Author Topic: Air cylinder/MFT3  (Read 2502 times)
Air cylinder/MFT3
« on: November 13, 2015, 09:48 AM »
I am looking for an air cylinder inline clamp I can adapt to the MFT/3 table to use for clamping up cabinet doors. Has anyone heard or done this before?
Offline rst
Re: Air cylinder/MFT3
« Reply #1 on: November 13, 2015, 10:15 PM »
Air cylinder clamps are common in industry and easy to find...that being said I'm not sure that the MFT top is up to the pressures that air clamps can exert.  I use air clamping cylinders and vacuum systems, most would definetly deform the  MFT holes if used regularly.
Offline Bohdan
« Reply #2 on: November 14, 2015, 05:11 AM »
You can reduce the air pressure to limit the clamping force to whatever you need and not damage the MFT.
« Reply #3 on: November 14, 2015, 09:21 AM »
 I've had clamping tables and that was my thought. The clamp used on a precision dogs plate would not deform the hole. I have found a few clamps, actually pretty cheap.
 Scott G.
Offline Knight Woodworks
« Reply #4 on: November 15, 2015, 03:27 PM »
Scott,
I have no advice on fitting air cylinder clamps to an MFT, but would love to see a few pics of your build.
John
