Which spiral bit would you recommend ... up cut, down cut, up/down/ compression, 1,2,3 flutes ... that’s a lot to choose from!?!?
1 flute = recommended for plastics & non-ferrous metals
2 flutes = recommended for plunging
3 flutes = will not plunge because they don't remove material in the middle
up cut = I like those a lot because they evacuate the scrap material
down cut = nice top edge but they keep packing material into the slot, shallow cuts are necessary
compression = never tried one for a dado but it could be a winner
Here's what I used on this dado, 2 flute solid carbide, spiral up cut bit, along with blue painters tape. This is pre-finished ply and I really rubbed the painters tape into the ply with a rubber Bondo applicator.
Clamped a hard stop to each end of the dado.
I used 1/4" ply for the back but the ply measured in at .255"/.265" so I needed to do several passes.
First pass at half depth, 2nd pass at full depth, measured dado width, adjusted MicroFence to give +.010" dimension, 3rd pass at half depth, 4th pass at full depth.
