Question out of curiosity
Are you going to blast clean all the old paint off and then repaint as part of the refurb? In I think its the 7th pic there's what looks like the base for another machine that looks like it was cleaned down to metal and then repainted.
What kind of primer and paint are you using on that old steel?
thanks, markus
I will needle scale them, grind any high spots/seams (although this casting is really nice) epoxy prime, filler, sand, high build primer, block sand, prime, block sand, putty, prime, scuff, paint. Lot of work.
Yes, that's one I am working on for someone else, its casting was kinda ugly, turned out nice.
Epoxy primer for bare castings
Filler is from napa
Primer is a 2k high build urethane
Paint is do-it best industrial Acrylic enamel (made by SW) sprayed with 2.0 tip hvlp
Sent from my SM-N960U using Tapatalk
