I noticed a couple of people posted their custom-built drill press table, so I thought to add another one. Who knows? It might inspire someone to make an even better one.
I started out with a CAD drawing. If anyone wants a copy, it is available, but in a non-standard format (FreeCAD).
First I have to move the handles outward, because otherwise they would get blocked by the platform.
I also added a Wixey depth gauge and a laser, because my drill press didn't have those.
Here's the platform with integrated T-tracks and centre scales.
You might notice the laser lines do not cross in the centre of the sacrificial plate. That is on purpose. I wanted to use round backer boards, because square ones can only be used on 4 sides. Now I can get a lot more mileage out of them by just turning them a few degrees. There's a finger hole to make it easy to replace or turn the backer boards. And the boards are inserted in another insert
![Tongue Out [tongue]](https://www.festoolownersgroup.com/Smileys/default/tongue_smilie.gif)
I did that so I could easily replace the drilling insert with sanding inserts for drums with different widths.
Obviously dust collection when drillng would be nice to have as well
And to have dust collection when sanding I put the platform on a box with a dust port that fits my CTL26.
The whole assembly is fixed with 4 bolts that can easily be loosened if I need to remove the table.
I had a Woodpeckers Super Fence that I didn't use yet, that I now use as a fence (both vertical and horizontal). I made 2 blocks that are perfectly square to fix the fence in vertical mode to the tracks. On the fence I epoxied a left and a right lexan scale to create a centre scale. The epoxy works really well for this. There is still no peeling at all.
Sometimes I have very small pieces where the knuckle clamps I use don't work that well. So I made a wooden sub fence that can be attached to the T-tracks for those situations.
Finally I put the drill press on a platform with casters so I could move it when needed.
Up to now I am very satisfied with this contraption. If there is one thing I regret then it is that I didn't notice in time that the guide rail had moved when I routed the groove for the right T-track. I won't repeat the noises I uttered when I found out...
![Scared [scared]](https://www.festoolownersgroup.com/Smileys/default/scared.gif)
![Crying [crying]](https://www.festoolownersgroup.com/Smileys/default/crying.gif)
