Author Topic: Anyone hear of Carbon Method tool coating?  (Read 1735 times)
Offline festal
« on: June 02, 2022, 07:20 PM »
Someone in one of the FB groups i browse mentioned today that they use https://carbonmethod.com/carbon-coating/ for protecting cast iron tables on their tools.  Its expensive and i can't find any real world reviews but i watched the application video and seems easy enough.  Application is done 6-12 months intervals
Snakeoil or good?
Offline Birdhunter
Re: Anyone hear of Carbon Method tool coating?
« Reply #1 on: June 03, 2022, 05:41 PM »
I hope you get some good inputs as I am always trying to keep my tools in excellent condition. I use WD40 on my cast iron tables.
Birdhunter
Offline Crazyraceguy
« Reply #2 on: June 03, 2022, 06:20 PM »
Really? I avoid that stuff at all cost. I keep some at home, for household things, but not in the shop.
I worked in a bodyshop for many years (90s) and it was a definite no-no there too.
We use Johnson's paste wax on cast iron tables. I have even used Briwax in a pinch, it's a little expensive for that application, but worked out fine. I think the Johnson's was a bit more durable? I think it lasted longer, but that is hard to quantify.
CSX
DF500 + assortment set
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
TS55, FS1080, FS1400/ LR32, FS1900, FS 2424/ LR32, FS3000
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Centrotech organizer set
Socket/Ratchet set
Pliers set
Offline Birdhunter
« Reply #3 on: June 04, 2022, 06:06 AM »
Re paste wax….. won’t the wax transfer to the wood? I’ve found once wax gets into the wood pores, applying any finish is difficult.
Birdhunter
Offline festal
« Reply #4 on: June 04, 2022, 07:30 AM »
it shouldn't.  you apply it, then buff it off.  Johnsons doesn't seem to effect wood
Offline festal
« Reply #5 on: June 04, 2022, 07:33 AM »
are you referring to wd40?
« Reply #6 on: June 04, 2022, 09:31 AM »
Yes, that stuff, as a vapor in the air, is a fisheye nightmare. You may never have a problem with hand-applied finishes, oils etc. but sprayed lacquer is a totally different matter.
Paste wax has never been an issue, when used on table surfaces, clamping cauls, etc.  If you got it on your parts directly, while "wet", it would be a problem though
CSX
PS420 + Base kit
OF1010
OF1010F
OF1400
MFK700 (2)
CT15
RO90
RO125
ETS EC 125
RAS115
ETS 125 (2)
RTS 400
TS75
MFT clamps set
Installers set
Socket/Ratchet set
Pliers set
Offline luvmytoolz
« Reply #7 on: July 05, 2022, 07:10 PM »
I've used Silverglide with good results to protect steel tops, but one of the best I've found is Fluid Film, which is a lanolin based gel. Wipes on and lasts for ages, buff and there's no residue. Especially ideal for when machines aren't going to be used for a while.
