Not sure how many of you have seen this video from "Hooked on Wood" but I encourage you to check it out here
I've been running a very similar insert on my Inca 259 table saw. I realized how much more effective this was after using a wide dado insert with a 1/4" blade and seeing the dust fly up into the air and then get sucked back down in the insert.
For an insert like this to be effective you really need to have your cabinet sealed as much as possible. It was an easy effort on my Inca 259 but Sawstop has so many gaps in the cabinet it took some real work. I sealed all the gaps under the table with pipe insulation, and all the vents, including the front slot behind the handwheel, with magnetic sign material. I removed the internal hose to keep air moving through the cabinet to keep in clean and the motor cool. I need to do some testing to see with and without the hose to see what kind of impact it has on cabinet cleanliness, airflow and motor temp.
The insert I used was an original sawstop phenolic insert before they went to the lever style. It was pretty chewed up and I never used it so I had nothing to lose by modifying it. I machined the insert to accept 1/4" melamine faced MDF inserts like the "Infinity Tools/Colliflower" insert. I do have a Colliflower insert, which I like but did not want to machine holes into it.
If you have a table saw and are disappointed with the dust collection I highly recommend this modification.
