Author Topic: 2019 Miter Saw options?  (Read 11300 times)
Offline 3PedalMINI
    • Signature Sound & Video
« on: February 27, 2019, 09:19 AM »
a few years ago my Kapex got stolen, at the time I was buying a house so I couldn't swing another saw. Did minimum research because I needed a saw ASAP and I ended up with the Bosch glide and I could not despise that thing more. I have to constantly tune it, the detents are not properly aligned and the blade has some of the worst deflection I have ever seen. (the general complaints with the saw) Now, I would have NO problem buying another Kapex, the thing is, because of this debacle I got a Incra miter setup on my PM2000 and have actually grown to love it. I know there is no replacing a miter saw, especially for molding so assuming a non kapex what would you look at doing?
I know this question has been beat to death, but there seems to be a BUNCH of new saws on the market. It actually seems like the battery powered saws are getting better reviews for accuracy then the corded ones. (although I would prefer corded)
I am mostly a DIYer but do have todo some jobsite work occasionally. Portability is not really a concern since it lives in the garage most of the time. All I want is a saw that doesn't deflect, can cut 5 1/4 baseboard vertically and something I can trust to cut a 90/45/22.5 and not have to put my woodpecker squares on it every time I make a move.  Again, I have no problem buying the kapex, except the motor burn does worry me a bit. But if I can save some money and have good results then why not?
The Bitterness of poor quality remains long after the sweetness of low price is forgotten -Benjamin Franklin
Professional Custom Audio Video System Designer/Installer serving Southern - Middle NJ, Eastern PA & the Surrounding Shore Points.
www.sigsv.com
Kapex 120,TS55,RO150,ETS125,CT-26,CT-MIDI,Tradesmen Cleaning Kit, Festool Ratchet Kit, Sys-lite, Sys Roll Cart, T18 +3, 2013 Centrotec Kit, Carvex 420, Carvex Accessory Kit, CXS,RO90, TI15 and Various Festool Systainers
Offline RKA
Re: 2019 Miter Saw options?
« Reply #1 on: February 27, 2019, 10:44 AM »
Take a look at the Dewalt DW717.  I had a 780 which was built reasonably well.  It wasn't as accurate as the kapex, but a lot of that had to do with the 12" vs 10" and the small rails on the 12" saw head.  The 717 has a large vertical and crosscut capacity and a large bevel scale.  The two minor quibbles I had with the 780 was no soft start, but that takes a back seat to performance.  And the "bearings" if you can call them that on the slider are nowhere near as nice as Festool or Makita.
Speaking of the Makita, the 1019 looks to be pretty nice.  A friend got one and I only had a chance to fondle it a bit after we tweaked the rails to get the blade inline with the rails.  That adjustment may take a bit of time, but once you get it right, it should be fine.  If I didn't have the Kapex, I think that would be at the top of the list.  Out of the box dust collection is probably pretty good as well.
-Raj
Offline Oldwood
  • Alberta, Canada
« Reply #2 on: February 27, 2019, 01:13 PM »
I have a Makita 1019L and I am very happy with it. It has 2 hoses for dust collection but they both connect to a 1.25" port. I split the 2 hoses so I can connect them to a 2" t connection on my vacuum. This improves the dust collection a lot.
The rpm is a little less than some of the other saws but if you feed the blade into the work accordingly this is a non issue.
Confucius
Offline 3PedalMINI
« Reply #3 on: February 27, 2019, 07:36 PM »
Hmmmm... The Makita actually looks really nice. I always forget about them! Does anyone have anything to say about Milwaukee?
Im almost leaning towards the Makita!
www.sigsv.com
Offline ktb153
« Reply #5 on: February 28, 2019, 12:59 AM »
I have the makita and have been using it daily for about 6 months now, I’m very happy with it. In that thread that was linked the member glass1 explains how to adjust the rails and I did that along with all the other initial adjustments when I first got the saw and everything is still dead on accurate. I have a dewalt 780 I use for site work and had a 12” glide that I sold after I bought the makita and am now considering another makita to replace the dewalt. I never owned the Kapex but used it a few times and as much as I love Festool that’s probably the only tool they make where I couldn’t justify it costing 3 times the makita. The only con with the makita is sometimes when plunging into a wide board the handle seems to vibrate which I’ve never experienced on another saw but the cut is still perfect so I don’t get it. Oh and their packaging is not made for shipping so buy locally if possible. It took 3 tries to get one without damage, the second one the box was torn in half and taped back together by FedEx where the saw obviously fell out of it and broke the handle.
Offline 3PedalMINI
« Reply #6 on: February 28, 2019, 07:34 AM »
Thanks guys! I’m strongly considering the makita. I read through that thread and I’m not sure I understand how to adjust the rails on it Incase I get one that is jacked up. Maybe if I had the saw in front of me it would make more sense.
I’m also wondering if I really need a sliding saw. I guess it’s nice to have the large cut capacity for larger panels and construction lumber.
www.sigsv.com
Offline RKA
« Reply #7 on: February 28, 2019, 08:00 AM »
It’s simpler than it sounds.
You loosen the screws holding the “cap” covering the front of the rails.  Then place a 12-15” 1x2 or other scrap of wood oriented vertically between the gap in between the rails.  Position the scrap of wood close to the rail ends (closest to you).  The scrap wood will be angled toward the left or right depending on how you fed it through the rails (which way depends on how you need to adjust).  Use the scrap of wood as a lever and push the top towards center so it’s closer to plumb.  Hold it where you want and tighten the screws on the cap.  It helps to have a second set of hands to tighten the screws because the rails will have a bit of spring to them. You’re only tweaking the rails in relation to one another 1/16” or less.  You may make several iterative adjustments testing in between until you get it just right. Start with a test cut as a baseline, note which way you twist the rails and compare the first and second cuts to see if you twisted in the correct direction or not.
-Raj
Offline waho6o9
    • Garage Door Handyman.com
« Reply #8 on: February 28, 2019, 11:12 AM »
36V Makita with a 7.5 inch blade used for small face frame type work and I Like it.
The Festool vac hose hooks up to it so I'm good with it.
293677-0
Offline 3PedalMINI
« Reply #9 on: March 02, 2019, 08:57 AM »
Grrr. Can’t fjnd anyone local that sells makita saws locally. Would love to check it out and feel it before I take the plunge.
I just don’t know what todo lol
www.sigsv.com
Offline RKA
« Reply #10 on: March 02, 2019, 09:19 AM »
If you venture up north, AW Meyer probably has one on the floor (near GW bridge).  Otherwise your best bet might be to play with the 36v model.  It’s reasonable similar.  Some larger Home Depot stores have them on display.
-Raj
Offline Dane
« Reply #11 on: March 02, 2019, 10:51 AM »
Here’s another vote for the Makita 1019, I’ve had mine for about 6 months and really like it.
Offline Mike Goetzke
« Reply #12 on: March 02, 2019, 12:05 PM »
I had the Makita LS1214FL for years and really liked it except for the slider bar needing so much room. I have many Makita cordless tools and batteries so I picked up the Makita 36V cordless. It is actually much smoother in action than the corded model. Highly recommend this.
Mike
Offline HowardH
« Reply #13 on: March 03, 2019, 08:28 PM »
I can't believe I am saying this....take a deep breath... exhale.... Ok.  Here goes.  Harbor Freight has a new pro line called Hercules.  I saw a few videos on in and it is almost a dead ringer for the DW 780.  I didn't see any video yet with it hook up to a DC because otherwise it creates a cloud of dust.  However, it looks very solid and could be real competitor.
Howard H
mft1080, P1cc, MFT/3, T15, TID-18, RO150FEQ, ETS EC 150, MT55cc, RTS400, CT22, CT36E, 800, 1080, 1400, 1900 rails, OF 2200, OF1400, CSX, C18, VacSys, Vecturo, Domino, Qwas dogs, Parf Dogs, Zobo's, Syslite Uni, CMS GE, Sawstop contractor, PM 1500, Shaper Origin. Felder AF-14
Online Bob D.
    • My Cordless Workshop
« Reply #14 on: March 04, 2019, 04:57 AM »
You don't have a Home Depot in your corner of SNJ? There are at least a dozen stores that I know of. HD carries Makita, maybe they don't have the particular model you are looking for I don't know but when I search their site for "Makita miter saw" I get over 20 hits.
Offline TheSergeant
« Reply #15 on: March 04, 2019, 01:33 PM »
I was looking at the Kapex for awhile but the motor issues kept me from it.  The price tag is well.  I went with a Bosch glide arm saw but the thing was simply not accurate.  I sold it.
I was going to buy the  new Makita but they had some alignment issues early on, so I decided to wait for them to sort it out.  In the meantime I purchased an older Makita LS1013 used from someone that upgrade to a Kapex no less.  I figured it would hold me over until the Makita sorted out the bugs in their new saw.
This LS1013 is phenomenal!  Very accurate, very repeatable.  Pleasure to use and quieter than the Bosch.  Yes, it hangs out the back and you need to account for that but overall I'm very very happy with it.  Might be worth considering if you can find one locally for sale.  I see them regularly for ~$200 in my area.
Beyond that I'd suggest the new Makita now that everything's been addressed.
Offline 3PedalMINI
« Reply #16 on: March 06, 2019, 09:13 AM »
its funny you mentioned this. I was in Harbor Freight the other day getting some furniture movers and saw it set up. It was actually VERY NICE, Surprisingly nice actually. Its definitely built to the dewalt standard. That being said I wonder how long it will last.
I want to get away from the 12" saws because of the deflection. If it was 10" I think I would have picked it up for giggles.
Im ready to order the makita I think. I wish I could buy it locally because of the shipping issues. Home depot sells makita, just not the saw in the store.
www.sigsv.com
Offline Steven Owen
« Reply #17 on: March 06, 2019, 10:59 AM »
It would always be between Makita and Dewalt for the best miter saws outside of the Kapex.  It’s easier to find more 3rd party accessories for the Dewalt Miter saws like zero clearance inserts and fence guides.  Zero clearance inserts and pretty critical if you’re doing any wood working.
Blade deflection is largely an issue with the blade itself and not the saw.  Get a good high quality Crosscut blade like an Infinity, a Woodworker blade, ect...never use the OEM on Dewalt or Makita of you’re worried about blade deflection.
Festool CT Midi, Festool ETS 125, DF 700 Domino Coming Soon
Offline demographic
« Reply #18 on: March 06, 2019, 01:32 PM »
After using three different Bosch sliding crosscut mitre saws at work on various sites I'd avoid them darn things like the plague, you couldnt give me one.
There always seems to be an issue with the electric blade guard lock or its cutting way off or whatever else.
 Almost every Makita Ive used has been basically reliable and taken a fair bit of hammer and many De-Walts have a dodgy little wheel on the blade guard that catches in the moldings of wood and throws the cut off line slightly. The only Milwaukee I've used has the same little wheel on the blade guard and I just wanted to launch that saw into the site skip.
I guess that means I'm more of a Makita bloke although I've never used a Hitachi and some of those look good.
Sorry but after Kapexgate I'd not be keen on spending Kapex type money on something I think might let the smoke out after a few years of babying it every time I use it.
Offline 3PedalMINI
« Reply #19 on: March 07, 2019, 09:33 AM »
Ordering the Makita. Ill report back once I get it, set it up and checked out.
www.sigsv.com
Offline alice
« Reply #20 on: March 07, 2019, 11:56 AM »
One thing in a miter saw i have to have is a vertical handle. A D handle style just doesn’t work for me.
Offline 3PedalMINI
« Reply #21 on: March 19, 2019, 08:43 PM »
Got the saw last week. and set it up on Friday. Took advantage of the Ebay 15% off, a seller was initially selling it for $509. I got it for $447
The saw arrived very well packaged, it had "protective" box edges and shrink wrapped really well. I Got the saw out and set up in 10 minutes. It was deadnuts accurate out of the box. Checked with my woodpecker squares and triangles. A few cuts on a jointed board and couldnt see any light, and of course 45's made  for perfect 90's. I have NEVER had any tool come out of the box so perfect before.
The laser is weird, but I dont use one anyway. The blade that came with the saw is surprisingly good, however I get a weird vibration on some cuts. Put my indicators on it and the blade isnt co planar (cant expect perfection on a provided blade) I ordered a forest chopmaster that should be delivered any day now.
I cannot believe im about to say this, especially on the FOG.....But IMO, It outperforms the kapex. I spent all weekend cutting crown and little detail moldings for a room I'm redoing and its phenomenal. The safety switch is actually really nice, I love how I can just shift my palm over to activate it and make the cut.
My only concern with it is the switch to move the saw to the detents feels a bit chintzy and I dont care for the way the bevel lock works to tilt it to the right. Kapex definitely has that down. overall I could not be happier with it, especially for the price point. Dust collection is fantastic, especially paired to my MIDI. Honestly given the choice, I think I would choose this over the Kapex. I didnt want to like it but man, Im glad I gave it a shot...
Thanks for the help guys!
www.sigsv.com
Offline ktb153
« Reply #22 on: March 20, 2019, 01:14 AM »
Nice, glad you enjoy it too and maybe makita got on the issue of the saws not being adjusted properly from the factory. I’m definitely not knocking the kapex as I’ve used one a few times and it’s an excellent saw but the motor issue kept me from buying one and now that I have the makita I don’t regret my decision at all. Keep us updated if the Forrest blade fixes that weird vibration, I put a tenryu silencer on mine and it’s still there. I’ve noticed it’s only when plunging into the board so if I start with the blade pulled towards me and push through the cut it doesn’t do that so I avoid it that way on everything but really wide boards. Whatever it is it doesn’t seem to mess up the cut, I noticed it felt pretty bad one time on a 12” wide board and put a woodpecker square across and couldn’t see any light.
Offline travisj
« Reply #23 on: March 20, 2019, 01:15 AM »
To clarify, you went with the LS1019 or the battery version?
Offline JimH2
« Reply #24 on: March 20, 2019, 09:17 AM »
+1
Offline morts10n
« Reply #25 on: March 20, 2019, 12:33 PM »
Can someone reiterate what it takes to calibrate the rails on the LS 1019L. I'm very happy with the saw, but while cutting  perfectly when mouldings are standing against fence, cutting boards flat produces out of square cuts. I was not able to budge the Allen screws that lock to the rails
Offline Jiggy Joiner
« Reply #26 on: March 20, 2019, 01:18 PM »
With any new miter saw, it’s good practice to square the fence to the blade for square cross cutting, and check the blade is verically plumb when zeroed before using the bevel facility.
This is done usually with loosening Allen bolts, or screws, or both.
If the bolts/screws are tight, they have probably been threadlocked at the factory. Firm even pressure should break the seal.
Offline RKA
« Reply #27 on: March 20, 2019, 01:22 PM »
@morts10n Scroll up to reply #7 in this thread.  You will need to loosen those little hex screws.  I hate it when little screws like that are overtorqued, they are so easy to strip out.  Try alternating counterclockwise and clockwise force on them just to loosen them up a little.  And make sure that allen key is fully seated before applying torque.
Are you sure the miter scale doesn't need to be adjusted?  Try doing an 8" sliding cross cut.  If the rails are skewed, the back edge of the blade (facing you) will create a stepped lip on one side of the kerf since it's not following the same kerf established by the front edge of the blade.
If you don't see that stepped lip inside the kerf, you might be okay and may just need to adjust the miter scale to get the blade 90 degrees to the fence.
-Raj
Offline oneeyesquare
« Reply #28 on: March 20, 2019, 09:50 PM »
I've been running the Makita LS1019L since July '17. Mine had the rail issue, which I adjusted and haven't touched since. My only beef with the saw is the aluminum detent gauge. Mine has some play from wear and tear. Rock solid saw that I found much more capable than the Kapex ( I sold both of them later that same year). Colliflower now has zero clearance inserts for it (I bought two!) and there is a guy on Instagram who has made a trial batch of stainless steel detent plates. plan on adding one more, just can't decide on battery or corded.  I highly recommend this saw!
Offline Paul G
« Reply #29 on: March 20, 2019, 10:18 PM »
skilsaw SPT88-01 12” worm drive. Toolnut says shipping 4/1. Will be interesting to see how the reviews play out. Hopefully it will show up at hone depot to see in person.
 https://www.skilsaw.com/wormdrive-dual-bevel-miter-saw-spt88-01/
+1
Offline glass1
« Reply #30 on: March 20, 2019, 11:29 PM »
Try sliding the detente plate forward towards you. If it’s too far back away from you there can be some slop on the ls1019. I think the cordless version is better. I have the ls1219 which I like better than both 10” models.
Offline DashZero
« Reply #31 on: March 20, 2019, 11:55 PM »
I had a Dewalt Flexvolt DHS790AT2
I used it to cut baseboard, rebuild split jamb door frames with a different mounding, cut luxury vinyl locking floor planks, cut 2x4.
It was used outside, under a carport, for 9.5 months on mostly battery power.  This was done to repair flood damage to my older brothers house.
I hated the dust collection.  It was hooked up to a a large Ridgid shop vac sometimes and other times a large craftsman shop vac. I found I couldn’t keep the weird rubber diaphragm open enough to capture saw dust.  To much suction the diaphragm collapsed, and not enough suction dust was sucked up.
During this time I used the Festool TS55 to make rip cuts for trim at the top of ikea kitchen cabinets, and to cut side panels for the ikea kitchen cabinets, and to cut Corian for the shower and tub surround and window ledge.  The dust collection on this was awesome.
I’m looking for another miter saw myself for some work at my home.  I think if all else fails I’ll cut some floor for my own place with the TS55.  Perhaps i can do the baseboard with a coping saw.
Offline simonh
  • Hobbyist / Maker of the VCS-R
« Reply #32 on: March 21, 2019, 09:20 AM »
I have the Dewalt 717XPS.  I felt the Festool Kapex 120 was too expensive for my needs and didn't really offer much more in features than the DW717.  The Kapex 60 was a similar price to the DW but a very poor comparison IMO and it just wasn't built the same as the 120.
The only slightly disappointing thing was the dust collection wasn't as good as on the Kapex I'd demoed. But the fix was very simple!  The problem seems to be that there is very little suction from a shop vacuum down at the dust shoe. Most of the suction is dissipated over too wide an area near the top of the blade.  To solve this I inserted a piece of 3/4" flexible pipe through the dust connection port and down to where the dust collection shoe is located (there's even a small aperture that is perfect to feed the pipe through to hold it in place). The difference is amazing. There's now real suction right near the back of the blade which you can see visually sucking the dust towards it (and also still suction up near the top of the blade where particles get flung). The dust collection is top notch.  It may benefit even further from a slightly bigger dust shoe in combination but I haven't been bothered with trying that yet as I've been so impressed with this simple modifiction.
-Simon
Offline RKA
« Reply #33 on: March 21, 2019, 10:27 AM »
Wow, well done simon!  It's amazing that a tool manufacturer doesn't invest the time to figure this stuff out and solve the problem.  Thanks for sharing!
-Raj
Offline alice
« Reply #34 on: March 21, 2019, 05:33 PM »
Does anyone know if a miter saw from Europe that is 110 volt work properly in North America?
« Reply #35 on: March 21, 2019, 09:00 PM »
I can’t see why not but, maybe compare ampage etc.
I have bought stuff from the USA, and fitted a UK 110 volt plug, and plugged it into a 110 volt transformer, and always been fine.
« Last Edit: March 22, 2019, 02:42 PM by Jiggy Joiner »
Offline DashZero
« Reply #36 on: March 21, 2019, 09:54 PM »
Which saw are you thinking about?
Offline simonh
« Reply #37 on: March 22, 2019, 04:13 AM »
I overheard someone at a trade show asking a Festool rep about availability of more 110V versions of tools in the UK. He said that 110V only accounted for 10% of their business worldwide. Rather than been development of any further 110V tools all future efforts would be directed at battery based versions.
Made me wonder if a battery version of the Kapex was the future and would solve the problems by giving full control of the power source! DeWalt and others already have battery versions so it's doable and the battery power is constantly improving.
-Simon
Offline alice
« Reply #38 on: March 22, 2019, 04:31 AM »
The saw I was looking at was the dewalt dws774 miter saw
Offline JimH2
« Reply #39 on: March 22, 2019, 09:15 AM »
The 110V tools are required on UK construction sites (and used extensively in US) so I doubt they will be scaling back on development. There is not a lot of difference between a 230/240V power tool and a 110/120V power tool beyond motor and possibly controller board (if one is present). The non-power related portions of the tools are probably all identical.
As for battery power the Dewalt 60V tools are promising. I have the mitre saw for framing and have used it with and without batteries. It works great with both, but having the option to plug in is the best feature it has. No fear of running out of juice and having to have a load of charged batteries around. One consideration on the Dewalt and probably other battery powered tools is that thinner kerf blades are used which can lead to deflection. Not a big deal for framing, but for trim it can be problematic.
Offline alice
« Reply #40 on: March 22, 2019, 11:07 AM »
Their is a battery version of the dws774 but their batteries are 54volt and we use 60volt.I wonder if you can use a 60 volt in their saws?
Offline DashZero
« Reply #41 on: March 23, 2019, 01:56 PM »
The Dewalt 54v battery can read up to 60v (maximum) on a voltmeter if charged full. Under load the 60V max battery gives 54v.
The sticker and wording is different due to marketing.
The 18v under load battery systems when changed to other style battery’s cases people to get confused which to buy in the US when Bosch I think changed.  Then Dewalt decided when going from the internal 18v underload Battery to the slide on battery to call it 20v MAX (vs 20v XR in other parts of the world)
That’s is my understanding from reading different sources.
« Reply #42 on: March 24, 2019, 08:24 AM »
Yesterday in two different tool shops/stores, I looked at the mains powered and cordless Makita. The mains powered versions had detente slop, and the cordless none? This was the case in both shop/stores. I know adjusting will fix it but, still odd that the cordless are rock solid even unlocked?
Offline travisj
« Reply #43 on: March 24, 2019, 01:42 PM »
I am going to try to go look this week.  My saw will be shop bound so cordless doesn’t necessarily interest me.  I am also not concerned about weight.  I want to compare the LS1019 VS the LS1219.  For me, I don’t see a downside for the 12” vs the 10”.
« Reply #44 on: February 12, 2021, 10:15 AM »
I tried the two-cut test on my 1019l, and sure enough, it's misaligned.
Two issues:
1. The hex bolts are *super* tight. I mean, the lower one is forcing me to bend my hex wrenches. How loose do they need to be?
2. I'm very confused by the cut test result. The two cuts i made appear to be off, but parallel to each other, not skewed. I'm not really sure how twisting the rails would get these two cuts to meet up, if you know what i mean.
Would appreciate any advice anyone has.
https://photos.app.goo.gl/AdWWc3cwxfzjJ9v5A
Offline jpmeunier
« Reply #45 on: February 12, 2021, 10:22 AM »
The bigger the blade the more deflection.
« Reply #46 on: February 12, 2021, 07:07 PM »
It seems to me that the problem with my test cut may be explained if the blade is not parallel with the rails, as i've tried to illustrate in the crude diagram below which is what things look like from birds-eye view. Is there an adjustment screw for this? It would seem like the adjustment would be near the blade's arbor?
I'm not sure that my test cut can be explained with the rails being twisted.
Offline glass1
« Reply #47 on: February 12, 2021, 07:28 PM »
Yep. There is only one way to fix this. Loosen the 2 bolts that attach the rails to the front connector bar. Twist bars and tighten screws. Trial and error till you get the rails untwisted.
« Reply #48 on: February 13, 2021, 11:22 AM »
If the rails being twisted were responsible for this, wouldn't the top of the cut be a different width than the bottom of the cut?
« Reply #49 on: March 03, 2021, 01:34 AM »
I ended up taking my saw into a makita factory service center. They were great, fixed the issue, had to actually replace the arm of the saw, not the rails. But the two cut test now looks great.
