrician
Re: Baltic Birch Drawer - Flat Top vs Roundover?
« Reply #1 on: November 21, 2020, 10:11 AM »
Amana Tool makes several undersize bits for use with plywood.  Look through this listing for some options.   [smile]
- Willy -
« Reply #3 on: November 21, 2020, 11:21 AM »
I prefer the the solid carbide spirals.
Wouldn't it be nice if we could find a US/Canada/Europe manufacturer that made up-cut spiral bits in undersized dimensions just for plywood?   [cool]
- Willy -
Online rvieceli
« Reply #4 on: November 21, 2020, 11:49 AM »
Offline afish
« Reply #5 on: November 21, 2020, 12:05 PM »
1/8 is probably the most for me, just tying to break the edges a bit.  1/4 on both sides of 5/8 is going to be almost half round. I dont do both sides on the front piece.  If you do it creates a little groove that I see as a perfect dirt catcher. I do drawers on tablesaw pre cnc.  sides always ran full length so drawer front covers the dado grove and you cant see the back one unless you really wanted to.  I used to have 2 tablesaws set up the main unisaw for cutting panels and a bosch contractor saw on gravity stand with a full time dado stack.  When I needed to do drawers I would just flip it out and run the drawers through. Fold it back up and wheel it back into the shed out of the way.
« Reply #6 on: November 21, 2020, 12:59 PM »
Ya it would...but I've pretty much given up on that until the plywood manufacturers either standardize their thicknesses or fine tune their processes.  [sad]
I'm presently working on some prefinished Tigerply carcases that vary from .697" to .721". And I'm marrying them to a couple of 2 year old prefinished Tigerply carcases that vary from .712" to .736".
I purchased a CMT set of bits for plywood about 5 years ago and have yet to use them as they are always the wrong size.
For all those reasons, I added a MicroFence to my arsenal and now just dial in the spiral bit of my choice. Make a pass, measure, dial the bit in .010" over, make another pass & done.
« Last Edit: November 22, 2020, 09:38 AM by Cheese »
« Reply #7 on: November 21, 2020, 07:47 PM »
Thanks, I’d not heard of this brand ... I’ll have a look.
« Reply #8 on: November 21, 2020, 07:48 PM »
« Reply #9 on: November 21, 2020, 07:50 PM »
Probably would want to break the drawer top edges a bit. So at least an 1/8 inch round over down both sides.
https://www.woodcraft.com/products/whiteside-2000c-roundover-router-bit-1-4-sh-1-8-r-x-3-4-d-x-1-2-cl
or 1/4 inch radius
https://www.woodcraft.com/products/whiteside-2001-roundover-router-bit-1-4-sh-1-4-r-x-1-d-x-1-2-cl
Ron
If you do them on the inside, how do you blend the sides to the front/backs?  Do you do it after assembled and then the inside corners don’t get touched?
« Reply #10 on: November 21, 2020, 07:55 PM »
For all those reasons, I added a MicroFence to my arsenal and now just dial in the spiral bit of my choice. Make a pass, measure, dial the bit in .010" over & done.
I’ve a Bench Dog router table extension wing and can reverse my Incra fence which has micro adjust. I’d not even thought of using one of these bits in the router table and instead was thinking how to do it with the guide rail attachment and OF 1010/1400.  This is interesting as I bet it’s much quicker to setup the bit in the router table than to change out to the dado blade.
So do you use up or down cut bits and do you use 1/4 or 1/2” bits?  I try to stay with 1/2” but wondering if I should be doing anything in 1/4 so I can use it with the lighter OF 1010.
« Reply #11 on: November 21, 2020, 08:02 PM »
I see some of these roundover bits have pilot bearings ... would you recommend with or without the bearing?
Offline afish
« Reply #12 on: November 21, 2020, 08:31 PM »
yes 100% with bearing.  I consider Round over bits to be one of if not the first bits someone should own. I would go ahead and pick up the sizes 1/16"r - 1/4"r unless money is tight so you have them on hand. You can then also start small and work up till you find a radius you like.
As far as when to do it I do it after the drawer is assembled.  all 4 inside top edges and 3 outside top edges.  I leave the outside edge that mates to the front panel square as mentioned before.  Yes this method requires you to balance and keep the router square to the sides all while riding on a very narrow edge.  Its not that hard but does take a little practice.  If your concerned about your abilities doing that you can cut some scrap the same height as the inside and outside height of the drawer and space it an inch or two away this will give the router base two points of contact and be much more stable.  Routing the drawer after assembly solves any issue with the inside corners.  I use a cordless trim router for this task since its easy to hold and quick.
« Reply #13 on: November 21, 2020, 09:06 PM »
Money is not an issue ... I’ll get 1/16, 1/8, and 1/4” to start but do you recommend 1/4 or 1/2
“ shank?  Also, I see they have ones with small pilot bearings ... should I just stick with the normal sized bearings?
Would it be easier to install the bit in the router table, set the height, and just move the box around the bit?  Could be an easy way to knock it out perfectly?
Offline afish
« Reply #14 on: November 21, 2020, 09:37 PM »
I prefer 1/4 shank for small round overs so they go in a trim type router.  Yes a router table should work well depending on the router table to drawer size ratio. If your going to be building lots of drawers I would try and get comfortable handheld but thats just me and everyone has their own comfort level.
Online Bob D.
« Reply #15 on: November 22, 2020, 04:26 AM »
A roundover bit will require two passes. Would it be possible to use
a double-roundover bit and run the pieces through before assembly.
https://www.whitesiderouterbits.com/collections/double-roundover
Offline afish
« Reply #16 on: November 22, 2020, 06:45 AM »
You could do it that way but then you end up with strange inside corners where there front and back panel butt into the sides.  Since the sides will have a radius that will be butting to a square edge you get a little valley at each corner and if you radius the short edge of the F/B you get an even bigger valley.  Rounding over after the drawer is assembled looks more seamless.
« Reply #17 on: November 22, 2020, 06:45 AM »
I suspect the double round over will create a bullnose rather than just breaking the edge but am not sure as I’ve never used one. As far as routing before assembly, please share a pic of how the corners will look once assembled ... I’m not sure this would ever look good unless the front/back are different height than the sides but I could be wrong ...
« Reply #18 on: November 22, 2020, 06:51 AM »
Regarding a seamless appearance, it seems a regular bearing but wold not get all the way into the corner and would leave the corner with some excess flat material than the smaller bearing bit?
For example, this bit with regular bearing ... 1/8 radius regular bearing vs 1/8 radius small pilot bearing.
Offline afish
« Reply #19 on: November 22, 2020, 08:07 AM »
the pilot will get you into the corner more but you may end up with some burn marks if your not careful.  I use the bearing bit and adjust the round over until I just get a slight roundover in the corner enough to provide a smooth transition and not a noticeable starting and stopping of the roundover.  It can be a fine line between to much roundover depending on your taste. The pilot bearing will give you the smooth corners with less roundover if that makes sense.  I would do a couple tests on some scrap to dial it in where you like it.  You might want to pick up a 5/32 round over too.  At the end of the day I would rather have a little more roundover than burn marks to try and remove.  The bearing bit allows me to quickly add the radius without needing to worry about having to do any extra sanding. For me its about striking a balance between delivering a product that looks good but can still be done efficiently.
« Reply #20 on: November 22, 2020, 09:28 AM »
Thanks @afish, I definitely don’t want burn marks!!  I’m not sure I understand the adjustment to get that sweet spot you’re referring to ... have you any pics to illustrate?
« Last Edit: November 22, 2020, 10:17 AM by Bugsysiegals »
« Reply #21 on: November 22, 2020, 10:04 AM »
Willy @Sparktrician suggested Amana and they also make great solid carbide spiral bits. I have several that I use on aluminum. The only reason I pushed Whiteside was because there is currently a 20% off sale on them at Woodcraft, I believe it ends today.
So, if you haven't decided yet, you can order some Amana bits from ToolsToday and usually receive a 10%-15% discount for signing up to their newsletter.
https://www.toolstoday.com/router-bits/spektra-extreme-life-coated-router-bits.html?sort_by=relevency&page_num=2
https://www.toolstoday.com/router-bits/spiral-solid-carbide-router-bits.html?sort_by=relevency&page_num=2
https://www.toolstoday.com/router-bits/compression-spiral-solid-carbide-router-bits.html?sort_by=relevency&page_num=2
FWIW...I just use a sanding sponge on the edge of a drawer box to just break the sharp edge or a Festool foam hand pad like these.
« Reply #22 on: November 22, 2020, 01:26 PM »
https://www.whitesiderouterbits.com/collections/spiral-router-bits
https://cdn.shopify.com/s/files/1/1698/7023/files/WM_Catalog_50_email.pdf?v=1603140047
(Attachment Link)
Which spiral bit would you recommend ... up cut, down cut, up/down/ compression, 1,2,3 flutes ... that’s a lot to choose from!?!?
Offline afish
« Reply #23 on: November 22, 2020, 01:53 PM »
Here is the photo as requested. Its hard to tell from just a photo but the bit is adjusted so it just does a slight ("ramp" for lack of better term) effect in the corner.
« Reply #24 on: November 22, 2020, 02:36 PM »
That’s a bit of optical illusion but I can see what’s happening...thanks for sharing!
« Reply #25 on: November 22, 2020, 02:46 PM »
1 flute = recommended for plastics & non-ferrous metals
2 flutes = recommended for plunging
3 flutes = will not plunge because they don't remove material in the middle
up cut = I like those a lot because they evacuate the scrap material
down cut = nice top edge but they keep packing material into the slot, shallow cuts are necessary
compression = never tried one for a dado but it could be a winner
Here's what I used on this dado, 2 flute solid carbide, spiral up cut bit, along with blue painters tape. This is pre-finished ply and I really rubbed the painters tape into the ply with a rubber Bondo applicator.
Clamped a hard stop to each end of the dado.
I used 1/4" ply for the back but the ply measured in at .255"/.265" so I needed to do several passes.
First pass at half depth, 2nd pass at full depth, measured dado width, adjusted MicroFence to give +.010" dimension, 3rd pass at half depth, 4th pass at full depth.
Online Bob D.
« Reply #26 on: November 22, 2020, 03:01 PM »
It would depend on which bit you get and how thick your material is. If you got a bit with two 1/8" radius cutters the center would be flat and you would have a 1/8" round over on each edge. A bullnose bit would carry the arc across the whole edge. The double-roundover bit has two individual cutters that you can space as you see fit.
« Last Edit: November 22, 2020, 03:05 PM by Bob D. »
Offline afish
« Reply #27 on: November 22, 2020, 03:11 PM »
Cheese thats an interesting gable you have pictured there. lots going on for sure but whats going on with the top?  why the 45ish degree angle?
« Reply #28 on: November 22, 2020, 03:19 PM »
Thanks Cheese!  Without the Blue painters tape will the thin veneer chip out?  Since you were making several passes, could you have simply used a down spiral and avoided the painters tape altogether?  Since you made several passes and I assume use Festool with their good dust collection maybe it wouldn't pack chips down into the dado in a way which would wear out the bit?
« Last Edit: November 22, 2020, 03:42 PM by Bugsysiegals »
Offline afish
« Reply #29 on: November 22, 2020, 03:19 PM »
ha, I was just cruising around on amazon and ran across this mini bearing round over I wasnt even searching for router bits but somehow I stumbled across it, perhaps my computer is spying on me...
« Reply #30 on: November 22, 2020, 03:24 PM »
@Cheese, two questions: 1) is that rectangular box structure a spacer for the glides, and 2) what are the white plastic pieces just below the Paolini ruler?
- Willy -
Offline afish
« Reply #31 on: November 22, 2020, 03:31 PM »
Im not 100% but the white plastic piece below the ruler is a terminal strip which Im guessing is for all the magnetic switches he has which Im also guessing is some type of drawer opening sensor.  The terminal strip would help organize all the wires hes going to have.  Looks like its in the toe kick area but I dont see any bottom.  Its unusual construction for sure the dado with a domino below it has me more confused than the wiring but Im sure he has it planed out.
« Reply #32 on: November 22, 2020, 05:09 PM »
These are built in cabinets for under a knee wall. That 45º makes the top drawer a bit short but it's still "free space" for socks, jewelry and the like. These built-ins are 10' long and I just didn't want to give up that much space. [big grin]
« Reply #33 on: November 22, 2020, 05:26 PM »
Sparky, the box made from ply fits on the Blumotion slides and with a magnet taped on the back it allowed me to properly place the proximity (reed) switches when I was going that route. Unfortunately, the in-rush current when the LED's turned on actually welded some of the contacts together and the whole thing became hit or miss.
That fiasco forced me to implement micro switches instead but I was still able to use the box for proper switch positioning.
Like afish mentioned it's just a terminal strip.
« Reply #34 on: November 22, 2020, 05:47 PM »
Ah, got it!  Very clever setup, indeed!  Thanks for the infill.   [smile]
- Willy -
Offline mkasdin
« Reply #35 on: November 22, 2020, 11:02 PM »
easing over edges I use a 1/16” router bit or 220/320 grit sandpaper by hand.
« Reply #36 on: November 23, 2020, 10:24 AM »
(Attachment Link)
(Attachment Link)
Thanks @Cheese!  I ended up buying a 1/4" and 1/2" compression bit ... the trick is that the tip, which is an up cut, needs to remain underneath the veneer on plywood to prevent tear out.  I believe the tips are about 1/4" long ... it seems as long as I can make my dado's at least ~0.26" deep these will work well and I don't see a problem with that for 5/8" drawer boxes or 3/4" cabinets.  Anything thinner for some smaller project I suspect would be made of hard wood and wouldn't matter ...
